Philips 60PFL8708S/12 - QFU1.2E LA - Error code 53
  • Chungalin
    replied
    Re: Philips 60PFL8708S/12 - QFU1.2E LA - Error code 53
    But, what caused the first improvement in Maalobs TV? CPU reflow or NAND replacement? Since he did both things at the same time, it wasn’t clear to me which one was the root cause. I admit that I’ve chosen the NAND part first because CPU reflow is out of my reach.
  • Davi.p
    replied
    Chungalin you are wasting time/money,the problem is the same always, cpu soldering.
  • Chungalin
    replied
    Error 2 / 53.
    Thanks Maalobs. I have an XGecu TL866II Plus that can read/write these NANDs, but I don’t have a TSOP-48 adapter, so I’ve prefered to order an already programmed NAND for this chassis.
  • Davi.p
    replied
    Which is your symptom?
  • Maalobs
    replied
    I still have the dumps of all the flashroms from the TV, even the NAND which is too big to post in the dump-thread on this forum.
    Let me know if you need it, I can arrange an sftp link for you.
  • Chungalin
    replied
    Well, I just wanted to check that I get exactly the same log outputs in both ports than Maalobs. Also, I wanted to make sure that my mods on the standard serial USB adapter were working fine.
    I have ordered a programmed NAND and I’ll report results after replacement.
  • Davi.p
    replied
    Why you're trying to access standby ser.port? I think it has no useful info in it, i have tryed with a Chinese board theese days, st.by serial only prints few characters at boot and 2 char. at shut down. It is a the port of the st.by processor that has a simple software, not much to communicate..
  • Chungalin
    replied
    Originally posted by Maalobs
    I discovered that the standby processor was set to 57600 8N1.
    Thanks. I tried other lower speeds without luck, but not this one!
    I use a USB serial adapter with FTDI FT232BM IC and a Sipex SP213ECA IC for standard serial voltages. I disabled the second IC (Enable to GND), and changed FT232BM signaling voltage from 5V to 3.3V connecting VCCIO (p13) to its own 3V3OUT (p6).
    The problem is that I tried TXD-STANDBY first, and as it wasn't good looking (due to the speed difference you point out), I blamed my modifications of serial adapted, but after giving up with that port I tried the SERVICE port and it worked fine!
  • Maalobs
    replied
    Originally posted by Chungalin
    Is there any difference between those two serial ports? While I can get clear communication from TXD-SERVICE (with expected parameters of 115200-8bit-1stop-no parity-no flow control), I just get garbage from TXD-STANDBY. I assume that signal level is 3.3V in both cases.
    Yes, the levels are 0-3.3V TTL on both ports.
    It said in the service manual that the main processor was set to 115200 8N1, and by simply testing other speeds I discovered that the standby processor was set to 57600 8N1.
    I used a USB-to-TTL serial-adapter:
    https://www.adafruit.com/product/954
    This one with the blue casing from Adafruit uses an original chip, so the device works with the official Windows-driver.
    If you find one that's half the price or cheaper, then it's most likely using a pirated chip, which the signed drivers in Windows will detect and refuse to work with.
    The pirated ones still work in Linux, though.
    I learned this the hard way.
    I also got a 5-pack of small test hook clips with a male Dupont connector on them:
    https://www.electrokit.com/produkt/t...klamma-5-pack/
    I soldered a short piece of bodge-wire onto the relevant pads on the PCB and then hooked the test clips to the wires I wanted to listen on.
    I left the bodge-wires on the PCB with the ends tucked between a couple of layers of kapton-tape, ready for use the next time.
  • Davi.p
    replied
    check if there is a level translator like MAX3232 or others..
  • Chungalin
    replied
    The debug-port 1CV5 is unpopulated but I soldered in wires on TXD-SERVICE and TXD-STANDBY so I could monitor them with serial adapters.
  • Davi.p
    replied
    hulko don't hijack other one's thread with different issues.. open your own discussion
    sorry, i see R J's post now..
  • R_J
    replied
    maki and hulko, start your own threads that way you are more likely to get answers.
  • hulko
    replied
    Hello, sorry i'm new
    somebody can explein how i can activate the service modo on 60PFL8708S
    because i'd like to try to re-install the original software before the boot of TV
  • maki
    replied
    Hello
    I was wondering if someone encountered a blank SPI ?
    I have a 46pfl8008, it has 2 blinks on level1 and 53 on level 2.
    Recovery isn’t working.
    I’ve suspected the SPI (25p10) and because it’s the easiest chip to check.
    I’ve used this programmer
    https://www.ebay.com/itm/CH341A-Seri...53.m1438.l2649
    with a clip
    https://www.ebay.com/itm/Soic8-Sop8-...53.m2749.l2649
    To my surprise, the chip was totally blank – all FFs.
    Any ideas?
  • Davi.p
    replied
    And open up your own discussion,,this is already too fitted
  • amennone
    replied
    Hi, I have the same problem with error code 53 with Philips 55PFL8007K12
    Chassis / Version: QFU1.1E LA
    Power supply: FSP197-4FS01 2722 171 90676 REV: 01
    Panel: LTA550HQ19 Card
    mother: 3104 308 98314
    The TV is completely turned off.
    The voltages I read are 3v3s = 3v3 and STB = 3v1
    I reprogrammed the spiflash 7CT3 (M25P10),
    on pin 2 of connector 1M95 the power supply
    it has gone to a low logic level, from 3v1 to 0 volts.
    The 12 volt, now, is present,
    like the other feeds on the mainboard.
    But I get error code 53.
    I tried connecting to Hyperterminal at the service jack,
    I get this information (see attachment)
    I also enclose the Spi 7CT3 reading before programming.
    The trash, which I reprogrammed for SPI is for a processor,
    is a Fusion P240 FNP202-B1E32.
    Can this be the problem?
    Another question, why do I get this log with Hyperterminal?
  • Davi.p
    replied
    Amennone di plcforum giusto? Qui devi scrivere in inglese! Controlla su plc una disc. recente di Ottaviucci, il problema e' il processore..
  • amennone
    replied
    Salve , ho lo stesso problema codice errore 53 con Philips 55PFL8007K12
    Telaio / Versione : QFU1.1E LA
    Power Supply : FSP197-4FS01 2722 171 90676 REV : 01
    Pannello : LTA550HQ19
    Main board : 3104 308 98314
    Il televisore si presenta completamente spento .
    Le tensioni che leggo sono la 3v3s = 3v3 e la STB= 3v1
    Ho riprogrammato la spiflash 7CT3 (M25P10) ,
    sul pin 2 del connettore 1M95 la alimentazione
    è passata a livello logico basso , da 3v1 a 0 volts .
    La 12 volts , ora , è presente ,
    come le altre alimentazioni sulla main -board .
    Ma ottengo codice errore 53 .
    Ho provato a collegarmi con Hyperterminal al jack di servizio ,
    ottengo queste informazioni (vedi allegato )
    Allego anche lettura della Spi 7CT3 prima della programmazione .
    Il bin, che ho riprogrammato per la SPI è per un processore Fusion 77
    Mentre il processore sulla main è un Fusion P240 FNP202-B1E32 .
    Può essere questo il problema ?
    Una altra domanda , perche con Hyperterminal ottengo questo log ?
  • Maalobs
    replied
    Hi, and thanks for your very detailed and well thought-out blog posts about repairs, I found them both educational and inspiring.
  • ngml
    Repair of an LG split AC system indoor unit PCB
    by ngml
    I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
    This indicates an error in the communication between the outdoor and the indoor unit.
    The outdoor unit is fine, so the problem is the indoor PCB.
    The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
    I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
    Does anybody have the schematics of this board,...
    02-01-2025, 12:55 PM
  • nobbnobb1
    Bose Companion 5 - Unit Powers On then Cuts Off Shortly After
    by nobbnobb1
    Hi guys,
    Trying to salvage a Bose Companion 5 computer speaker system that powers off shortly after powering on. It's got a primary USB input (built in DAC) and an aux 3.5mm input. The USB appears to be the primarily source that tells the unit to power on (control pod LED goes green) as the unit has no power switch.
    When I first connect power to the unit, plug in the USB, it will play audio nicely for a minute before it drops out and the unit appears to go into standby (control pod LED goes red). It stays in standby and I cannot seem to power it back on without physically...
    02-03-2022, 11:14 AM
  • BC_TechForum_drb
    Missing enable on +5v sec pwr rail AMD Firepro D500-B/Mac Pro late 2013
    by BC_TechForum_drb
    Sub: Missing enable on +5v sec pwr rail AMD Firepro D500-B/Mac Pro late 2013
    Ref: 1/ MacPro6,1 Late 2013/A1481 MD878LL/A (3.5 GHz 6 Core Xeon E5-1650v2)
    Gfx-B: APN: 661-7548 PPN: 820-3533-A AMD FirePro D500-B 3GB Vmem
    2/ Figure 1 Gfx-D500-B Front Facing
    3/ Figure 2 +5v supply (zoom-in)
    Intro:
    While troubleshooting a Mac Pro(6,1) referenced above I discovered the +5v secondary supply did not stand up on the D500-B graphics card as a result of a missing enable signal. The +3.3v secondary rail was the only rail that did standup. I tried to perform...
    12-07-2023, 09:55 PM
  • Gjackson
    Air-conditioning unit power supply failing to power up
    by Gjackson
    Hi all, I managed to narrow down which PCB was causing my Haier AC to throw out an E7 error code (E7 indicates that the indoor unit and outdoor unit cannot communicate). I found that the outdoor unit power board which gives 5v and 15v to the outdoor unit module board fails to fully power up.. The power Led starts to fade in incredibly slowly and the 5v and 15v power buses jump around like crazy and never reach their required voltage. I unplugged the module board from the power board and the power board powered up fine! It had a steady 5v and 15v out and the power LED came on instantly and Bright....
    01-08-2022, 09:24 AM
  • Duranitron
    Asus x512dk rev 2.1 power on problem
    by Duranitron
    When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
    Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG)...
    11-26-2024, 10:22 PM
