Insignia No AV, Demonic sound coming from panel possibly
  • k0nsol
    • Sep 2012
    • 30
    Hi All!
    I've recently been trying to get into TV repair (mainly for the fun of it/side hobby), and to better my lack of component level repairs. I work IT and am contently given broken electronics, usually which I try to fix for fun. In the past, I've thrown parts at the TV based until It works. Usually I'd sell it at a major loss after that, as a man can only have so many TVs.
    I saved a Insignia NS-p502Q-10A from the curb earlier this week, and think I've diagnosed it down to a short to ground on the input board. I checked all the outputs on the power supply, and verified that both the X and Y mains are receiving the proper power, as well as the suspect input board. I also ran a continuity test across the buffers, which came back negative.
    On the input board, I don't receive the noise if I unplug the main connector to the control board. Additionally, the main IC after 30 seconds or so gets extremely hot, to the point where I can barely keep my finger on it.
    Here is a video of the noise:
    https://drive.google.com/open?id=1ZD...PuSVLnc6hWLJ3X
    Advice on what to check next is much appreciated!
  • llonen
    • Sep 2014
    • 495
    • hampshire
    Re: Insignia No AV, Demonic sound coming from panel possibly
    You have posted almost none of the required information to get help and you repair underway, please refer to guidelines for obtaining help with plasma sets. Post reasonable pics of the whole rear set board layout and picks of the individual boards in the set for a start. Test VA and VS referring to panel spec, Test Vsc, Ve etc also see if Vs and VA have shorts to ground on either sus board.
    Now that said, what I can see of your set and a search on NS-p502Q-10A seems to suggest this is a Samsung with a different badge, so you could try the following remove the flat cable from the Logic CTRL Board to the Signal input board then jumper pins three and four on the Logic CTRL Board. This should produce a test pattern on the pdp if everything else is working correctly.
    Let me know how you get on
    • tvtimmy
      • Mar 2015
      • 1160
      • usa
      Does the screen light up at all?
      • k0nsol
        • Sep 2012
        • 30
        Hi All,
        The model is a NS-P502Q-10A. I've attached pictures of the TV as well.
        Shorting pin 3/4 did not display a picture. One interesting thing I found was that with the power (and control/data cable) disconnected, the TV did not make any noise. When connecting only the power cable from the PSU to the input board, the TV powered up/on and continued making the noise. Additionally, the input board needs to be connected to power, and power only for the IR to work.
        The IR works normally. The TV powers on and off via a remote.
        • k0nsol
          • Sep 2012
          • 30
          Also, to answer TVTimmy, The screen doesn't display anything or power on. No image or backlight.
          • Andrew F. Ali
            • Jan 2014
            • 2450
            • Trinidad & Tobago
            Unplug the PSU from the Main Bd and see if you have 5VStd-By power on the removed connector.
            • k0nsol
              • Sep 2012
              • 30
              If by main bd, you mean the input board, I have one pin labeled "STBY", which does have 5v at the "off" state.
              • k0nsol
                • Sep 2012
                • 30
                Any thoughts? I'm thinking since the input/main board's data line isn't connected, and I'm having the same symptoms, that the control board is the culprit
                • tvtimmy
                  • Mar 2015
                  • 1160
                  • usa
                  Is the sound coming from the speakers?
                  • k0nsol
                    • Sep 2012
                    • 30
                    It sounds like it's coming from the panel it's self. both speakers are completely disconnected.
                    • k0nsol
                      • Sep 2012
                      • 30
                      Lost cause?
                      • budwich
                        • Jul 2015
                        • 3097
                        when you say the "the panel itself" are you meaning the "physical panel" or one of the boards on the panel is making the sound? ... I can't tell from the video.
                        Use a paper towel card board tube or otherwise to your ear and see where you can isolate the sound from and go from there.
                        Further, on some designs (panasonic in particular) have grounding issues which may generate buzzing....BUT this "fault" ultimately takes out some of the components as the grounding is lost to some of the FETS used to power the display.
                        The voltage labels on the power card are not legible... can you improve and identify which you have checked. Same for the main board.
                        • petehall347
                          • Jan 2015
                          • 4448
                          • United Kingdom
                          sounds like switching noise from supply . is it drawing excess current from the wall ?
                          • R_J
                            • 9623
                            If you here the noise from the panel itself it is likely because the panel has lost its gas, either it is cracked or the glass has lost its seal (around the edge) About the only way to confirm it would be to look at the drive signal on the buffers.
                            • k0nsol
                              • Sep 2012
                              • 30
                              I fully disassembled the TV and found the edge of the front glass. The noise appears to be originating from the Plasma panel it's self, not from any of the individual components.
                              • Kartowl
                                philips 47pfl6158k/12 image faded away, sound still coming from TV
                                by Kartowl
                                Hi, my TV image started showing those lines and the image faded away, but sound is still coming from it, what could be the cause and is it fixable? I thought it could be the tcon board but I red on the internet that it could be a failing panel
                                04-23-2024, 12:57 AM
                              • jose6326
                                Insignia Ns-l22x-10a no picture only sound
                                by jose6326
                                When i power on the tv a "please wait" image appears then goes away then nothing after that only sound
                                When i was removing the back cover i heard a rattle.
                                Removed the metal plate and the heat sink was off (see pic)
                                would this cause a no picture/image issue?
                                What is used to put back the heat sink
                                07-30-2024, 11:03 PM
                              • Christos Tsiligiannis
                                Marian Trace Alpha sound card repair help
                                by Christos Tsiligiannis
                                Hello to the forum.
                                My name is Christos, I am new to the forum here and i am posting from Greece.
                                So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                                To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                                So i tried asking for a schematic from the company and they would not give me one. Instead they...
                                11-18-2024, 05:26 AM
                                HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500T Specification for Upgrade or Repair
                                This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                09-12-2024, 02:30 PM
                                HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i7-9700 Specification for Upgrade or Repair
