Samsung UN55H6350 no image, has sound -Bad T-con or Panel?
    • 12323
    • U.S.
    Re: Samsung UN55H6350 no image, has sound -Bad T-con or Panel?
    Yep, good idea to test everything you can on tcon, when dealing with used parts it's always possible to get a bad one, try to find a good tutorial on testing.
    • kudalski
      • 12
      I'm ready to conclude that I have a bad panel (screen)
      Problem started when customer saw a couple of horizontal lines showed up in the image than TV is out.
      When try to turn TV ON; red led power blink, sound only.
      Disconnecting power line to motherboard. LED's comes on (of course LED's working on the fly, no motherboard control). so, they are ON, full power.
      Connecting back power to motherboard. Disconnecting either of the ribbon cables to LCD = LED's all respond to power and all come ON, but no image.
      Connecting both LCD ribbon cables back to T-CON = again a flicker of LED's then out.
      I think I've seen this problem before, and it sounds like I have a bad LCD (Panel / screen)
      can anyone confirm? thank you.
        • 12323
        • U.S.
        Try heating your mainboard with a hairdryer be sure and hit the capacitors on there too, see if tv comes on or anything changes.
          What Voltages testing have you done on the T-con board?
          • NJ_TV_Computer
            • Aug 2019
            • 3
            I am kudalski, now using my repair shop name. this what I will be using from now on.
            Voltages are all there on main, power supply and T-Con. T-Con was replaced just for the heck of it, same problem. I just wanted to confirm it is my LCD and I feel 99.9% it is.
            • neilc6
              • Nov 2015
              • 1550
              White on both sides with ribbons connected one at a time would seem like a panel fault on both sides https://www.badcaps.net/forum/showthread.php?t=50646
                So you are saying the T-CON board VGH, VGL, AVDD, VCC Voltages are all correct? The panel may have shorted components on the Tab bonding board, I.E. shorted caps, or COF.
                • budwich
                  • Jul 2015
                  • 3097
                  X2 ^ especially if you are seeing a clean white on either side with only one tcon to panel connected. If is likely an issue with some component at the bottom edge board. As suggested check the various hopefully labelled voltage at the tcon.
                  • wolf1976
                    samsung ue40d6100 has no backlight no sound and image
                    by wolf1976
                    hi to all
                    on the above model of samsung i have the faults i have told already on the title
                    iI have standby i can from remote control open and close the tv and it seems reacts the tv when i press someone button from remote control but and with the help of a torch i cannot see anything image on the tv and no sound
                    any idea from someone what can i measure so i can find the problem ?
                    the power supply is the bn44-00482a i cannot find the service manual so i can test if the leds are ok and maby these are the cause of my problem
                    11-17-2024, 01:02 PM
                  • rimwall
                    Sony KD-65x7500D - double image - Tcon or Panel?
                    by rimwall
                    This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
                    I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
                    11-18-2025, 02:09 AM
                    09-07-2024, 05:50 AM
                  • Ierwin
                    by Ierwin
                    05-13-2025, 03:31 PM
                  • ChaosLegionnaire
                    by ChaosLegionnaire
                    09-13-2022, 09:02 AM
