Sansui 55" LCD TV Model STY1655 (Backlights switching off intermittently)
  • angelos
    • Dec 2012
    • 568
    • South Africa
    Hi guys,
    I have been battling on this one quite some time without any solution. At this point i suspect the inverter board is bad but need to confirm it first. What is happening is that the backlight switch off randomly. I noticed that its the one side of the edge lit leds that flicker and switch off te other side is perfectly fine and stable. I then measured the incoming voltage going off of the LED supply connector and get 42V DC but at times this value changes goes up to 52V. I also measured the return voltage on the LEDs marked N1, N2, N3 etc and they all increase in voltage going up towards 20V DC. Normally they run at about 1.8V Can this be a LED strip going open circuit causing this or is this a bad inverter board?
    What tests can i do to determine this?
    Regards
    Angelos
  • angelos
    • Dec 2012
    • 568
    • South Africa
    Re: Sansui 55" LCD TV Model STY1655 (Backlights switching off intermittently)
    I see that the Vizio E322MV uses the backlight inverter model number T87D106.00
    Anybody got a schematic for this board? It would really help me.
    • CapLeaker
      Leaking Member
      • 8146
      Try turning the back lights down as low as they go in the menu and see if the problem goes away or the back lights are staying on for longer. If you do see an improvement with this, you have bad LED's on the back light strips. The panel needs to be taken apart and the strips replaced.
      • angelos
        • Dec 2012
        • 568
        • South Africa
        There is no such menu option. What i can do, is swap the two plugs around and see if it's the inverter or the led's. The problem is that the plugs differ so i will have to remove the individual wires and swap over after marking the wires. Risky but can prove its the backlights or not.
        • angelos
          • Dec 2012
          • 568
          • South Africa
          Update: I swapped the two led plugs around to find out that the same side is flickering thus its the inverter that's faulty.
          • angelos
            • Dec 2012
            • 568
            • South Africa
            I meant to say its the leds on that side that are faulty. You agree?
            • CapLeaker
              Leaking Member
              • 8146
              yes, the LEDs on that side is / are faulty. These LED's are constant current driven, not by constant voltage. That's why you see the volts go up when a LED goes out.
              • angelos
                • Dec 2012
                • 568
                • South Africa
                Thanks Capleaker, i have ordered replacement LED's. Will have to wait 4 months to arrive. That's how pathetic our postal service is here in South Africa.
                Will post a update once i have installed them.
                • CapLeaker
                  Leaking Member
                  • 8146
                  yeah... sometimes it isn't much better here either with 3 months.
                    by sam_sam_sam
                    03-31-2024, 02:12 PM
                  • mixmax
                    Samsung A53 5G SM-A536F switching off intermittently
                    by mixmax
                    Samsung A53 5G SM-A536F dropped, screen cracked. replaced. Phone works now, but switching off intermittently. It doesn't turn on at all if phone is assembled and all screws are in. When motherboard is loose, it works. I suspect, there is a crack in the MB or pin on some component. The question is:
                    is repair attempt feasible and what is the best way to do it?
                    01-31-2025, 05:07 AM
                    by sam_sam_sam
                    07-01-2024, 06:34 AM
                  • Pipolups
                    Corsair K70 LUX RGB dying LEDs
                    by Pipolups
                    Hi there !
                    I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                    Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                    10-08-2024, 11:58 AM
                    by sam_sam_sam
                    After all of...
                    07-13-2024, 08:14 PM
