LCD Problem (Obvious in Pictures)
  • metalbird44
    • Dec 2018
    • 14
    Re: LCD Problem (Obvious in Pictures)
    Which is the "Local Dimming board"?
    • budwich
      • Jul 2015
      • 3097
      Originally posted by Davi.p
      This is the problem now... is it a cut?? It's a burnt trace?
      X2 unless it is "marking pen".
      • budwich
        • Jul 2015
        • 3097
        Your problem is not a local dimming problem.
        • metalbird44
          • Dec 2018
          • 14
          I tore it accidentally while plugging/unplugging the ribbons for diagnosis, however, the problem existed before it was torn and hasn't seemed to be affected by it. I'm happy to replace it if it's not too expensive, I think someone said it was a 64 channel ribbon?
          • budwich
            • Jul 2015
            • 3097
            hopefully, you are "working" the cable connectors / clamps correctly. The clamp has to be lifted so that the ribbon can be easily removed.
            Your latest screen shot appears to show a bit of horizontal lines in the right lower half of the screen.... although it could be the "boundry" between the upper and lower side edge boards since the two aren't totally "half"... one has three tabs while the other has two. However, this usually points to problem with the side tab driver in that area. Depending on what the "root" of the issue is, this will cause the display problems that you are seeing. Not really a big deal in terms of a "save" as many many sets in this forum have been saved from this type of issue. The set will operate OK in general without much "visual degradation" assuming you don't have "golden eyes".
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4301
              • Italy - Milan
              #26
              If this is the fact then i agree with the possibility that it is a backlight problem, but i rely on what Diah says about the presence of local dimming. Post a picture of the entire back of the tv, but i have seen those scuff marks on the tcon, plus the flat cable, plus your child's hands... ehm ehm.. i don't know if this is a work for you! Needed an expert's cure. The only thing i want to suggest you that if it is present the local dimming board, then unplug, clean and re-plug all the cables that comes to it..
              • nomoresonys
                • 12123
                • U.S.
                #27
                "plus your child's hands... ehm ehm.. " ???????????????? Must be some GREAT meds.
                • budwich
                  • Jul 2015
                  • 3097
                  lol... :-)
                  its not a dimming problem. Dimming is not going to cause the "color shifts" that are in the display.
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4301
                    • Italy - Milan
                    #29
                    Wrong word sorry, my English is very basic, i wanted to say Kid's hands..
                    • chrismurphy
                      • May 2014
                      • 251
                      • australia
                      #30
                      I still think the issue is not with the LCD panel but the LED backlighting
                      The only way you are going to be sure is to remove the panel and get access to the LED array . Then turn on the TV and see how the leds perform , i suspect that you have Faulty leds or the local dimming is faulty on one or more of the arrays
                      Also if you can get another power supply just to check
                      Also i have one of these with almost the same issue except mine has the dark area in a cone shape as per yours but on the lower left of the panel
                      This is why i suspect the LED array
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4301
                        • Italy - Milan
                        #31
                        He can first try to run the tv with the tcon disconnected from the panel, he could see a white panel, or if not connect output bands one at a time so he can watch at the white side if it is uniform.
                        • chrismurphy
                          • May 2014
                          • 251
                          • australia
                          #32
                          OP any news on this error , i have the same problem
                          • metalbird44
                            • Dec 2018
                            • 14
                            I completely removed the tabs from the bad side, but there was still a dark area in the middle of the screen, so it remained unusable.
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4301
                              • Italy - Milan
                              #34
                              tv's must be studied in deep also outside the forums, before doing suggestions.. datasheets, manuals and so on.. this is a totally fail..
                              • budwich
                                • Jul 2015
                                • 3097
                                what "tabs" are you referring to... maybe provide a picture... as in some of your previous posts you were referring to "tabs" that are not actually tabs. Tabs are dark colored flat ribbons that run from the edge board to the panel and are bonded to the panel.
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4301
                                  • Italy - Milan
                                  #36
                                  "Tab" is a generic term not a technical one, if someone call it tab he can refer it as a horizontal side tab or vertical side tab, so don't play with words, technical terms are source driver fpc and gate driver fpc.. for example.. for friends : top/bottom tabs, side tabs..
                                  • Rozp
                                    70LE660U dark cloud or black screen with sound.
                                    by Rozp
                                    Hello Everyone,
                                    This is my first post so I will try to be as precise as possible without making this post too long winded. Unfortunately I don't have pictures of the original problem but I included images of the TV internals.
                                    I have a Sharp 70LE660U. The problem started a few months ago with the bottom row looking out of sync and was dark on the left side and then fading to transparent on the right side. Shortly after, a dark cloud appeared in the center of the screen. The dark cloud started small and shaded but the image was visible. It also affected the menu area....
                                    08-29-2023, 05:25 PM
                                  • theone111
                                    by theone111
                                    3. Problem: TV shuts down
                                    07-22-2024, 10:36 AM
                                  • Zeonalbasta
                                    Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                                    by Zeonalbasta
                                    i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                                    The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                                    09-13-2024, 01:17 PM
                                  • ashyt16
                                    Toshiba TV bad panel half screen dark - pull tabs or not?
                                    by ashyt16
                                    Hi fellas, I have a Toshiba 50u6863db (vestel crap) here belonging to a family member.
                                    The TV was given me to repair (possibly) as it had developed a blank screen, just back lights and sound.
                                    Upon further investigation it turned out one of her cats had sprayed on the screen as I could see it on the edge of the panel and tabs and it stank. Looks like it probably shorted the circuitry. I cleaned it up and still the same.
                                    I initially suspected Tcon board as none of the test points were showing correct voltages. Tried removing one LVDS cable at a time, same result....
                                    10-26-2020, 05:47 AM
                                  • Tynan Dill
                                    by Tynan Dill
                                    Assuming...
                                    11-22-2024, 01:46 PM
