Samsung UN50JU6500F; Blown NTC thermistor
  • yyzmxs
    • Apr 2018
    • 19
    • Czech Republic
    Hi guys,
    a neighbour offered me his TV which stopped working, since he knows I like to tinker.
    First obvious visual red flag, as a plastic bulging on the back over, not too far from the plug ... I immediately think, something blew up on the power supply board. Here's the pic ....
    After I removed the cover (pic below), I am looking at where the bulge is and see obviously one of the green NTC thermistor guys hurting. Using voltmeter to measure ohms, obviously I get out of range figure.
    So here are my questions ...
    1)
    Immediate thought is to replace the NTC thermistor. The value on it reads WMEC
    WTR
    15D2R5
    which I believe means 15mm disc dia., with 2.5ohm resistance value, and 8A peak current, 3.2W power
    Problem is I cannot find exactly the same part or value anywhere (anywhere where I can buy few, not hundreds). The closest I am getting is either larger D or a bit smaller peak amps or power. See example below ...
    https://canada.newark.com/epcos/b572...mm/dp/24AC7709
    My question is is larger diameter bad or it will just dissipate heat better? I assume I cannot go lower on power or amps correct?
    Is there a better place then Newark to buy these things?
    2)
    Not being familiar with the particular component, I wanted learn a bit. It seems that most people suggest that if NTC thermistor blows, it's usually for other reasons than the component being bad or worn out. Having said that, there's no other obvious burnt up spot on the power supply board. Should I be measuring voltages elsewhere on the board to verify whether there's more damage as a result of the NTC failure, or rather something else failing before, causing the NTC blowup. Is it correct to assume that there must have been larger amperage rushing in which the NTC could not take and thus could not dissipate the higher heat value and melted the plastic?
    Thanks very much for trying to help.
  • petehall347
    • Jan 2015
    • 4448
    • United Kingdom
    Re: Samsung UN50JU6500F; Blown NTC thermistor
    is the other one working with it ? like in series or parallel ?
    i would be checking for shorted semiconductors first
    • yyzmxs
      • Apr 2018
      • 19
      • Czech Republic
      Well the other one measures about 3.5ohm at 21C. Shorted semiconductors ... you mean like diodes, transistors etc.?
      You think replacing it, is a good chance it will blow right back up again, eh?
        I do not see the pictures of the board.
        P/N BN44-??????
        • R_J
          • 9624
          If it is a bn44-00807 the green one is a mov 14D751 (location VX801S)
          The thermistor is a 2.5D-15 (Location NT811S)
          • yyzmxs
            • Apr 2018
            • 19
            • Czech Republic
            I took a couple more pictures of the board ... It's BN44-00807A
            • R_J
              • 9624
              Use the Go Advanced and click on the paper clip to attach your pictures
              • petehall347
                • Jan 2015
                • 4448
                • United Kingdom
                pic has vanished
                • yyzmxs
                  • Apr 2018
                  • 19
                  • Czech Republic
                  That's odd as far as pictures ... is this site not compatible with Google Drive pics sharing?
                  • yyzmxs
                    • Apr 2018
                    • 19
                    • Czech Republic
                    How about clicking on these links? Does it work?
                    Back Cover
                    Complete power board
                    Power Board Model
                    Damaged NTC
                    • R_J
                      • 9624
                      how about attaching them to the thread?
                      both thermistors are 15D2R5
                      • yyzmxs
                        • Apr 2018
                        • 19
                        • Czech Republic
                        I can try that ... so the links I posted last time don't open the pictures either?
                        • yyzmxs
                          • Apr 2018
                          • 19
                          • Czech Republic
                          Pics are attached to the thread now.
                          • yyzmxs
                            • Apr 2018
                            • 19
                            • Czech Republic
                            both thermistors are 15D2R5 Ametherm SL15 2R507 or Epcos B57237S0259M000
                            https://canada.newark.com/c/circuit-...-25degc=2.5ohm
                            The Ametherm is only good for up to 7A, stock was 8A, isn't that a concern? Epcos is even lower 6.5A ....
                            • R_J
                              • 9624
                              https://canada.newark.com/w/c/circui...t-at-25degc=8a
                              Amphenol CL-30 2R5 8 amp, 19.56mm diameter
                              The epcos is 8.4 amp at 2.5Ω as soon as the resistance drops to 2.2Ω its at liklely close to 9 amp
                              I would not be too concerened as the main fuse is rated at 5 amp
                              • yyzmxs
                                • Apr 2018
                                • 19
                                • Czech Republic
                                So, that was my initial question .... the larger diameter is not a concern as far as functionality.What's the wisdom here .... the larger footprint, the better heat dissipation?
                                • R_J
                                  • 9624
                                  The larger diameter is not a concern. the only concern would be if not fit is the space on the board
                                  • yyzmxs
                                    • Apr 2018
                                    • 19
                                    • Czech Republic
                                    Got it. So I guess I will go ahead and order a couple of those Amphenols a go from there.
                                    • yyzmxs
                                      • Apr 2018
                                      • 19
                                      • Czech Republic
                                      I replaced the cracked up NTC and so far TV works like new.
                                      Thanks for your help everyone.
                                        09-07-2024, 05:50 AM
                                      • cheeky2
                                        Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
                                        by cheeky2
                                        This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
                                        I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
                                        Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
                                        06-15-2025, 05:12 AM
                                        09-06-2024, 11:40 PM
                                        09-06-2024, 08:40 PM
