Mitsubishi DLP WD-82737 stuck on Welcome Screen Repair Advice
  • waynezo
    • Dec 2018
    My WD-82737 is hanging on the blue welcome screen. I did the firmware update and it worked for 2 weeks. I did firmware update a couple more times and got it to boot but the color was blotchy then it went back to hanging on startup screen. I have heard this indicates a bad power board and or main board. I found this chassis kit on shop jimmy (Out of Stock) https://www.shopjimmy.com/mitsubishi...is.htm?alert=1
    I could probably install it myself. If I can get the part.
    Is there a way to diagnose this better? What would a tech charge for that repair approximately?
    Any advice is greatly appreciated.
  • waynezo
    • Dec 2018
    Re: Mitsubishi DLP WD-82737 stuck on Welcome Screen Repair Advice
    I found a power board on ebay and installed it................ still stuck on welcome screen. So I guess it is the main board. Is there another component which could be the culprit?
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8176
      Can you make some straight shot, high resolution pictures of your main board?
      • R_J
        • Jun 2012
        • 9540
        Looking at the service manual and seeing the large bga chip IC5A01, That would be one of my suspects, bad bga connections. I guess there could also be a fault on the dmd board?
        Try a system reset " press and hold the POWER button for 8 seconds"
        • waynezo
          • Dec 2018
          Thanks to all who responded. I installed a used mainboard for less than a C-note and the TV is fixed
          • Ryan.man
            by Ryan.man
            02-04-2025, 12:23 PM
          • BMCappelletti
            Lenovo Thinkpad E14 Gen3 stuck on "To interrupt normal startup, press Enter" screen
            by BMCappelletti
            Hi everyone.
            Lenovo Thinkpad E14 Gen 3, stuck on the "To interrupt normal startup, press Enter" screen.
            Found a lot of people with this issue, but with no definitive answer. Some people managed to get away accessing BIOS, going to Startup and turning off "Option Key Display". For me that only removed the interrupt normal start up message, leaving only the Lenovo logo.
            Most people say hitting Enter does not work. It's true, if you wait a few seconds. But if you hit Enter right away you get the options to enter BIOS (which works), run diagnostics (goes to a...
            02-18-2025, 12:22 PM
          • reformatt
            by reformatt
            07-31-2025, 08:37 PM
          • smic717394
            by smic717394
            07-25-2024, 10:16 AM
          • Chrissygizmo
            by Chrissygizmo
            02-10-2025, 12:33 AM
