Sony KD49X8005C Assistance Required Please.
  • Stevie406
    • 59
    • United Kingdom
    #41
    Re: Sony KD49X8005C Assistance Required Please.
    Originally posted by Diah
    be aware always. LED testing with just they turn on not enough. as each led had build in diode opposite to the LED light to limited the current. so led turn on but the diode shorted or some time open too
    Thank you, I will add this information to my notebook for the future.
    Share your knowledge with others,
    And the gesture will be returned tenfold.
    • Diah
      • Feb 2013
      • 6437
      Originally posted by Stevie406
      I Test the LED+ from the socket with plug disconnected, at power up 93.44v
      And LED- 0.23v
      I'm not sure I have taken the correct measurements you wanted.
      again wrong.. from now on never never disconnected the LED socket from PSU. until you see all strips turn on when tv power on...
      also read the value again on the socket you have only 2 pin - and + this you need to read
      • Stevie406
        • 59
        • United Kingdom
        #43
        Ok . Another note for my book. Thanks
        • Stevie406
          • 59
          • United Kingdom
          #44
          LED+ 93.4v - 95.3v
          LED- 13.8v - 15.3v
          • Diah
            • Feb 2013
            • 6437
            why you put the - on chassis ? leave the - on - and + on +
            just read direct from the socket
            • Stevie406
              • 59
              • United Kingdom
              #46
              I'm getting 1.6v to 0.14v
              Is this correct?
              I tested a few times with similar results.
              The 1.6v is just for a fraction of a second, then it settles down to 0.14v
              • Diah
                • Feb 2013
                • 6437
                no... you have one raw flash on... lol... how it come 1.6.....start testing put your voltmeter on Diode Option. and start test diode LED you can make references from reading value of working one each test should be in tow opposite direction of - +
                • Stevie406
                  • 59
                  • United Kingdom
                  #48
                  I have tested all of the LEDs with the meter in diode mode.
                  All LEDs test from 2.53v to 2.51v.
                  All LEDs have OL with leads reversed.
                  • Diah
                    • Feb 2013
                    • 6437
                    ????? test as diode not volts.... tv must be off .. show me how you test with yours DM
                    • Diah
                      • Feb 2013
                      • 6437
                      any one from English speaker counties please help him to test which LED fault.
                      • Stevie406
                        • 59
                        • United Kingdom
                        #51
                        I will take some pictures of how I am testing LEDs. And upload in a few minutes.
                        Sorry if I am doing this wrong.
                        • Stevie406
                          • 59
                          • United Kingdom
                          #52
                          The first picture is with the Black probe on the negative rail and the Red probe on the first test point after the first LED.
                          With the meter on Diode mode, I get a reading of 2.515v.
                          This LED lights up.
                          When I reverse the leads, the meter shows OL
                          The 3rd picture shows testing the second and all other LED on this string.#
                          I place the Black lead on the test point before the LED and the Red probe on the test point after the LED.
                          The meter shows 2.525v
                          This LED lights up.
                          When I reverse the leads the meter shows OL.
                          All LEDs are about the same value.
                          I'm so sorry if I have misunderstood your instructions.
                          • Diah
                            • Feb 2013
                            • 6437
                            This LED lights up.
                            This LED lights up.
                            this test you mentioned above only on the string which flash on at start up right ?
                            if yes do the same to all other string led
                            if not the one string we talk on which it flash once at start up wrote here its not
                            • Stevie406
                              • 59
                              • United Kingdom
                              #54
                              I have tested ALL LEDs on ALL the strings, and the test results are almost the same.
                              There is only 0.01v of a difference between ALL the LEDs.
                              Just for future reference, Were you expecting to see at least one of the LEDs with a different reading from all the others?
                              • Diah
                                • Feb 2013
                                • 6437
                                however. please inspect and re solder all joint point of string and socket.. dpnt left any with out resold them
                                • Stevie406
                                  • 59
                                  • United Kingdom
                                  #56
                                  Ok, I will re-solder all connections, and re-test again Tomorrow, I'm getting pretty tired, and I don't want to make a mistake.
                                  Thank you for your patience, and assistance, I really appreciate everyone's help.
                                  • Diah
                                    • Feb 2013
                                    • 6437
                                    i am off.. i don't believe on yours DM . if you have the easy one of diode test option with beep tone you had found the fault led.. please other help.. i keep my eyes on this post
                                    • Diah
                                      • Feb 2013
                                      • 6437
                                      TV LED BL test should be as following
                                      when the DM on Diode mode when you put the probe and the LED light on, the DM as my will read nothings. then reserve the probe the DM will read value as ziner Diode between .650 -.756
                                      if the DM peep ton or read less than .500 mean this ziner shorted , if the DM no peep or no value read it mean its OPEN. and both above state are fault which make this err.
                                      • zomi
                                        • Nov 2011
                                        • 509
                                        #59
                                        All the wire connectors solder these direct
                                        either new wire or just snip the plugs off and solder
                                        i have circled them for you
                                        • Stevie406
                                          • 59
                                          • United Kingdom
                                          #60
                                          Ok. 10 Minutes and it will be done.
                                          Thank you..
                                          • Carlos#2003%
                                            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                            by Carlos#2003%
                                            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                            02-15-2024, 07:52 PM
                                          • dkneyle
                                            Sony KDL-46HX850 Can't upgrade/update firmware
                                            by dkneyle
                                            Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                                            Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                                            09-25-2024, 10:44 PM
                                            Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                                            This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-06-2024, 05:27 AM
                                          • ahmedtou
                                            HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                                            by ahmedtou
                                            help me please
                                            I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                                            When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                                            I will share all the details with you, including the disc information.
                                            Code:
                                            HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                                            Current Profile: BD-R
                                            Disc Information:
                                            Status: Empty
                                            State of Last Session: Empty
                                            Erasable: No
                                            Free Sectors: 12,219,392
                                            Free Space: 25,025,314,816 bytes
                                            Free Time: 2715:27:17 (MM:SS:FF)
                                            Next
                                            08-27-2025, 08:49 AM
                                            Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
                                            This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
                                            09-06-2024, 05:30 AM
