Sanyo FW65D25T has backlight but no picture
  • CapLeaker
    Leaking Member
    • 8352
    Re: Sanyo FW65D25T has backlight but no picture
    what are the numbers printed on them ic's?
      • 12323
      • U.S.
      Originally posted by cb1175
      I replaced the main board tonight with one that I ordered from Ebay (supposedly fully tested from a repair shop) and still get backlight no picture - same thing it's always done. I did notice the standby light blinks 9 times now instead of 8 when turning it on. Does anyone know what the blink codes on a Sanyo mean?
      I still had the replacement T-con board that I bought and swapped that in but didn't make a difference.
      The only board I haven't replaced yet is the FRC board. I can't find one for sale right now used or new for this TV. However, in searching for one, I saw that a RCA RLED6090 FRC board looks identical to my board but has a different part number on the board. Should I bother to try replacing the FRC board? If yes, is there any way the RCA one would work or do I need one specific to this TV?
      It appears to me that there is an EEPROM on the FRC board and one on the main board. Are they both EEPROM's or is the one on the FRC board something else?
      Check n see if that's a match, appears to be. https://www.ebay.com/itm/Sanyo-40-DR....c100005.m1851
        • 12323
        • U.S.
        Any progress?
        • triplefour
          by triplefour
          09-13-2023, 10:43 PM
        • TR103
          by TR103
          - it keeps rebooting
          01-22-2025, 04:12 PM
        • Mgiffune
          by Mgiffune
          06-09-2024, 10:28 AM
        • Ierwin
          by Ierwin
          05-13-2025, 03:31 PM
        • Patrick501
          Philips 55PUS6704 no picture, backlight ok
          by Patrick501
          I'd like to repair a Philips 55PUS6704.
          It turns on and you can see the backlight, hear the sound but no picture.
          When I disconnect one of the T-con cables, half of the screen turns white.
          right cable disconnected= right side white
          left cable disconnected= left side white
          When I tape like 6 or 7 pins of one cable it looks like the picture attached. I already tried another T-con board without success.
          There are no shorts on the the mainbaord and the two lcd panel boards...at leat I couldn't find any.
          Also you can notice one single...
          11-12-2025, 08:46 AM
