UPDATE**** Replacement mainboard from Spain arrived today in post, quicker than some UK sellers
Fitted board and the set has powered up ok, all in Spanish though lol
Seems to be working ok, so it seems that it was a mainboard problem
Now to get the back cover refitted, not sure how it fits back yet, its a screwless cover
Reset/Retune and see how it goes
Ok still got a problem
TV is working, BUT it thinks it is still located in Spain
Reset it to factory settings twice, back to original factory settings (Spain)
Changed settings manually to English
No option on Location in the setup to select UK
When all setup completed, still in spanish
Terms conditions etc Spanish
Updated software to 1262
How can I convince this tv it is now in the UK
Can not find a way in the reset menu on the tv to change region to UK, many countries to choose from but no uk, got spain, germany italy etc. etc.etc but no uk
Is there an engineers setup menu on these tv's, as in the older samsungs tried info,menu,mute, power that did not get me into it
as i said inside service menu ( you call it engineering mode ) under MRT the region can be changed and language too..
Ok will try that again, I did try info, menu, mute, power earlier but it did not get me into that menu, I have used that menu before on older samsungs
Thanks for the help
Ok thanks for the help Diah
Got into that menu Changed Serial Number, changed language to EU nearest option, Region to paneuro
Restarted TV set up again much better but still not quite perfect
Have noticed channels are not in correct order, they are all over the place
WiFi is not working as in searching for WiFi did not detect any available WiFi, have got it connected by cable
In Menu, About this TV Wireless Mac Address is empty/blank,
Post photos on yours service menu , MRT available intery region ... language.. and where are listed wifi mac
you may forget to plug in wifi socket on replacement MB. in general wifi module mac stored on the module unless its defect as i mentioned early main fault of this samy model
forget to tell you.. yours replacement MB had before registered WLAN mac. which it other as yours.. from service menu make factory reset, it will read yours wifi mac and registered it if its not defect
