Panasonic TX-48CX400B - No Video
    • 12272
    • U.S.
    Re: Panasonic TX-48CX400B - No Video
    Originally posted by tmcw
    Ok, so I got another t-con board, but I have the same issues as before, sound but no picture.
    Testing the voltages on the new t-con board, I'm seeing more or less (+/- 0.03V) the same voltages as noted a few posts above.
    I went back to the power board, at the connection (CN4) that goes to the mainboard, and apparently I'm not getting what I think should be the +5V_STBY, this is what I'm getting on the pins (hope I've assigned the voltage to the correct pin)...
    1 24.8V
    2 0.01V
    3. 0V
    4. 0V
    5. 3.2V
    6. 0V
    7. 1.6V
    8. 0V
    9. 0V
    10. 11.8V
    11. 11.8V
    12. 11.8V
    I've attached the 071114 R9 schematic, but it doesn't show the CN4 pinout, I got the CN4 pinout from the R6 schematic, so assuming it would be the same.
    But the mainboard would be using 5V standby for generating video, would it, surely it would be using the 12V?
    Do the pins have a name beside them?
    • tmcw
      • Oct 2010
      • 382
      • Ireland
      No, they don't, I deduced which was pin 1 etc., based on the R6 schematic showing pins 10, 11 and 12 being 12V, and then working from there to fill in the rest. I also saw another poster saying the same thing here, post #10...
      https://www.badcaps.net/forum/showth...hlight=17IPS20
      I've attached close-ups of both sides of the connector, but you can see that there is no markings to tell which is pin 1.
      From the R6 schematic document, the pins are labelled as follows...
      1. PIN_1
      2. -| (Earth?)
      3. ST_BY
      4. -| (Earth?)
      5. BL_ON-OFF
      6. -| (Earth?)
      7. PWM_DIM
      8. -| (Earth?)
      9. +5V_STBY
      10. +12VCC_S
      11. +12VCC_S
      12. +12VCC_S
      And I'm getting...
      1 24.8V
      2 0.01V
      3. 0V
      4. 0V
      5. 3.2V
      6. 0V
      7. 1.6V
      8. 0V
      9. 0V
      10. 11.8V
      11. 11.8V
      12. 11.8V
      • diif
        • Feb 2014
        • 6978
        • England
        Looking at the schematic, Q212 is the 5V standby regulation.
          • 12272
          • U.S.
          Don't know if you already tried or not but did you see if you have the 5 volt stndby with the cable from powerboard to mainboard unhooked?
          • tmcw
            • Oct 2010
            • 382
            • Ireland
            Just tried that now...
            With the powerboard to mainboard cable disconnected, I still see zero volts on the 5V standby.
            But I notice that the 11.8V and 24.8V on the other pins are still there.
            I'm far from an expert, but I thought that these power supplies were designed to keep the higher voltage circuits disabled until the set was turned on, and that the 5V was needed to allow the set come out of standby, and which point the other voltages would be activated.
              • 12272
              • U.S.
              #26
              Check the trace and see where your stndby pin/s are going.
                • 12272
                • U.S.
                #27
                It seems strange that it looks like you have 2 labeled standby with no voltage on either.
                  1) If you look at the schematic, the ST_BY (PS-ON) pin is ACTIVE LOW (Q206 is the controller), you should see this line toggle high when TV is turned off.
                  2) Looking at your PCBA, it does not look like the 5VSTBY section is stuffed with parts.
                  3) The fact that the new T-CON board you have
                  VIN_12V ... 11.78 ... 11.82
                  but still no HVIN_12V ... 0.06 ... 0.06
                    T-CON training.
                    See how HVIN_12V is generated.
                      • 12272
                      • U.S.
                      #30
                      Thanks Bud, this will help many many of us.
                      • DanSpangles
                        • Dec 2020
                        • England
                        #31
                        Hello
                        Did you manage to solve this issue? I have exactly same issue on same model. Replaced all boards and still no voltage on HVIN on tcon. Any solution?
                        Many thanks
                        • DanSpangles
                          • Dec 2020
                          • England
                          #32
                          I will add that when I'm testing voltages I place my black lead on the casing and it shows 3v. Is this normal as it hasn't happened on any other TV I have looked at? When I placed the red lead on a ground point it goes to 0v. Just wondered if there was a short causing the issue.
                          • tmcw
                            • Oct 2010
                            • 382
                            • Ireland
                            #33
                            I've just seen your post here...
                            No, I never got any further with it, gave up, and put the TV into storage. May come back to it.
                            • dick_barton
                              • Aug 2015
                              • 6643
                              • Wales
                              #34
                              If Q212 is not in circuit then there will be no +5V_STBY
                                HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                                This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                                09-12-2024, 02:00 PM
                              • signal.quest
                                Panasonic LED TV TC-40A420U - Replaced Backlight LEDs but now no image/display or garbled
                                by signal.quest
                                I have a Panasonic LED TV TC-40A420U. The TV was given to me as an attempt to fix or throw out. I replaced the Backlight LEDs and now the screen lights up, but there is no image/display. If I play with the up/down buttons I can get the display to change from black to garbled. I can't get sound from HDMI but not sure of what input is selected. I have no remote control. When I connect a laptop to the HDMI ports it recognizes a Panasonic TV for display and sound output but I can't see or hear anything through the TV. This makes me think the mainboard is OK, but not sure if mainboard can...
                                03-17-2024, 10:14 AM
                              • ItepK
                                Panasonic TX-P42G30E green light blinking, no video, no audio
                                by ItepK
                                Hey everyone!
                                I've gotten this TV for free, neither have it seen a TV repair man, neither have it been opened before.
                                This post describes my entire troubleshooting process of this TV.
                                When I turn it on using the ON/OFF switch at the side of the TV, the light rapidly flashes green, then it stays on, but it does not react to any of the remote buttons, side buttons, and doesn't play audio.
                                I've taken the unit apart, and I've started to check some voltages:
                                • On the P11 connector, there is 15V DC only for a brief moment, then it goes
                                12-22-2023, 05:06 AM
                                GeForce RTX2080 Super Aero video gaming card issues help need
                                by sam_sam_sam
                                This is from my son’s gaming computer that at first had minor overheating issues when playing a very intense game with it causing the computer to crash or reboot
                                Then bough a new motherboard and a new computer case that a cooling system in it already installed also brought the cooling system for this video card but now the issue with it is that it randomly rebooted screen goes blank randomly and suddenly video freezing or started with video being there then blank screen and then the video comes back or it just stays blank for a while and then maybe it will come back but it...
                                05-07-2023, 08:12 AM
                              • jaroslav.psenicka
                                Lenovo Yoga 13 Panasonic, no video, fan OK, missing voltage rail (?)
                                by jaroslav.psenicka
                                I have a Lenovo Yoga 13 Panasonic here, when powered
                                • both fans spins (the sconds starts with a bit of a delay), no image neither on HDMI nor the display
                                • most voltage rails seem OK (see image below, red labels)
                                • resistnace to ground mostly seem OK as well (blue labels)
                                the only suspicious is the 0.0V rail (2nd from left, top row)
                                • the resistance to ground is rather low (1.9ohm)
                                • when injecting the voltage (1V), it consumes around 200mA, seems OK to me (?)
                                also tried new BIOS, no change
                                I can't find a schematics for the board - can some of you gurus look at the voltages?...
                                05-02-2024, 05:59 AM
