Hisense ltdn40d36eu
  • Nawual
    • Jul 2016
    • 65
    • Spain
    Hisense ltdn40d36eu
    Hello.
    We have this tv model ltdn40d36eu that only show the logo when turn on and nothing more.
    It has this main TP.SIS231.PT85, i think that it can be fault of eeprom but i dont know much about that problem.
    Any idea or help?
    Thanks and apologize for my english.
    Regards
    Re: Hisense ltdn40d36eu
    As in any electronics troubleshooting, you need to at least do the visual inspection and Voltage testing first.
    • Nawual
      • Jul 2016
      • 65
      • Spain
      Thanks,i did it, and every voltage is ok on power supply.
        So you are saying the control signals (PS-ON, BL-ON, DIM) are all good?
        • Nawual
          • Jul 2016
          • 65
          • Spain
          Hello again. After measuring all tensions. I came to the conclusion that the error was software. And I got to repair the tv.
          I explain how I did it and I leave photos and the bin file that I used.
          I located the eeprom memory which is a winbond 25q64fvsig next to the crystal oscillator. I unfolded it and read the content. I saved it on the pc. And I erased the memory, writing the new bin file. I checked and everything was correct. I soldered the IC back to the main.
          I turned on the tv, and it worked perfectly.
          Regards!
          • Nawual
            • Jul 2016
            • 65
            • Spain
            I forgot the pictures and the file
            • aarty
              • Aug 2012
              Hi there,
              I too have the same problem as you have and I also think it is the eeprom.
              I ordered the CH341A to program the chip but it doesn't work for me. I have been following tutorials on youtube but still unable too.
              My tv is a Brauhn but uses the same board as yours.
              Just wondering how you did it?
              • Nawual
                • Jul 2016
                • 65
                • Spain
                Hi,I used this model EZP2013 to program it.It's work for me
                • neilc6
                  • Nov 2015
                  • 1550
                  It is better to replace the eeprom with a new one than just erasing it and reprogramming it.
                  • Robinsosa
                    • Nov 2013
                    • 19
                    • kenya
                    TV Model: Hisense LTDN40D36T
                    Flash memory GD25Q64BVF
                    I had a similar problem.
                    Hisense logo stuck and then reboots.
                    Remove the flash memory, erase it and reprogrammed it with the bin file supplied by
                    Nawual. It worked perfectly.
                    Thanks Nawual for the firmware.
                    • P Smith
                      • May 2008
                      • 5
                      Re: Hisense ltdn40d36eu - FIXED !
                      Thank you for the info and FW [?] file - fixed my TV, same model. In exchange to your courtesy I'd like to add some relevant info from my case.
                      The TV has different chip: A1423 / 25064SIG (cannot define the mfg).
                      I did use a programmer SuperPro 3000 by Xeltek with SOIC-8 adapter.
                      A type of the chip been selected as Winbond 25q64.
                      The chip was protected, so I'm forced to remove protection (S3000 SW allow to un/protect the chip), then erase and programed it.
                      Verification failed - ConfigFail; so I did restore its protection and then Verify passed OK.
                      TV up and running with new BIN content, but a language was set to Spanish
                      Changed it, no big deal, scanned RF, found all stations - all is good!
                      I did try to compare bin files, but found those have too many differences.
                      If someone know how to mount the bin, to read its content as folders/files, if it has some structure to do that, please tell here.
                      • SidneyCanadas
                        93C46 and 93C56 EEPROM
                        by SidneyCanadas
                        I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
                        https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
                        Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
                        06-14-2023, 01:16 PM
                      • Teban1306
                        [REQUEST] ThinkPad T14 Gen 1 (20S1) - Custom Boot Logo Modification
                        by Teban1306
                        Hello everyone!
                        I hope this is the right section for this request. I'm looking for help to modify the boot logo on my ThinkPad T14 Gen 1.
                        System Information:
                        • Model: Lenovo ThinkPad T14 Gen 1
                        • Machine Type: 20S1S4E600 (Intel i7 variant)
                        • Current BIOS: N2XET42W (1.33) - Latest version
                        • BIOS File: n2xuj25w.exe (12.98 MB) - Downloaded from Lenovo support
                        What I'm trying to achieve:
                        Replace the default "LENOVO" boot logo with a custom image during POST.
                        🔧 What I've tried:
                        09-14-2025, 11:49 AM
                      • NYKing
                        Hisense TV 32D33 - Replaced EEPROM, now menus have no text
                        by NYKing
                        The TV initially had a steady (not flashing) red standby light but did not turn on when power button was pressed. I tried all the usual “fixes” but nothing worked. TV would not turn on. After researching the issue, I concluded the cause was a bad EEPROM chip. I ordered the appropriate chip from ShopJimmy:
                        https://www.shopjimmy.com/hisense-32...hoCOcUQAvD_BwE
                        I took off the old chip using my hot air station and soldered on the new chip. I tested...
                        10-07-2021, 05:06 PM
                      • USmechS
                        Hisense 65H6570F Logo shows then turns off
                        by USmechS
                        Hello everybody,
                        I had this Hisense TV since November 2019 (Bestbuy Blackfriday special). Couple of nights ago my dad turned it off normally. In the morning it does turn on, shows the Hisense logo, then the LED light flashes and it turns off. It remains in the same state.
                        Things I have done:
                        A. Plug it off and on.
                        B. Plug it off, pushing the power button for up to 2 minutes, plug it in.
                        C. Contacted the customer service, They sent me a firmware update, with the file name:
                        upgrade_loader_no_tvcertificate.pkg
                        The zip file has this...
                        04-25-2022, 03:06 PM
                      • Verlengsnoer
                        Bios splash/logo change
                        by Verlengsnoer
                        at firs, i hope this is the right place to post my question.
                        Im looking for a tool to change the bios logo.
                        everyone knows when you turn on your laptop/pc you will see the manufacturer logo like lenovo, hp, dell...
                        i know that HP has a build in option to change the splash logo.
                        but i want to change the manufacturer logo to an own logo.
                        I try'd Change Logo 5.0, but when i make a backup of an laptop and edit the logo and flash the editted version back on the laptop the logo diddnt change.
                        10-28-2022, 09:52 AM
