Sasmung la40m81bd - Recapped
  • Amraks
    • Nov 2011
    • 725
    Re: Sasmung la40m81bd - Recapped
    VDD = 3.24v
    AVDD = 15.07v
    AVDD_1 = 15.11v
    • Amraks
      • Nov 2011
      • 725
      Just thought I would throw some more voltages up.
      VCC_3.3 = 3.24v
      VCC_1.8 = 1.85v
      VCC_2.5 = 2.57V
      • Dannyx
        CertifiedAxhole
        • Aug 2016
        • 3912
        • Romania
        Looks good (unfortunately). Could be the main IC on the T-con itself is bad, since you do get some picture, so the main board is sending something, but it's not "rendered" properly. Other more experienced users are of course welcome to disagree, that's why we're discussing.
        Wattevah...
        • Amraks
          • Nov 2011
          • 725
          I am wondering if it could be some of the caps I have used. as I did mix it up a bit with brands.
          I have a ESR meter if you know what caps for the picture on the PSU I should be measuring let me know .
          • Dannyx
            CertifiedAxhole
            • Aug 2016
            • 3912
            • Romania
            Unless you used caps that you recovered from another board (used ones), you shouldn't worry about what brand they are, as it shouldn't matter. The brand only makes a difference in how long they last over time AFAIK.
            Also, the power supply board is not directly involved with the picture: it supplies the voltages to the main board and T-con board which then do some stepping down of their own, so as long as the TV is turning on and displaying something, the PSU is likely not the culprit. Noise on the output of the PSU has to get pretty bad to affect anything, by which point the TV is likely not going to turn on at all, but your is, so there's a problem with an IC somewhere. A scope would be handy to analyse the power going into the T-con and main board and ensuring it's ripple-free.
            Wattevah...
            • Amraks
              • Nov 2011
              • 725
              something I need to invest in is a scope.
              if it is a IC I have a microscope to use for the fine soldering.
              • Dannyx
                CertifiedAxhole
                • Aug 2016
                • 3912
                • Romania
                #27
                Ditto...
                Could be the main one (in the middle of the board) which is not replaceable from where I stand, because you can't find it easily, plus the price and labour would outweigh the cost of a replacement T-con. Good on you for having a microscope though...that's another thing I lack.
                Wattevah...
                • Amraks
                  • Nov 2011
                  • 725
                  Just measured pin 4 on TPS65160A in diode mode its reading 0.168v
                  • Dannyx
                    CertifiedAxhole
                    • Aug 2016
                    • 3912
                    • Romania
                    #29
                    Would that reading be in relation to GND ? If so, repeat the measurement in ohms just for the sake of thoroughness. Still, pins 4 and 5 give you the boosted 15v output, which you seem to be getting, given you last results: AVDD = 15v. If there were any dead shorts, you probably wouldn't get any picture at all.
                    This is a good time to measure VGH (voltage gate high) and VGL (voltage gate low) as well since the pins are clearly labeled in the datasheet for the TPS. They are pins 10 and 11. From what I've seen, "ghosting" occurs if VGL is not functional (the screen is not "discharged" and the picture gets stuck). Conversely: if VGH is not "charging" the screen, well, quite predictably, you get no picture. These seldom fail though and from what I've encountered so far, if VGH/VGL are not up, the fault is not in the T-con, but in one of the buffer boards where there's a short that kills VGL/VGH and it's not repairable at that point (the short is most likely in the COF - chip on flex)
                    Wattevah...
                    • Amraks
                      • Nov 2011
                      • 725
                      Never mind I wasn't even looking at the packages legs right lol
                      I measured pin 10 and pin 11
                      10 = 15.12v
                      11 = 4.54v
                      • Dannyx
                        CertifiedAxhole
                        • Aug 2016
                        • 3912
                        • Romania
                        #31
                        Pin 11 should read negative (usually -5/-6v). Try and see if there's a pad labeled VGL connected to that pin (there's a diode in series with that pin, so don't measure AT the pin, measure after said diode). The example schematic in the TPS's datasheet illustrates this. See how there's a diode D2 on the VGL pin there ? Measure after it and see what you get. Should be negative. If not you could be getting closer to the issue now.
                        Wattevah...
                        • Amraks
                          • Nov 2011
                          • 725
                          So pin 11 goes to CD15 then to D4
                          D4: -7.79v
                          Added a picture of the voltages across that line.
                          • Dannyx
                            CertifiedAxhole
                            • Aug 2016
                            • 3912
                            • Romania
                            #33
                            Would that value happen to appear at the test point marked V_OFF ? If so, it would seem they're not calling them VGH and VGL but rather V_ON (slightly higher, towards the mounting hole) and V_OFF, which is the same thing.
                            The value would seem right...a bit low, but should be within spec (the datasheet for the panel itself tells you exactly what it should be).
                            EDIT: also, could your describe, or better yet, post a picture of what the picture is doing currently ? I missed the video.
                            Wattevah...
                            • Amraks
                              • Nov 2011
                              • 725
                              Here is some more voltages I took.
                              VREFL_L = 330mV
                              VREFL_H = 6.45V
                              VREFU_L = 8.49V
                              VREFU_H = 14.68v
                              not sure if the top one is meant to have voltage going through it but it stands out as being something to pick on.
                              • Amraks
                                • Nov 2011
                                • 725
                                heres a video i scrubbed the other one it had a kid screaming and I didn't think it was fair on you guys to listen to a baby screaming lol
                                https://youtu.be/d3zCpfB23Sg
                                • Dannyx
                                  CertifiedAxhole
                                  • Aug 2016
                                  • 3912
                                  • Romania
                                  #36
                                  Wow that's bad...you could try heating up the main board like someone else suggested just to see what happens. Must admit I haven't seen anything quite like it, but that rainbow of colors could point to a faulty MB too...
                                  Wattevah...
                                  • Amraks
                                    • Nov 2011
                                    • 725
                                    That is correct must be a Samsung thing.
                                    • Dannyx
                                      CertifiedAxhole
                                      • Aug 2016
                                      • 3912
                                      • Romania
                                      #38
                                      Not necessarily. Actually this is the first T-con I've seen which calls them that. Samsung doesn't manufacture the boards anyway, so the original producer is free to mark them whatever they want if I'm not mistaken.
                                      Could also be a bad LVDS cable, though I doubt anyone messed with it. Still worth trying to disconnect it, plug it back in at either end, jiggling it around, you know just to rule it out.
                                      Wattevah...
                                      • Amraks
                                        • Nov 2011
                                        • 725
                                        Have had this disconnected a few times after I got the tv back cables look good no ones been messing with them.
                                          • 12084
                                          • U.S.
                                          #40
                                          Wonder if thats a match for your tcon? the first 9 numbers on the sticker match. https://www.ebay.ie/itm/TCON-BOARD-4...-/162987820813
                                            Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                            by sam_sam_sam
                                            This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                            I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                            I am comparing them to a brand new one that I installed
                                            The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                            I going to let it run for several days before I remount back on the wall next to the...
                                            09-05-2024, 06:48 PM
                                            by momaka
                                            03-15-2023, 10:17 PM
                                            HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
                                            This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            09-12-2024, 02:30 PM
                                            HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                            HP ProBook 450 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook 450 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G7 + APC Back-UPS 700VA boardview and 450 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 08:10 PM
