Samsung un60eh6050 back-light working, but no picture or sound
  • engelwood39
    • Mar 2015
    • 93
    I have a Samsung un60eh6050 that the back-lighting comes on, but it has no picture and no sound. I was going to see if someone could point me in the right direction.
    Here are the voltages out of the power supply with everything still hooked up:
    1: B13V...12.78
    2: PWM_DIM...3.07
    3: B13V...12.78
    4: B13V...12.78
    5: Vamp...12.78
    6: BLU_ON/OFF...5.98
    7: Vamp...12.8
    8: GND...0
    9: GND...0
    10: GND...0
    11: B5V...5.4
    12: A5V...5.4
    13: B5V...5.4
    14: POWER ON/OFF...3.6
    Also I tested the T-Con board fuse and it had 12V on both sides.
    If there is anything else I need to test that may help please let me know.
  • DXseekerMO
    • Feb 2018
    • 1119
    • US
    Re: Samsung un60eh6050 back-light working, but no picture or sound
    Timing control boards on these are known to fail in this mode. Search this site with your T-CON board number and see if you get a hit.
    They call me......."threadkiller"
    • CapLeaker
      Leaking Member
      • 8352
      check the LVDS on the main board with an oscilloscope, while turning the menu on and off all the time. Other than that, test all these little buck converters on the Tcon board. If you want to throw parts at it, change the Tcon first, as it is much cheaper to replace than a main board, plus the Tcon is known to fail.
        • 12323
        • U.S.
        Must be a high demand for the tcon, shopjimmy wants twice as much for the tcon than the mainboard.
        • bobbyskillz
          • 76
          I'm curious what components normally fail on t-con boards.
          • jetadm123
            • 2169
            I believe for this t-con, it's the ISL9860 chip. But that's for a TV with sound and no video. However, since you're also getting no sound, I would think it's something beyond the t-con.
              • 12323
              • U.S.
              Mainboard repair kit? https://www.shopjimmy.com/samsung-bn...eh6000fxza.htm
              • TR103
                by TR103
                - it keeps rebooting
                01-22-2025, 04:12 PM
              • Mgiffune
                by Mgiffune
                06-09-2024, 10:28 AM
              • Ierwin
                by Ierwin
                05-13-2025, 03:31 PM
              • jchang
                Samsung UN70NU6900F no picture and no sound
                by jchang
                Hi all
                I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                Symptom:
                No picture no sound.
                When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                No sound at all.
                What I tried:
                1. I tried unplugging the left or right ribbon...
                01-09-2023, 06:28 PM
              • Dodgethis
                Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                by Dodgethis
                Hello all,
                This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                09-11-2024, 07:39 AM
