Re: Vizio M70-C3 Dark Spots
It was off, pictured left at calibrated for test, backlight=zero
do the same test again of backlight level zero.. i thnk this auto brightiness was on... if it was off then no need to do it
i said the test with channel signal not jpeg or s other.. areal signal or cable signal of program that the picture will change and moved time to timeLast edited by Diah; 03-01-2019, 04:07 PM.Leave a comment:
please upload photos as other members request. now start the hard workLast edited by Diah; 03-01-2019, 02:24 PM.Leave a comment:
OK, turned out the lights in the room and reduced the backlight to zero for 30 minutes. While watching, all dark spots are still noticable . Slowly increased the backlight from zero to 55, checking for spots while doing so and they remain on the screenLeave a comment:
waiting on your response of the second test i suggest at post 22Leave a comment:
Sorry Diah, just saw your response above.Leave a comment:
on the specification of the this TV there are full arrow dimming system. as other said. this panel are big the risk to take out with one person do high.
reading voltage don't work at all as its currents to dimming or turn off. if there was one burned then whole back light will be out and TV will never start.
the rest we can think what i said before.. but its much we can know more close with easy steps
1- make hard reset from service menu and check result
2- attached UHD learning full arrow dimming system put them on fat32 usb format and play them on the tv one by one until you can see the white one full White.
if no change please report to do other test
Is that the tests you are asking for?
thank you,
KentLeave a comment:
Hello Diah, I restored the factory defaults and picture still the same. Next, I copied the black and white jpg's to a thumb drive and played them on a slide show for a couple minutes. I could always see the shadows when the white screen played.
thank you,
Kent
this test should be done with Cable or areal signal. not USB or HDMI signal.
please turn off the light of your room ( in case the TV set had build in Light room sensor ), and set the backlight level of the TV to Zero. keep it on and watching any things for at least 30 minute. then turn the backlight level setting to up slowly .. but not to full and check the dark spots at which level there no spots.Last edited by Diah; 02-26-2019, 09:46 AM.Leave a comment:
:-) very wise on the "last thing to do" especially as a "first effort". Ultimately, I kind of doubt that to fix this set, there will be an easy / board solution.Leave a comment:
You have 32 LED strings, thus 32 power MOSFET's to control the current for each LED string. Using LED tester to look for open LED will be the easiest but you will have invest in the tool. Taking the LCD panel apart will be the last thing you want to do after all the testings are done.
https://www.shopjimmy.com/vizio-1p-1...led-driver.htm
https://www.shopjimmy.com/foxconn-s7...-16-strips.htm
Based on picture of the LED strip from SHOPJIMMY, it has 160 LED's total that I can see, so it means (if they are grouped equally) 5 LEDs per zone, you can use two 9V batteries connected in series to form 18V source than put 150 Ohms resistor in series to limit the current to about 30 mA for testing each set of LED.
5 LED's with current limit of 30 mA so total Vf of 5 LEDs = 2.70V x 5 = 13.50V.
18V - 13.50V = 4.50 V, 4.50V @30mA = 150 Ohms.
BTW, can you read the P/N of the LED driver IC U101, U102?Last edited by budm; 02-25-2019, 10:55 PM.Leave a comment:
Some say it's dirt n dust on the diffuser sheets.Leave a comment:
thank you,
HI Guys, thank you very much for the great feedback, much appreciated! Appears I should focus on a couple areas, LED's and the local dimming aspect of the TV.
I think a good place to start is where BudM recommends, take off the back of the TV and snap some shots of the entire back, then of each board up close. I'll try and get a peek at the LED's as well without tearing the whole thing down. I have watched and studied several YouTube video, including ShopJimmy.com of replacing LED's on a 70 inch TV and not ready to jump there yet. :-)
I think I understand Diah's post, but not sure what I am looking for or the result of the test. I did the following:
I went into the System settings and restored the TV back to factory defaults, is this what is meant by a hard reset? In my world, a hard reset is unplugging and plugging back in, which I also performed.
Now, his next step, put on a thumb drive and play the white and black back and forth until the white screen is all white?? and if it nevers goes to completely white?
Oh, one other question, the Vizio site said this TV does have local dimming in 32 areas. So I looked on ShopJimmy.com and I see an LED driver board with 32 components. Does this board control the local dimming aspect of the TV? Seems logical. So if the LED's are all good, maybe need a new LED driver board..sorry for the long winded return, but ya'll had great thoughts.!!Leave a comment:
if no change please report to do other testAttached FilesLeave a comment:
since there seems to be a lot of areas... my guess is that you have been running the set "full bright" resulting in heating of the diffusers around the led resulting in some "burning" which has made them less transmissive. If the actual leds had problems, odds are high that the set would have shut down due to some form of voltage / current limits being set.Leave a comment:
If it has local dimming then the circuit controlling it may be faultyLeave a comment:
Please provide the pictures of the whole backside of the TV showing all the boards, then good clear straight shot of the whole board of each board.Leave a comment:
by YanlebI have a Vizio M70-D3 4K with a dark spots backlight issue. It is using the Y8387248A backlight driver board.
On this model each of the 64 transistor powers 2 LEDs. Using my TKDMR TD3H backlight tester I've determined that the backlight LED strips were the issue, and the backlight driver board was just fine. Some LED pairs required 5.9 volt at 155mA, some required 9.5 volt and some were completely open.
I've removed the LCD panel and once the LED strips were exposed I've tested them again by connecting my LED tester directly on the test pads. To my surprise all, I've... -
by JaviercityHello there i have a Sharp 80" LDC that has some dark spots in the middle of the screen, since its a 80 inch need another person so hang it on the wall or move it around, so i hope the collective wisdom can help me to determine what is wrong, I've been doing some research online and there is next to nothing about this TV, i tend to believe that the spots are due the back films/diffuser sheets, that are bit dirty, or perhaps one or two LEDs being burned, but what throws me off is that the dark spots are more noticeable when the image is bit dark like night scenes, and also noticeable when...06-13-2023, 12:02 PM
by howardc64Problem
Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
Model & Board Pics
Conflicting Spec
Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
https://www.shopjimmy.com/vizio-gj-2k1... -
by RozpHello Everyone,
This is my first post so I will try to be as precise as possible without making this post too long winded. Unfortunately I don't have pictures of the original problem but I included images of the TV internals.
I have a Sharp 70LE660U. The problem started a few months ago with the bottom row looking out of sync and was dark on the left side and then fading to transparent on the right side. Shortly after, a dark cloud appeared in the center of the screen. The dark cloud started small and shaded but the image was visible. It also affected the menu area.... -
Assuming...7 Photos - Loading...
