42 inch acoustic solutions tv no standby light
  • petehall347
    • Jan 2015
    • 4435
    ok will start from beginning .
    when this tv came to me a few months back it had bad capacitors on the power board so changed them . then it was working fine .standby light on after plugging in . off when powered up tested tv for a few hours and was fine . fast forewords to weekend just gone .got tv out to sell it tested it and working fine .sold it and delivered it .tv apparently worked fine for first day then it switched itself off and apparently wouldn't switch on . brought it back here plugged in no standby light . pressed on on remote and tv came on fine and has been on for about 5 hours . but standby light not coming on when powered off by remote . also noticed when returning from standby the vol is at a set level even though i had turned it down before power off .
    just wondered where to look first ? i guess i will look at standby led first .
    will update with model number tomorrow .
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: 42 inch acoustic solutions tv no standby light
    maybe someones messed with the menu settings try a factory reset first.
    • petehall347
      • Jan 2015
      • 4435
      would that kill the power / standby light ?
      people that bought it said tv went off and on a couple of times then wouldn't power on again . even though it does power up .
      i am thinking its somehow only part way in standby when turned off . and losing settings . tv channels are still there .
      i forgot to mention they only use for x box so guessing that is hdmi .
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        not sure but cant you turn the standby leds off in tv service menus? im sure ive read you can but like you say a odd fault i would start by checking all the voltages on the psu and go from there ive only ever worked on the 32in version of acoustic solutions.
        • petehall347
          • Jan 2015
          • 4435
          will have to see how to get into service menus .
          • nomoresonys
            • 12257
            • U.S.
            Try firmware update, reapply if available.
            • petehall347
              • Jan 2015
              • 4435
              never had luck finding updates for any tv i have worked on . i have tried auto updates but never worked as well .
              it worked fine with firmware already there anyway . unless you think its corrupted itself somehow ?
              will do regular fault finding in daylight .visual first for obvious things then re seat cables .then check led itself . then check solder joints and maybe heating and cooling things when its narrowed down a bit.... i suspect supply for standby is not right . hoping for bad capacitor as i didnt change them all last time .
              • nomoresonys
                • 12257
                • U.S.
                Often this is sign of mainboard problem, could be borked firmware or something else.
                • nomoresonys
                  • 12257
                  • U.S.
                  Its not too hard to mess up the firmware, small article here. https://www.powersystemsdesign.com/a...-fault/22/5911
                  • petehall347
                    • Jan 2015
                    • 4435
                    that is too much to read right now . first thing jumped out is " preventing the system from booting up after powering on. " it is powering on just fine .just no standby light to start with . so obvious problem . i need to find why that light doesn't light up . will check supply voltages as soon as rear cover comes off and had a visual check over ..
                    damn thing is a bit of a wind up . i was short of cash for birthday beers so sold tv to someone with hard luck story for very low money because of small scratch on screen . turns out it is just for gaming . if they had asked for a monitor i wouldn't be asking about how to fix it . i dont have any monitors for sale .
                    at the end of the day it switches on and works as a tv .. i need to test hdmi for a few hours . will try a video on repeat from pc . or x box i need to test if repeat is an option .
                    • cheeky2
                      • Dec 2012
                      • 337
                      • uk
                      Small point about volume if I recall adjusting volume by remote doesn't store the volume setting when set turned off. You have to enter menu and adjust volume there and there is a store option that must be selected at the bottom of menu as I recall!
                      It took me a while to figure it out as the store button was at the bottom of the audio menu which you have to scroll down to see! So not obvious!
                      As Vinceroger69 said earlier the service menu can be adjusted for various configs for the standby led and I believe in the user menu on some models.
                      • petehall347
                        • Jan 2015
                        • 4435
                        am looking at it shortly . will report back .
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          • uk
                          whats the model number of this tv we maybe able to locate a service manual
                          • petehall347
                            • Jan 2015
                            • 4435
                            ok went through settings and not even a factory reset ..
                            removed cover and checked voltage at standby led .. 3 point something . may have been 3.3v or 3.6v .. jumpered across a white led and it of course it lights up and goes off after pressing on on the remote ..
                            just leaves me trying to find a small through hole blue led on a Friday afternoon .. i removed one from a broken tv but is also a dead one ..i only have white and green ones and too big anyway .
                            tv worked fine for 7 hours yesterday then i switched it off .
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              • uk
                              ive got a few spare ir boards but just checked they are all are double colors none blue, i have a pkt of small through hole leds red, white, green, yellow, but no blues i would of posted you one first class if i had one.
                              • petehall347
                                • Jan 2015
                                • 4435
                                thanks for the kind offer . i also found a dual colour one . i suppose red would be ok . are yours 3mm ?
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  • uk
                                  yes 3mm ones, red would be fine in that set if you have one im sure no one would really notice as long as it lights and does the job. Does the tv seem too work fine now then on all inputs?
                                  • petehall347
                                    • Jan 2015
                                    • 4435
                                    not tried all inputs yet .
                                    will pm my address to you now for red led .
                                    • petehall347
                                      • Jan 2015
                                      • 4435
                                      pm sent
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        • uk
                                        pm sent
                                        posted some out first class two of each color i had.
                                        • ChristianBr01
                                          LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                          by ChristianBr01
                                          I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                          The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                          What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                          04-23-2025, 01:48 AM
                                        • brithepi2k
                                          Sony KD-65XE8596 no standby light
                                          by brithepi2k
                                          I’ve got a Sony KD-65XE8596 here that has no standby light coming on. I’ve tested the power board with the test meter, the TV needs 3.4 for the standby but only getting 2.4. Anything that I can change/check on the board to get it working? Pictures of the board are included.
                                          cheers...
                                          09-06-2025, 02:22 PM
                                        • Kaar3l
                                          Samsung QLED QE65Q7FNAT only standby light
                                          by Kaar3l
                                          TV: Samsung QLED QE65Q7FNAT
                                          PSU: BN4400940A
                                          MB: BN94-12832K
                                          I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                                          09-24-2024, 01:35 PM
                                        • jasonbay13
                                          Philips 37HFL5682L/F7 no standby light, incomplete service manual?
                                          by jasonbay13
                                          picked up a tv and when the power is plugged, the standby light flashes real quick then goes off. of 3.3, 12, 24v is all there but i couldnt find any 5v on the back-end board. ON/OFF is low, which it seems is what turns on the backlight so i removed the wire at the back-end board and put a 10k resistor to the 3.3v, which when plugged in brings on the backlight for a split second and also a blue light "LED1" on the inverter board, which goes off after a short time.
                                          am i missing something to bring on the backlight or is the inverter/ccfl gone bad? would that cause the inverter board...
                                          12-01-2023, 09:55 PM
                                        • Nicktronic
                                          Samsung UN70NU6070F Standby Light flashes twice
                                          by Nicktronic
                                          Hey Everyone,
                                          So I've got this Samsung and the reported issue is that when powered on the backlight comes on, but no picture, no sound, it will flicker, the standby light will flash red twice and repeat the whole process...each loop lasts about 15 seconds.
                                          I've googled the issue and understand it is likely a panel/driver board issue, but was hoping the "tape method" could be successful. Before I did that though, I disconnected the left LVDS cable and powered the TV on. This time I got sound, no picture and the two blink standby light stopped. Did the same...
                                          03-27-2023, 07:01 PM
