42 inch acoustic solutions tv no standby light
  • petehall347
    • Jan 2015
    • 4448
    Re: 42 inch acoustic solutions tv no standby light
    many thanks . will fix that first then test hdmi inputs .
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      did the leds turn up in today's post did they fit in ok? im still waiting for a first class parcel from thursday guess Christmas post delays
      • petehall347
        • Jan 2015
        • 4448
        nope i just checked the post . looking like they will arrive Monday . oh well . been busy changing 2 cv joints anyway .
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          royal mail is getting a joke i posted them atleast half a hour before last collection so should of got them today really, and too bloody cold too be working on cars (im a ex mot tester myself) unless your in a nice heated garage of course.
          • petehall347
            • Jan 2015
            • 4448
            work in a plastic marquee ..have a small burner and gas space heater .. its ok when the winds not blowing in . have to fix tv.s in there too as electronic workshop is a small wooden shed .
            • petehall347
              • Jan 2015
              • 4448
              #26
              led.s arrived .have fitted a red one and it looks ok . just testing hdmi input from laptop playing a film .
              • vinceroger69
                • Mar 2012
                • 6714
                • uk
                #27
                my first class parcel also turned up today too not sure whats happened to first class next day deliveries , main thing is you can fully test the tv now and hopefully re sell it on.
                • petehall347
                  • Jan 2015
                  • 4448
                  #28
                  its still working on hdmi .will leave on for another hour and call it ok . tv is already sold .they say it stopped working after first night of use . i let them borrow a spare tv whilst i looked at this one .
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    • uk
                    #29
                    thats good news then a nice easy fix.
                    • petehall347
                      • Jan 2015
                      • 4448
                      #30
                      just switched it off as all seems fine with it .
                      • petehall347
                        • Jan 2015
                        • 4448
                        #31
                        tv is back with buyer ,,i hope it lasts this time .. if it fails again all i can check if heat related as it is cold where it was tested plus rear cover removed in case it failed or xbox is a problem
                        • petehall347
                          • Jan 2015
                          • 4448
                          #32
                          6 weeks on and it has gone bad again switching off just after picture comes on .led still works .
                          i just told her to unplug it from the wall for a day and try again as that seemed to work last time .well apart from transporting it here .
                          • cheeky2
                            • Dec 2012
                            • 338
                            • uk
                            #33
                            What's the main board and power board from this also model number of Acoustics Solution TV?
                            As I have had similar issues with an old 42" sub branded Vestel unit with a 17pw16-2 which turned out to be Molex connectors from power board to main board were slightly high resistance causing voltage drop! There was enough voltage drop for remote not to work but side buttons would work when bringing it out from standby! Also check the capacitor c835 is not high esr which can also cause issues with standby!
                            • petehall347
                              • Jan 2015
                              • 4448
                              #34
                              it hasn't come back as of yet so i dont know what boards it has
                              • ChristianBr01
                                LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                by ChristianBr01
                                I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                04-23-2025, 01:48 AM
                              • brithepi2k
                                Sony KD-65XE8596 no standby light
                                by brithepi2k
                                I’ve got a Sony KD-65XE8596 here that has no standby light coming on. I’ve tested the power board with the test meter, the TV needs 3.4 for the standby but only getting 2.4. Anything that I can change/check on the board to get it working? Pictures of the board are included.
                                cheers...
                                09-06-2025, 02:22 PM
                              • Kaar3l
                                Samsung QLED QE65Q7FNAT only standby light
                                by Kaar3l
                                TV: Samsung QLED QE65Q7FNAT
                                PSU: BN4400940A
                                MB: BN94-12832K
                                I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                                09-24-2024, 01:35 PM
                              • jasonbay13
                                Philips 37HFL5682L/F7 no standby light, incomplete service manual?
                                by jasonbay13
                                picked up a tv and when the power is plugged, the standby light flashes real quick then goes off. of 3.3, 12, 24v is all there but i couldnt find any 5v on the back-end board. ON/OFF is low, which it seems is what turns on the backlight so i removed the wire at the back-end board and put a 10k resistor to the 3.3v, which when plugged in brings on the backlight for a split second and also a blue light "LED1" on the inverter board, which goes off after a short time.
                                am i missing something to bring on the backlight or is the inverter/ccfl gone bad? would that cause the inverter board...
                                12-01-2023, 09:55 PM
                              • Nicktronic
                                Samsung UN70NU6070F Standby Light flashes twice
                                by Nicktronic
                                Hey Everyone,
                                So I've got this Samsung and the reported issue is that when powered on the backlight comes on, but no picture, no sound, it will flicker, the standby light will flash red twice and repeat the whole process...each loop lasts about 15 seconds.
                                I've googled the issue and understand it is likely a panel/driver board issue, but was hoping the "tape method" could be successful. Before I did that though, I disconnected the left LVDS cable and powered the TV on. This time I got sound, no picture and the two blink standby light stopped. Did the same...
                                03-27-2023, 07:01 PM
