Samsung TV with black screen
  • gua45
    gua45
    • 21
    • España
    Hello, good morning, I have a Samsung TV,
    Model: UE32F5700AW, when I turn it on
    it has sound and the led of the panel light up but the image
    is absent, I have been told that it may be the
    T-con. In the input and output of the fuse of this card I have
    12 v., But I do not know where to measure more tensions in the T-con.
    The code of the T-con is RUNTK 5351TP 0055FV ZZ.
    Please can someone tell me the steps to follow for
    find the problem
    Greetings and thank you.
    P.S. Sorry for my English.
    Re: Samsung TV with black screen
    Please upload good clear straight shot pictures of the whole T-CON board and also the whole back side of the TV showing all the boards.
    • gua45
      gua45
      • 21
      • España
      Hi, I'm attaching TV pictures, I hope
      be correct
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Looks like F100 was bridged and was open circuited again. If you do have 12V on both sides of F100 then measure the voltages on VGL, VGH, HVDD and VCOM and report your findings.
        • gua45
          gua45
          • 21
          • España
          Hello, indeed the fuse is bypassed because it was fused and as I said in my first post
          I have 12.4 v. At the entrance and exit and in the points you mention I have no tension.
          A greeting.
          • gua45
            gua45
            • 21
            • España
            On the TV I have sound and backlighting
            but I do not have an image
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              If the Flat ribbon cable to the Panel Bd. is disconnected, do these voltages come up? If yes then the Panel is defective, if no then a new T-CON Bd. should solve your problem.
                • 12330
                • U.S.
                Mainboard there, need to check white sticker numbers to see if its a match, 60 euros for a 32 inch tv seems a bit high tho. https://www.ebay.es/itm/PLACA-PRINCI...13WS:rk:3:pf:0 Oops, thought you were looking for a mainboard.
                • gua45
                  gua45
                  • 21
                  • España
                  Disconnecting the flat cable that goes to the
                  Main-boar, the voltages remain the same, absent.
                  I understand that it is necessary to change the T-con, I can replace it
                  for a Runtk 5246TP instead of the Runtk 5351TP.
                  A greeting.
                  • gua45
                    gua45
                    • 21
                    • España
                    I read on the network that the Runtk 5246TP card gives less
                    problems that the Runtk 5351TP.
                    • Andrew F. Ali
                      • Jan 2014
                      • 2450
                      • Trinidad & Tobago
                      Yes a new T-CON will fix your problem.
                      • gua45
                        gua45
                        • 21
                        • España
                        Thanks, I'm going to order the T-con, runtk 5264TP and when the
                        receive information about the results.
                        A greeting.
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4540
                          • Italy - Milan
                          OH MY GOD!... Knowledge zero...
                            A greeting.
                            What we need are the Voltages of VGH, VGL, etc. on the T-CON board test point when the ribbon able between the T-CON and the LCD panel are not connected and connected, not the cables to the Main board. There are many Voltage test points on the T-CON board that need to checked and reported.
                            • vlado66
                              • Apr 2015
                              • 10
                              • SLOVENSKO
                              voltages
                                What we need is the OP (gua45) to provide the Voltages from HIS T-CON board suggested in my post #14.
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4540
                                  • Italy - Milan
                                  But we know fuse is blown so he must replace it first.. also to be tested VLS15.6V
                                  • petehall347
                                    • Jan 2015
                                    • 4450
                                    • United Kingdom
                                    ic looks bad by where it says FET 201 top left
                                      • 12330
                                      • U.S.
                                      ""T-con. In the input and output of the fuse of this card I have
                                      12 v."", But I do not know where to measure more tensions in the T-con.
                                      find the problem
                                      Tcon fuse is good then.
                                        He bypassed the fuse per post #5.
                                        • HTR-Informatique
                                          by HTR-Informatique
                                          02-09-2025, 06:51 AM
                                        • totof
                                          Samsung UE50KU6070 black screen
                                          by totof
                                          I have my TV model UE50KU6070 which I am trying to repair.
                                          BN41-02528A / BN94-10800C motherboard.
                                          If I disconnect the motherboard from the power board, the backlight works. When the motherboard is connected the backlight works but the screen remains black.
                                          When I plug the TV into the electrical outlet, the standby LED lights up but no reaction to an attempt to start it with the remote control for about 1 minute. During this minute the TV consumes about 20W.
                                          After one minute the consumption drops to 0W and the TV can turn on with the remote control but...
                                          09-26-2022, 02:34 PM
                                        • VcemPzd
                                          Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                                          by VcemPzd
                                          Hello everyone !
                                          My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                                          04-28-2025, 10:14 AM
                                        • kca
                                          by kca
                                          Hello all ~
                                          08-31-2025, 06:38 AM
                                        • ulthi
                                          Samsung QE50Q60TAU - Flashes black/blue screen
                                          by ulthi
                                          My tv is not able to turn on. I flashes between black and vague blue screen (see video)
                                          I have tried different resets and have also replaced the main board - but nothin has changed.
                                          Any suggestions?
                                          https://youtu.be/acYQ-ImmhWA
                                          10-14-2025, 01:48 PM
