Vizio P55 C1 Boot loop
  • evox45
    • Jan 2019
    • 13
    Hey guys, I'm new here but I'm hoping someone can help me with my tv.
    Model: Vizio P55-C1
    My issue is the tv turns on, I see the Vizio symbol but after that, the screen seems to go greyish black than after about 10-15 seconds the tv reboots. I have unhooked my receiver from the tv. I've tried unplugging and holding the power button for a few seconds. Sometimes if I'm lucky the tv will work and it seems to work well until it is turned off again. I'm not aware if the tv did a firmware update or anything, to my knowledge no. I did read another thread about a different model number. He got a black box sent to him so he could do a firmware update. Not sure if anyone has input but id greatly appreciate it. Thanks in advance.
  • nomoresonys
    • 12276
    • U.S.
    Re: Vizio P55 C1 Boot loop
    First thought is mainboard issue, do you have a multimeter for testing power supply voltages?
    • evox45
      • Jan 2019
      • 13
      I do yes.
      • nomoresonys
        • 12276
        • U.S.
        Test all pins on connector from mainboard to powerbard on powerboard side, all boards connected. Test in standby/plugged in but off, then apply power report both conditions, example: pin 1 bl-on=0 volts standby and 3.3 powered on, report results for every pin. How to video in my signature below.
        • evox45
          • Jan 2019
          • 13
          Thanks for the help, I guess I jumped the gun here and apparently this tv came with extra warranty when I bought it from Costco. I'm currently waiting to hear back from them what they want to do with it as I live out of town and the contract says as long as the tv is over 40 inches they have to send a repairman. If the repairman can't fix it apparently they just cut me a cheque. If this is the case I'll definitely open it up and maybe be able to fix it if he cannot.
          • evox45
            • Jan 2019
            • 13
            Ok, so they wrote me back and the tv is not worth the time apparently. I'm willing to test connections to see if it's fixable. The pins you speak of are super small, hopefully, I will be able to test these connections. The only thing that wont work is having the tv off or on. It seems like the tv powers on and off and I can't seem to stop it. I'll provide some pictures if that helps things.
            https://imgur.com/a/P94hhOk
            • budwich
              • Jul 2015
              • 3097
              so they are refunding your money and leaving the set with you?
              simple first test would be to disconnect, one at a time, the cable going from the tcon to the panel (while not powered) and then see if this changes how the tv responds, what happens with the display and go from there.
              • evox45
                • Jan 2019
                • 13
                Yep, not sure why but it works out well for me. I think I figured it out! When I disconnect this (see picture) the display turns on (I've tested this about 10x) Does anyone know what this is?
                https://imgur.com/a/hgkacpy
                • evox45
                  • Jan 2019
                  • 13
                  So that one plugs into main display board. I'm going to plug something into this and see if the tv plays Netflix or something. At least it looks not very expensive?
                  • evox45
                    • Jan 2019
                    • 13
                    Ok, so everything seems to be working. The picture seems a bit choppy, and it doesn't seem to be telling me the definition that it's displaying in. Also randomly the tv will restart but doesn't seem to be a timeframe just seems random. Also after the tv is turned off then on it seems like it loses its programming and needs to be set up again.
                    • evox45
                      • Jan 2019
                      • 13
                      So some research says that this is the wifi module for the tv. Not sure as to why this is causing the tv to get stuck in a boot loop when it is turned on.
                      • budwich
                        • Jul 2015
                        • 3097
                        I think there is "logic" behind that... as a number of "help posts" in various threads first ask the OP to try disconnecting the wifi module to see what happens. I would think that like most things computer that if the operating system gets "hung" trying to communicate to components / networks during its setup / startup, the system may / does become "sick". Other may be able to direct you more but perhaps the module has an issue itself. If the tv starts without it, are you able to get into menus and see what is happening with some of those... in particular those dealing with networking?
                        can you post a picture of the display that shows the "choppy...".
                        • evox45
                          • Jan 2019
                          • 13
                          To be honest it may have been Netflix slowing down. I'll see if I can find some local content to play. Do you think that plugging in the wifi module to the board after the tv has started would be an issue?
                          • evox45
                            • Jan 2019
                            • 13
                            So I just did a factory reset and after that, the tv took a firmware update via ethernet cable. After the update, I plugged the wifi board back into the main board and the tv is working again. I'm guessing a bad firmware update in the past caused some sort of issue between the wifi board and the main board. I'm hoping this helps others in my situation although I won't write this off as fixed until I use it a bit more. Thanks to budwich and nomoresonys for help. Much appreciated.
                            • nomoresonys
                              • 12276
                              • U.S.
                              Nice work, believe I have seen this before, yes I think your analysis is right on.
                              • evox45
                                • Jan 2019
                                • 13
                                So maybe this isn't the place to ask but is there any reliable TVs these days? I like Vizio because bang for the buck you can't beat them but considering this tv got very light use and screwed up I may look for a different brand next time. I have a sony LCD that has worked for close to 15 years now with daily use and no issues but I'm not sure what the track record is now. Any suggestions?
                                • captainKKK
                                  • Sep 2018
                                  • 287
                                  • nomoresonys
                                    • 12276
                                    • U.S.
                                    I have a sony lcd from 2009 going strong, only ever needed a firmware reapply, samsung seem to be the ones you see here and elsewhere that always need fixing. Also have a sharp lcd from 2007, on all day as monitor, never a problem.
                                    • evox45
                                      • Jan 2019
                                      • 13
                                      I might check out what Sony has to offer the next time around. Thanks again for all the help.
                                      • NolesFan
                                        Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                                        by NolesFan
                                        Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                                        10-24-2024, 06:36 PM
                                      • Takeatry
                                        Yet another Samsung QLED Boot Loop
                                        by Takeatry
                                        Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
                                        10-04-2024, 02:57 PM
                                      • blaster_
                                        Samsung UE49MU6105K - boot loop, horizontal lines
                                        by blaster_
                                        Less than a year out of warranty, samsung UE49MU6105K craps out, they've got this designed obsolescence down to an exact science of self destruct when out of warranty...
                                        Screen started to show horizontal lines and ghosted image at the bottom, then turned off by itself. Did software update, to no avail of the line problem, and got a boot loop after some minutes of watching TV. This boot loop will turn on the backlights for some seconds the sound comes on, the image will turn dark very fast and then it reboots again. Pressing power button will not put it on standby. Disconnecting...
                                        06-22-2022, 05:19 PM
                                      • torchzack
                                        Samsung 55" TV - Boot loop but sometimes works fine - UE55MU6470U
                                        by torchzack
                                        Hi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
                                        I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
                                        Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't...
                                        08-28-2023, 07:42 AM
                                      • Daniel Larsson
                                        Firmware file for LG SK10Y Soundbar stuck in Please wait loop needed
                                        by Daniel Larsson
                                        My LG Soundbar, SK10Y, has somehow ended up in an endless "PLEASE WAIT" loop and I am now starting to suspect that the firmware is causing this, and I can't manage to connect via the app to push a new firmware in as it never really starts.
                                        I can trick it to start via HDMI ARC and it actually starts up, flashes OPTICAL and then goes to ARC where the sound (including sub) is perfect, but the white led indicator keeps blinking and after 20 seconds it says "GOOD BYE" and shuts down.
                                        During these seconds the function button is not working...
                                        08-13-2025, 10:29 AM
