LG 50PN4500 - fluctuating Vcc/18V supply on Y-sustain board causing fault
    Re: LG 50PN4500 - fluctuating Vcc/18V supply on Y-sustain board causing fault
    Good fix, thanks for the update.
    • Pat P.
      • Mar 2019
      • 5
      I'm chasing somewhat of the same issue. Started with a shorted cap at c204 between Vcc and gnd of Ic201 (200d6). replaced with a 50uf (original was 100) to check and everything worked for about 10min.
      replaced Ic201 based on OP's xperiences as everything else seemed to test fine, as well as replacing C204 with the proper value.
      Blew out the 2.0 ohm resistor and the driver FET Q202.
      replaced those and IC201 again(as a precaution), and got fluctuating voltages on the high voltage pin of IC201 .
      IC201 was showing high frequency bursts on the gate of the FET, and as I was continuing to probe it blew out the 2.0 ohm resistor and the FET again.
      I've checked all around that area and components seem fine.
      Any advice?
      • Beau28713
        • Feb 2018
        • 50
        If i remember correctly I blew the same FET and resister once because I had the ic-201 removed from the circuit when I powered up the board. IF I remember correctly there is a small transformer located next to the IC-201, FET and resistor. Make sure incoming/outgoing voltage is good on that. make sure all connections and solder joints are good in the area also. A cold solder joint will cause some weird symptoms and have you chasing ghost.
        Also remember there is a floating ground and a chassis ground on that board.
        • Pat P.
          • Mar 2019
          • 5
          Thanks, I've given the board a good look over, but I'm sure my tired old eyes may have missed something.
          I'll report back when I've had another go at it.
          • Pat P.
            • Mar 2019
            • 5
            Just gave up and bought a used y-sus for $45. back up and running!
            • Beau28713
              • Feb 2018
              • 50
              Hey as long as it is working.
              • alain28
                • Feb 2018
                • France
                #27
                I am looking for C417 and C418 value. Does the rated value is 500v ?
                Thank you.
                • Beau28713
                  • Feb 2018
                  • 50
                  Thank you.
                  I no longer have this tv, but ill look around in my notes and pictures and see what i can find for you.
                  • R_J
                    • Jun 2012
                    • 9557
                    I believe they are 0.022uF
                    • alain28
                      • Feb 2018
                      • France
                      #30
                      Thank you very much for the answers of Beau28713 & R_J
                      You can see a picture of these caps here:
                      http://www.coppelltvrepair.com/p/154...-image-problem
                      On the left and right they are C416/415 & C401/402 that seems similar to the couple C417/418.
                      The dielectric is light grey then the value could be low but also different because the height is not the same.
                      It is not for me but a colleague so I Don't have the board.
                      • Beau28713
                        • Feb 2018
                        • 50
                        I do believe R_J is correct in saying they are .022uF and around 500v. The safest way to proceed would to just buy the repair kit. That way you will have the correct caps and plus you will have some spare parts in case you need them.
                        • Rictech
                          Panasonic SA-MAX770PU SMPSU board fault....
                          by Rictech
                          Hello everyone. 😀
                          As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
                          Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
                          Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
                          This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
                          There are no devices that have exploded or otherwise show signs...
                          08-26-2024, 01:05 AM
                        • tony359
                          2007 Macbook logic board fault
                          by tony359
                          Good day all,
                          I got a 2007 MacBook from a friend. The fan was not working so it was overheating.
                          Once the fan was swapped, I installed an OS and it worked fine.
                          The board had quite a few corroded spots so I removed it, touched those spots with a soldering iron, washed the board in PCB cleaning fluid (I've done that many times), rinsed it with distilled water, dried it etc.
                          Unfortunately it doesn't work anymore. It does turn on, fan spins, power LED turns on. But no picture.
                          If I see that right, I have missed VCORE on L7100 (page 59)....
                          01-23-2025, 06:59 AM
                        • Tynan Dill
                          by Tynan Dill
                          Assuming...
                          11-22-2024, 01:46 PM
                        • Hakuu
                          by Hakuu
                          Hi There,
                          More Details
                          TV Model - LG OLED77G1PUA
                          07-12-2023, 02:37 PM
                        • m1ch43lzm
                          by m1ch43lzm
                          05-12-2025, 08:37 PM
