panasonic TX-L47DT65B 10 blinks
  • Andre Gilbert
    by Andre Gilbert
    11-20-2024, 08:52 PM
  • paoloxp
    Red screen or "red snow" on Panasonic TH-42PX70
    by paoloxp
    my old Panasonic plasma TH-42PX70E starts to show a reddish picture every time that it gets warm. Let's say about 15 mins after power on.
    You can see an example on this other post:
    https://www.badcaps.net/forum/troubl...x25-red-screen
    Is there something specific to check on this model? A board that I could try to exchange, maybe?
    Thank you all in advance!...
    05-24-2024, 12:20 AM
  • nobbnobb1
    Panasonic TC-P50U50 Powers Off - 8 blinks
    by nobbnobb1
    I have a Panasonic TC-P50U50 plasma TV which powers on briefly, then powers off and flashes the power light with 8 blinks. This TV is infamous for this, of which the suggestion that the SS board has failed due to loose grounding screws and requires a replacement of the following components on the SS board:
    2x DG302 (Q16051)
    2x RF2001 (D16041)
    2x 5.6 ohm SMD resistor
    1x BD8694 IC
    I have already gone ahead and replaced these components, as well as cleaning off the ground connections on the SS board as well as the associated...
    03-21-2023, 08:33 PM
  • BigPete
    Panasonic Heatpump Dryer Repair
    by BigPete
    I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
    The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
    In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
    Unfortunately the whole machine has to come apart to fix it.
    I have...
    11-01-2025, 06:40 PM
  • mmischni
    Panasonic Viera Plasma TH-42PX75U 7 Blinks/8 Blinks/burned P board?
    by mmischni
    Greetings friends,
    I have a Panasonic TH-42PX75U manufactured in 2007. It has been trouble-free until recently. One evening I turned it on and it then powered back off and gave 7 blinks.
    First a question about the blinks. Everyone only speaks of a single number of blinks. I noticed on my TV, it blinks one fewer times for the first group of blinks, then blinks the full number repeatedly. So for my first code in question, the TV switches off, blinks 6, then blinks 7 repeatedly. When I disconnected the SC board, the TV switches off, blinks 7, then blinks 8 repeatedly....
    09-06-2017, 08:52 PM
