Panasonic TX-L42E6B Has Backlight & Sound, no Picture
  • Billsy
    • Oct 2018
    • 53
    Good evening all. I have picked up this set that was reported to be dead. When I powered it up, it worked perfectly for a couple of minutes. I then powered off/on and the picture is no mo. The backlight is working fine as is the sound.
    Test pads on Tcon are all very low until I pull the left side ribbon cable, the voltages then come up and the right side of the screen is working.
    Can't see any shorts on the left side LCD driver board (if that's what you call the long thin pcb that hangs from the LCD?) There isn't much to check on those boards, looks like just sm caps and maybe diodes.
    Bad panel? Anything else I can check before I strip it? Cut left side COF tabs perhaps?
    I'll load pictures if required.
    Many thanks
  • nomoresonys
    • 12206
    • U.S.
    Re: Panasonic TX-L42E6B Has Backlight & Sound, no Picture
    Do the same with the right side, see if you get same result on that side, I don't pull any connectors while tv plugged in, with tv unplugged pull ribbon cable then plug in tv and check, less chance of shorting things out that way.
    • Billsy
      • Oct 2018
      • 53
      Yes I did try that. With the left ribbon in-place and right side out, there is no picture. I also never move anything while powered up!
      • nomoresonys
        • 12206
        • U.S.
        Could be panel problem.
        • nomoresonys
          • 12206
          • U.S.
          • Andrew F. Ali
            • Jan 2014
            • 2450
            • Trinidad & Tobago
            Look for a shorted SMD cap on the left Panel Bd.
            • nomoresonys
              • 12206
              • U.S.
              Could try checking your capacitors on the tcon for shorts, diode mode.
              • Billsy
                • Oct 2018
                • 53
                As a last resort I released the left ribbon while powered up and wiggled it about and I managed to find a position where it was happy, pushed the clamp down and picture is working fine. Question is will it last? I'm guessing the connection is worn? Should I put some tape on the back of the ribbon to give more clamping force?
                • Billsy
                  • Oct 2018
                  • 53
                  I did give it a good clean!
                  • nomoresonys
                    • 12206
                    • U.S.
                    If its working, the cleaning and or reseating may have been all you needed.
                    • Billsy
                      • Oct 2018
                      • 53
                      So before re-assembling the TV I tried a reboot and the picture was gone again. I was about to order a tcon board but I was sure the one in the set was ok so I cut off the left side tabs and it now works perfect.
                      Guys is there a long term "side" effect when removing these tabs? What are they for?
                      Thanks for your help
                      • TR103
                        by TR103
                        - it keeps rebooting
                        01-22-2025, 04:12 PM
                      • mar1in
                        Panasonic TH-55AS670A no picture no sound
                        by mar1in
                        I've got this Panasonic TV here with the following symptoms:
                        * Standby Light is solid RED
                        * Turning on using the Button on the TV (long press) would change LED to blinking GREEN
                        * After a couple of seconds, LED is solid GREEN and without picture or sound.
                        I've tried a couple of things before tearing it apart:
                        * Resetting using various combinations of powerbutton and volume buttons pressing down while booting.
                        * Activating Self Check according to service manual using IR Blaster (we have no remote unfortunately)...
                        09-10-2023, 11:10 PM
                      • Mgiffune
                        by Mgiffune
                        I have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started β€˜fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
                        I ordered a supposedly β€˜new' Tcon board this time, and
                        06-09-2024, 10:28 AM
                      • Rozp
                        70LE660U dark cloud or black screen with sound.
                        by Rozp
                        Hello Everyone,
                        This is my first post so I will try to be as precise as possible without making this post too long winded. Unfortunately I don't have pictures of the original problem but I included images of the TV internals.
                        I have a Sharp 70LE660U. The problem started a few months ago with the bottom row looking out of sync and was dark on the left side and then fading to transparent on the right side. Shortly after, a dark cloud appeared in the center of the screen. The dark cloud started small and shaded but the image was visible. It also affected the menu area....
                        08-29-2023, 05:25 PM
                      • DXseekerMO
                        TCL 55US57 backlights, no picture.
                        by DXseekerMO
                        So here we go with another screen short TCL. For this exercise left and right will be reference looking at the screen.
                        The person I got this TV from said the color was bad in a vertical fashion about 1/4 of the way over the left side of the screen. Shortly after the symptoms below started.
                        Power Supply, main and T-CON board are working.
                        Symptoms: The TV has backlights but no picture with both FFC's attached to the T-CON and does not respond to the remote or buttons, and the TV appears to continuously re-boot.
                        Unhook FFC from left side...
                        09-18-2021, 03:56 PM
