Maxent MX-26X3
  • lkvee
    • Feb 2009
    • 198
    Maxent MX-26X3
    I don't think this TV actually has bad caps, and I failed to find any with bulging or electrolyte expulsion on the bottom of the capacitors. The specs for one (lonesome?) capacitor are 85 deg. C, 1000 uF, 10V, and the designation T53.
    I turned on this TV, got the expected behavior (blue screen, acquiring signal, transmitting image), and then after a second, a series of vertical lines about 10 pixels wide, but never a good image. LCD itself is fine.
    FixYa indicated two possible problems, both of whom point to the video chip. I think this was inscribed or etched on that chip:
    DCRe
    SVP
    EX52
    7052 LF
    A HDD02
    D1W95.1
    0532/D5082033
    (c) Trident '04
    I removed the old thermal epoxy, and used four sparing drops of Loctite Control Gel and Arctic Silver 5 on that heatsink. No change in behavior, even though I have yet to feed it a signal.
    I'd like to reflow the solder on that chip (with a heat gun? mini blow-torch? tealight candles?). Yes, this would be my first reflow. I'm not even sure if I'm using the correct terminology, but I'd love to find an instructional URL detailing solder reflow for dummies.
    I'd be grateful for your feedback.
    Thanks for reading.
  • Nama
    • May 2009
    • 127
    Re: Maxent MX-26X3
    Those Caps look to be Elite, Or CapXon's I have replaced many that have no bulging or leaking and it has fixed the problem. I would suggest replacing them. They are very close to the Mosfets and get hot and dry out. I would myself re-cap those 5 before getting oiut the Tealight Candles.
    ^Learning to walk on rice paper without leaving a trace,
    • tmwalsh
      • Jan 2009
      • 119
      Re: Maxent MX-26X3
      You see all those little silver cans? They are electrolytic caps. If you go up a level in the forum, and over to the CDrom section, one poster noted he replaced a bunch of them and his CDrom drive could then read discs that it could not previously read. I would expect there to be a problem in the signal area of the board, not in the power supply.
      Forgive me if I am telling you something you already know. The brown caps by the power supply clean up the dc voltage. If you can scope the output, you can see if they are working.
      tom
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        Re: Maxent MX-26X3
        The KZE on the power board are appropriate there.
        The other Radials look to be Panasonic/Matsushita by the shape of the vents.
        The SMD I'm not sure. I don't see a logo.
        Mann-Made Global Warming.
        - Dr Seuss
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          Re: Maxent MX-26X3
          Originally posted by lkvee
          The specs for one (lonesome?) capacitor....
          Does it date Fuhjyyu's?
          - Dr Seuss
          • lkvee
            • Feb 2009
            • 198
            Re: Maxent MX-26X3
            Thanks for the feedback. I've taken the back cover off again to get a better look at the capacitors. I'm using the picture called "Complete Board" as a reference.
            I used a Cen-Tech point-and-shoot thermometer to get some temperature readings, too.
            The heatsink measured about 118 degrees F. There's another chip that lie "southeast" of the heatsink and that measured 136 degrees F when the thermometer was directly applied to the top of that chip. The one further away about "east-south-east" of the green heatsink measured 98 degrees F. The one northeast of the green heatsink measured 82 degrees F.
            The really big capacitor on the right is specified for 150uF and 450V.
            The smaller capacitor towards the bottom right is specifed for 1000uF and 10V and is also general purpose (85 deg C).
            There are seven electrolytic capacitors towards the bottom left of the picture. The top two are specified for 220uF and 25V and have the designation "HFA". The row of four have the designation "T53" and those capacitors are specified for 2200uF and 10V. The last capacitor is a general purpose capacitor (2200uF and 16V).
            The set by the aluminum towards the upper left of the picture is specified as follows:
            The column of six to the left of the aluminum block are specified at 220uF and 35V. The five to the right of the aluminum block have two specified at 470uF and 35V, one at 280uF and 25V, and two at 1000uF and 16V. These are the KZE capacitors.
            I didn't see the designation "Fuhjyyu" on any of the capacitors.
            I'm still focused on the chip underneath the green heatsink. I'm also still quite open for other ideas, and would like to reflow the BGA solder underneath.
            Thanks again for the input!
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              Re: Maxent MX-26X3
              The mention of Fuhjyyu was a joke...
              You know, "lonely cap", needs a date.. .. Oh. never mind...
              Fuhjyyu are complete junk. You don't WANT to see one.
              "HFA" sounds like a Panasonic number but I can't find it at Panasonic so maybe it was Matsushita only production.
              "T53" is probably a date code.
              - Dr Seuss
              • sucram100
                Re: Maxent MX-26X3
                i have the same problem with the vertical line , and notice that one of the caps on the signal board was loose , replace the cap with a regular electrolytic cap with double the voltage on cap from 25v to 50v and got not results so i detecting the board now
                • lkvee
                  • Feb 2009
                  • 198
                  Re: Maxent MX-26X3
                  So, which capacitor did you replace exactly? I only recall one for 280 uF and 25V. If I'm reading your post correctly, after changing that capacitor, you still got vertical lines and got no change in behavior - you still have a TV working less than 100%.
                  • lkvee
                    • Feb 2009
                    • 198
                    Re: Maxent MX-26X3
                    I took another look at the 208-pin QFP, and I found bridged and bent pins:
                    http://*************/photo/my-images/854/dsc0058ad.jpg/
                    There's another one on another side that's displaced also. It's not as bad as the ones pictured here.
                    Looks like this damage may have been deliberate. Colleague surmised it was done by an unscrupulous repair shop which wanted to cover its anatomy when they told the previous owner there's nothing they could do to fix this monitor.
                    I don't have the equipment to completely repair this. Sure, I have a thin X-Acto knife, but I'll need something with a 1/32" chisel tip to be able to solder with such precision. I don't have a 30X stereo microscope either.
                    Thoughts?
                    • severach
                      • Aug 2007
                      • 1055
                      Re: Maxent MX-26X3
                      With experience this can be soldered with an average sized chisel tip. Practice on a few bum parts first and watch the YouTube videos on SMD soldering.
                      sig files are for morons
                      • lti
                        • May 2011
                        • 2548
                        Re: Maxent MX-26X3
                        The pin on the far right could be straightened since it is still attached to the board. I did a similar repair before. However, the two pins on the left have broken loose from the board. That will be more difficult.
                        • lkvee
                          • Feb 2009
                          • 198
                          Re: Maxent MX-26X3
                          I've been a repeat viewer of the video from Curious Inventor. My colleagues chuckle in disbelief when they see the size of a 603 resistor and the very same 208-pin QFP I want to fix.
                          • tony359
                            Reflow equipment
                            by tony359
                            Hello all,
                            I am experimenting a bit with reflowing larger components - ideally I'd like to reflow a PS4 APU or a GPU for example.
                            I know it's impossible to reflow such large components with just hot air so I bought a pre-heating plate, T-8280 classic Chinese machine, which seems to be working fine besides it's a little slow, which shouldn't be a big deal.
                            Now, my hot air station is a Aoyue 852A++ and I feel it's a bit weak when used with larger nozzle. I tried reflowing a laptop chipset using one of those large, rectangular, nozzles and I failed miserably,...
                            12-25-2021, 01:29 PM
                          • Mr_Nada
                            Concerns before attempting a Reflow of Laptop's GPU
                            by Mr_Nada
                            I saw some posts at one point talking about doing a reflow but I couldn't find them again so I thought that I would post this here.
                            I plan on reflowing the GPU of this old HP DV2500 laptop but I want to go over what I have and the steps I have to take to guarantee it will come out fine.
                            I have a Yihua 8786D 2in1 Rework station, flux (just some paste that I got from an old Radioshack kit), a couple rolls of Kapton tape and a $15 Thermometer +probe (a TM902C from EMR shielding Solutions if its important).
                            • The paper that came with the thermometer states that the probe
                            10-10-2024, 02:53 AM
                          • Davi.p
                            For BGA reflow experts...
                            by Davi.p
                            I have attempted all sumed very few reflow processes, and i need to make it better, how do you make yours to have sureness that the balls are really fully reflowed? My temptation was always to do "the slight move" touching very gently an angle, but due to some cases, but maybe 100%, where the previously half working device became totally shut off, i finally understood that the damn "move" makes the balls shorted, so what do you suggest?
                            Thanks!.. Muchas gracias.....
                            11-23-2024, 10:36 PM
                          • bpjl
                            SEF 551.10 - Error starting the reflow oven.
                            by bpjl
                            When starting the SEF 551.10 reflow oven, the following problem occurs:
                            It seems to me that this is related to corrupted software. Does anyone have files that can fix this device? Or maybe someone uses such an oven and is able to make a sector copy of the memory card located in the computer controlling this oven?
                            PS.: Of course, appropriate emails for help have been sent to the manufacturer and distributor in my country. No response yet, but I don't expect much. It's a fairly old device and from what I know, it's no longer...
                            10-17-2024, 06:30 AM
                          • linhtinh
                            Strange behavior of charging ic ISL88738H
                            by linhtinh
                            Dell LA-H331P board.
                            Schematic here
                            Boardview exactly same la-f541p here
                            First is the ISL88738H charging ic died, i replaced it but the PQ1900+PQ1902 mosfets kept dying, all mosfets are taken from the donor board.
                            Strange behavior is the machine still turns on without battery, i can still enter into bios, but when I pluggin the battery it doesn't charge.
                            I measured all the capacitors and resistors around the charging ic, all are normal. Does anyone know why the PQ1900/1902 mosfets keep dying (shorted D-S) ?​...
                            07-26-2024, 05:01 AM
