Samsung UE58MU6125K flashing standby led only
  • london-freddie
    • May 2015
    • 472
    Re: Samsung UE58MU6125K flashing standby led only
    yes will try it
    • london-freddie
      • May 2015
      • 472
      ok baked mainboard 10 mins in oven @ 200c
      Still same ie not working
      waiting for replacement mainboard to come, going to be a long wait
      • london-freddie
        • May 2015
        • 472
        UPDATE**** Replacement mainboard from Spain arrived today in post, quicker than some UK sellers
        Fitted board and the set has powered up ok, all in Spanish though lol
        Seems to be working ok, so it seems that it was a mainboard problem
        Now to get the back cover refitted, not sure how it fits back yet, its a screwless cover
        Reset/Retune and see how it goes
        • diif
          • Feb 2014
          • 6978
          • England
          The aim is not to bake but to reflow the solder under the main processor. 200c isn't hot enough for lead free.
          • london-freddie
            • May 2015
            • 472
            Ok still got a problem
            TV is working, BUT it thinks it is still located in Spain
            Reset it to factory settings twice, back to original factory settings (Spain)
            Changed settings manually to English
            No option on Location in the setup to select UK
            When all setup completed, still in spanish
            Terms conditions etc Spanish
            Updated software to 1262
            How can I convince this tv it is now in the UK
            • Diah
              • Feb 2013
              • 6343
              change region or serial No. all could be done in Service menu
              • london-freddie
                • May 2015
                • 472
                Can not find a way in the reset menu on the tv to change region to UK, many countries to choose from but no uk, got spain, germany italy etc. etc.etc but no uk
                Is there an engineers setup menu on these tv's, as in the older samsungs tried info,menu,mute, power that did not get me into it
                • london-freddie
                  • May 2015
                  • 472
                  It seems each time I reset to factory state it reverts everything back to spanish with no option to select UK when setting back up,
                  • london-freddie
                    • May 2015
                    • 472
                    I can change the language to english on the first set up menu, but not change the tv's location to uk, I have set that as other???
                    • Diah
                      • Feb 2013
                      • 6343
                      as i said inside service menu ( you call it engineering mode ) under MRT the region can be changed and language too..
                      TV in stand by. put the RC near the TV and very fast to press info,menu,mute, power
                      watch this youtube
                      https://www.youtube.com/watch?v=HWz826UQf4o
                      • london-freddie
                        • May 2015
                        • 472
                        Ok will try that again, I did try info, menu, mute, power earlier but it did not get me into that menu, I have used that menu before on older samsungs
                        Thanks for the help
                        • london-freddie
                          • May 2015
                          • 472
                          Ok thanks for the help Diah
                          Got into that menu Changed Serial Number, changed language to EU nearest option, Region to paneuro
                          Restarted TV set up again much better but still not quite perfect
                          Have noticed channels are not in correct order, they are all over the place
                          WiFi is not working as in searching for WiFi did not detect any available WiFi, have got it connected by cable
                          In Menu, About this TV Wireless Mac Address is empty/blank,
                          • Diah
                            • Feb 2013
                            • 6343
                            Post photos on yours service menu , MRT available intery region ... language.. and where are listed wifi mac
                            you may forget to plug in wifi socket on replacement MB. in general wifi module mac stored on the module unless its defect as i mentioned early main fault of this samy model
                            • london-freddie
                              • May 2015
                              • 472
                              Sure I connected wifi pug to mainboard
                              will get pics of menu in a few minutes
                              • Diah
                                • Feb 2013
                                • 6343
                                forget to tell you.. yours replacement MB had before registered WLAN mac. which it other as yours.. from service menu make factory reset, it will read yours wifi mac and registered it if its not defect
                                • london-freddie
                                  • May 2015
                                  • 472
                                  Pic of service menu
                                  • london-freddie
                                    • May 2015
                                    • 472
                                    I did a factory reset from this menu, may order a wifi module
                                    • Diah
                                      • Feb 2013
                                      • 6343
                                      change the code under network support to wifi_int
                                      • Diah
                                        • Feb 2013
                                        • 6343
                                        and wifi region look what other option you have and need to put the wifi vendor as printed on the module if it didn't detect it
                                        • london-freddie
                                          • May 2015
                                          • 472
                                          Thanks for that Diah, changed wifi-ext to wifi_int reset again and now have wifi detected and connected
                                          Now just to sort the channel order out
                                          • Michael Long
                                            No Standby Light on Samsung UN65MU6300FXZA with Mainboard BN94-12440E
                                            by Michael Long
                                            I had a Dead Samsung UN65MU6300FXZA with Mainboard BN94-12440E
                                            Dead / No Power / No Standby Light results after power company had three
                                            consecutive power outages on/off/on/off/on/off after which TV was rendered unresponsive.
                                            After exploring the issue found Mainboard was the fault. Then with research on this site determined IC1604 was the suspect. The IC1604 is a surface mounted device (SMD) EEPROM, Winbond Model 25Q40CLSIP. A read on this EEPROM came back with all FF FF FF FF FF in all registers blank and empty of data. I had a spare mainboard with intact IC1604 and utilized...
                                            09-13-2022, 06:55 AM
                                            09-07-2024, 05:50 AM
                                          • tvguy12012012120
                                            by tvguy12012012120
                                            02-07-2025, 05:13 PM
                                          • 7ony
                                            Samsung plasma - flashing standby light
                                            by 7ony
                                            The TV is a 2013 Samsung plasma, model # PN60F5300AFXZA.
                                            Snagged it up in non-working condition a couple years ago. Previous owner said that sometimes he could get it to come on after repeated tries but other than that he couldn't get it to turn on.
                                            Personally I haven't been able to get it to turn on at all. The standby light comes on solid when plugged in, but pressing the power button results in the standby light flashing once every 4 or so seconds. No "click" noises, no light from the panel at all. Just the flashing standby light.
                                            No visible...
                                            08-31-2020, 05:18 PM
                                          • ChristianBr01
                                            LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                            by ChristianBr01
                                            I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                            The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                            What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                            04-23-2025, 01:48 AM
