SAMSUNG LE40S73BDX Distorted screen - VIDEO AVAILABLE
  • busigkille
    • Nov 2017
    • 21
    • Finland
    Could i please get some help troubleshooting this on?
    Video and pictures below. Sometimes screen is good and clear but mostly totally distorted.
    Video:
    https://www.dropbox.com/s/hlm3cddmhj...47.07.mov?dl=0
  • Unspun01
    • Jun 2011
    • 349
    Re: SAMSUNG LE40S73BDX Distorted screen - VIDEO AVAILABLE
    This may be a problem with poor solder connections of the large square QFP IC on your mainboard. You will need to use lots of flux, and re-touch each pin of this IC on the mainboard with a very fine tip solder iron.
    Reflowing with a hot-air rework station may work, but re-using the existing crappy lead-free solder may not be as successful as retouching each pin with fresh solder.
    Before attempting repair, you may try applying heat from hot air dryer over the mainboard before turning the TV on to see if any of the lines change or go away completely.
    • Chrissygizmo
      by Chrissygizmo
      02-10-2025, 12:33 AM
    • iZakre
      HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
      by iZakre
      Hello everybody!
      To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
      The thing is that I had installed TeamViewer and could log into the computer...
      02-19-2023, 02:27 PM
    • JunkmanJimbo
      Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
      by JunkmanJimbo
      Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
      No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
      Please help. Thanks in advance!
      08-12-2025, 11:45 AM
    • Kiberge
      Samsung LH82QENELGC/EN Help needed - Static line on screen
      by Kiberge
      HI guys!
      I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
      I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
      the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
      This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
      04-22-2024, 11:28 AM
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
