Sony XBR65X850C and XBR65X850C flash copy success?
  • MASTER_TECH_101
    • May 2018
    • 12
    Anybody had any luck coping flash chips on those main boards?
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8321
    Re: Sony XBR65X850C and XBR65X850C flash copy success?
    How come? Is it dead, you flashed the eeprom and still nothing is working? Can you attach a high resolution picture of your main board, so we can see what you did or tried to do?
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8321
      read that: https://www.badcaps.net/forum/showthread.php?t=73533
      • Ihandyrepair
        4 red flash led 65X950G boot Sony and android logo but then black
        by Ihandyrepair
        HI guys
        I got here a Sony 65X950G - I tried to find any repairs guides for this model but not many online
        here is the issue
        I have Sony and android logo. but then 4 led red flash lights front of the tv
        I have 3.3v ref. 12v reg then T con 12v when I press the power on button
        but then I get black screen and 4 red flash light at the front LED
        but I get 3 led flash on the LED driver board.
        I check that few X900F or C YouTube repairs, seems that if you have 4 led red flash it could be due of LED black light error
        so I tried...
        07-11-2024, 01:45 AM
      • Valtekken
        Lenovo IdeaPad 3 15ADA05 (model name 81W1) - Trying to flash the correct serial number, machine type and UUID without success
        by Valtekken
        Specs:
        • CPU=AMD Ryzen 5 3500U
        • GPU=(integrated) Radeon Vega Mobile
        • RAM=8GB (2x4GB, a 4GB set is soldered), DDR4; 1x4GB Ramaxel, 2400MT/s, RMSA3310MJ86H9F-3200; 1x4GB Micron, 2400 MT/s, no part number (soldered)
        • Storage=512GB, NVMe SSD, hfm512gdhtni-87a0b
        Hello everyone.
        My issue isn't massive, but I'd like to get this solved since I'm trying to fix a friend's laptop.
        A botched BIOS update by Lenovo bricked this laptop, so I used my BIOS programmer to reflash the BIOS on it and saved it from an early demise. All is good now, but the BIOS reports the S/N, MTM and UUID...
        09-10-2025, 04:14 PM
      • ekozeko333
        by ekozeko333
        🧠 What I’ve Done So Far
        Flashed...
        06-21-2025, 02:48 AM
      • corrize
        Nikon D800 camera - flash don’t work and capacitor don’t charge
        by corrize
        Hello, I'm stuck in troubleshooting…
        The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
        In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
        When I press the flash button, it's detected by the system, flash icon appear on LDC display....
        10-01-2022, 10:02 AM
      • protonusr22
        Sony 49XH9505 four flash of death
        by protonusr22
        I own a Sony 49XH9505 123.2cm Smart Android 4k quite new bough brand new in 2021. Just after the warranty has expired it had died on me.
        The symptoms are the following: right after turning on backlight turns on and this loading screen appears, than the display turns off and the red led flashes four times.
        Any idea how to fix it or if it at least fixable? Does this sign related maybe some SoC/DSP and its circuits or just some simple power supply issues somewhere ?
        Many thanks in advance,
        02-07-2024, 08:10 AM
