Best Buy / Sharp LC-32LB261U backlight failure
  • asel51
    • Jan 2019
    • 5
    Hi, I picked up a free Best Buy / Sharp LC-32LB261U LED TV from Craigslist. The LED back light had failed. I found that the set uses 3 LED strips which have 7 LEDs per strip, and the 3 strips are driven in parallel by the Power Forest PF7903B boost converter. During troubleshooting, I found that the boost converter would startup but be shut down by its over voltage protection circuit as the output voltage spiked to around 42V.
    From the schematics and product brief, the feedback voltage on the PF7903B is 240mV and the 0.192489 ohm current sense resistance in the LED return path (5 resistors in parallel; 2 @ 0.91 ohm & 3 @ 1.0 ohm in parallel = 0.192389 ohms) indicated that the full load current should be 1.247 amps.
    To test the converter, I used a 27.5 ohm 100 watt resistive load and that allowed the converter to run and produce 33.3 volts across the load and 1.246 amps through the load. That confirmed that the boost converter / current regulator was operating correctly.
    Next, I used a bench power supply to test and make sure the LED back light assembly was bad before removing the panel. With 35 volts and the current limit set to 500 mA, I could get no current flow through either of the VLED+ to LED- connections. That confirmed that the LED back light strips were bad.
    After disassembly, I found 3 strips with 7 LED per strip, labeled as Evertop LBM320P0701-FC-2. I tested each LED individually with bench supply @ 2.7 volts and current limit set to 400 mA. I found a total of 5 failed LEDs; 3 on one strip and 1 on each of the other 2 strips. Replacement strips are available on EBay, but before ordering, I wanted to try and replace the bad LEDs on each strip. (As an aside, the reflector in the set is paper and glued to the chassis which makes removing it without damage almost impossible. Very poor design with regard to serviceability.)
    Does anyone know what the LED vendor and part number used on the LBM320P0701-FC-2 strips might be? These appear to be around 1.25 watts based on the 1.247A full load current into the parallel connected strips. This means each strip should have a current flow of 416mA and assuming a forward voltage drop of 3V, that would be 1.247 watts per LED.
    If you know what vendor & part number the LEDs might be, please let me know.
    Thanks,
    Re: Best Buy / Sharp LC-32LB261U backlight failure
    You should check the dimension, and also remove the LED to find out what kind of foot print it has.
    BTW, do you have the schematic?
    https://www.shopjimmy.com/sharp-pltv...-32lb261u.htm#
    That is crappy design using LED strings in parallel so if one string goes open circuit the other string will have the total current flowing through it and that will cause the failure of the remaining string since it is constant current drive setup.
    • Unspun01
      • Jun 2011
      • 349
      Your math looks good.
      But 416mA sounds really high for an LED? Maybe that's why they burned out? I thought something around 200mA is good enough? Any comments? Maybe these need to have some resistance in-line to drop the current and protect the LEDs?
        They like to drive the LED at the Max and beyond the spec so they will fail so you will buy another TV.
        You can reduce the current by turning down the backlights level or modify the circuit by changing the current sensing resistor.
        • asel51
          • Jan 2019
          • 5
          Yes, I have the schematic. I have removed the strips and the LED lenses and will remove the LED chips and measure the package outline and look at the pin-out (pads). I'm sure I can find suitable replacements at Mouser or DigiKey or via EBay from China. Yes, this is a very poor design with the LED strips driven in parallel. You are right about one failing which increases the current in the remaining strips or strip until they all fail. Too bad designers and manufactures don't take a conservative approach to the design, but a limited lifetime product does force new sales. When I reinstall the LED strips, I may play with some 3M double-sided thermally conductive tape to better heat sink the LEDs to the chassis, or maybe put some thermal paste under the strips.
          • npielawski
            MacBook Pro late 2016 (820-00239) with multiple failure modes.
            by npielawski
            I will just preface all this by saying that I have a fairly technical background but have never attempted SMD electronics diagnostics and repair before, I really like the idea and want to learn.
            I have a MacBook Pro late 2016 that died maybe four years ago. Over the course of 30 seconds, it got slower and stuttered, until it froze for a second and died. No click from the trackpad anymore, nothing. I started getting interested in electronics repair and decided to give it a shot, so I opened it, removed the battery (one cell was puffy), took out the motherboard and experimented with...
            10-15-2025, 01:53 AM
          • Geeker007
            Please review my ESP based WLED controller board for WS2815 12V LED Strips - New to electronics.
            by Geeker007
            I'm designing an ESP-based WLED controller board for WS2815 12V LED strips, with a primary focus on energy efficiency.
            To minimize power consumption, my goal is to completely shut down the system when the LED strip is turned off.
            However, the current buck converter powering the ESP module draws about 8 watts even when the LEDs are idle, making it unsuitable for low-power operation.
            I am using below components:
            • Buck Converter: TPS562201 (12V → 5V regulated)
            • Microcontroller: XIAO ESP32-C3 (with built-in USB-C)
            • LED Strip: WS2815 (12V digital LED strip)
            • Switching
            06-29-2025, 05:20 PM
          • caspian
            Causes of Failure After Buck Converter Repair in Laptop
            by caspian
            Dear members,
            Recently, I watched this nice video:
            www.youtube.com/watch?v=XBAn2Ck8GeE
            I have experienced such a failure many times in laptops.
            He replaced the Mosfets and the controller of a buck-converter in one go. But then after powering the laptop on, the new Mosfets burned again.
            What are the popular causes of the repair failure in this video?
            note: after removing the coil, he measured that the circuit is not shorted after the coil. only the circuit before the coil was shorted.
            03-28-2022, 12:57 PM
          • edugimeno
            Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
            by edugimeno
            Hi There!
            I'm trying to help my friend who owns a restaurant be just bought.
            He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
            It's stuck using, I guess, the 2 sided tape that comes with the strip
            The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
            09-05-2024, 09:34 AM
          • MarkC1970
            Sharp LC-40FG2241KF failed LED boost converter
            by MarkC1970
            My Sharp LC-40FG2241KF with a TP.MS6486.PB711 mainboard has a failed LED boost converter. The FET (AOD458) was s/c and the rectifier/blocking diode (SR320) was also s/c. Both were changed as well as the input and output caps.
            On powering the TV we get 55v on the LED rail. Immediately we take the TV out of standby the controller (OB3350CP) starts to trigger the Gate of the FET and it dies again (with smoke no less). The inductor is incredibly low resistance at 0.09 Ohms and I suspect it is short and so the FET is directly grounding the 55v supply, but I may be mistaken. Scoping the...
            02-15-2022, 06:47 PM
