TCon V400H1-C03 - picture
  • xxcxx
    • Feb 2013
    • 31
    • portuguese
    I have a Tcon - V400H1-C03 and i need change QP3 - trasistor , is demanged. but i cant see value ..
    I try find schematic ..but ..nothing..
    Is it possible to send-me a picture or value ?
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4535
    • Italy - Milan
    Re: TCon V400H1-C03 - picture
    Try to replace with a P channel mosfet, Vds>=40v, Id=the maximum you find, sot23 pacakge, pinout with 2 pins bottom, single on top, from left: G-S-D
    • xxcxx
      • Feb 2013
      • 31
      • portuguese
      Thanks for yor information, but i see in a picture i think smd mark is "po" , is a transístor or Mosfet ?
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4535
        • Italy - Milan
        it's much probably a mosfet used as a switch for the VGH tension, check also RP21,RP29,Rp30.. check also the vgh rail for short on the connection to the panel with tcon detached..
        • Fly_Among_Stars
          VIZIO E70-E3 Half picture with half TCON
          by Fly_Among_Stars
          I have a VIZIO E70-E3.
          Symptoms: Black screen, no picture, but LED backlights are working.
          I probed the power board and voltages are as listed on the board.
          Main board appears fine, too.
          I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
          There are two separate ribbon cables feeding the LCD.
          If both are connected, the screen is black.
          If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
          04-24-2023, 08:20 PM
        • iglitare
          Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
          by iglitare
          i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
          Backlight seems to work, Sound (Setup menu after reset) works.
          If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
          Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
          With my small knowledge i would think at least the cables are good.
          Can this happen because of a bad tcon board?
          Or is it always a bad/shorted...
          09-04-2025, 07:13 AM
        • x_orange90_x
          TCL 50S535 bad tcon or panel issue?
          by x_orange90_x
          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
          03-29-2025, 11:02 PM
        • shelby5041
          Samsung LCD TV no picture backlight on no 12v at tcon
          by shelby5041
          hi
          i have a samsung lcd tv
          it powers on with sound and backlight but no picture
          all voltages from PS are good 12v 3.3v and 5v
          whats odd is that at the tcon i tested voltage across the fuse on the tcon and i get 0v
          i figured main board issue..so i ordered a used main board....when i put replacement main board in i still have same issue
          no 12v at the tcon fuse
          i disconnect the panel ribbon cables to rule out any panel issues and i still have no 12v at the tcon fuse
          the odds of having 2...
          10-08-2021, 08:21 AM
        • Tr0ll
          by Tr0ll
          Original T-con:
          First replacement T-con:
          10-07-2023, 07:48 PM
