I'll start off with saying that I'm very new to tv-repairs.
With that said, I have an LG 60PZ250N-ZB in my home, which I happened to find in the garbage room.
The TV worked just fine, but I noticed some grainy noise, going mainly horizontally across the screen, in certain lighting. Could be bright or dark, mostly bright.
After some searching I figured it could be what's known as "mal discharge" so I got myself some documentation from LG for this.
Then I found this site, and Topcat wrote about the "sparklies".
I decided to test the Va and Vs with a DMM and found the voltages off by a volt or so. Keep in mind that I have a very cheap DMM. I am thinking this isn't the brightest thing to use, but I have an incredibly limited budget.
So, I adjusted the pots to get the correct Va and Vs, but upon testing Vs on the YSUS board I happened to short the 5v and the Vs (55v) lines.
I hear buzzing from the YSUS board when I plug in the AC cord, which I heard prior to shorting, and the buzzing now stops ~3 seconds after plugging in.
On the control board, the green LED flashes 4 times (long, long, short, short). I have no idea how the LED was lighting before shorting because I did not look.
So, without jumping to any further conclusions, I'd like to ask for some opinions on what to do next. Should I replace the PSU? I'm not quite sure how to test what components might have fried since I have very limited equipment.
Thanks for taking the time to read my post.
