Philips 20PF4121/58 power inverter board problem
  • JohnNovak
    replied
    Re: Philips 20PF4121/58 power inverter board problem
    Hi.
    I check this critical parts and also other diodes and transistors,
    Q208, Q204, D201, D202, Q209, Q205, D101, D103, D100,
    no faults found.
    Thank you.
  • bobbyskillz
    replied
    What's going on with Q208 where it meets the heatsink? Have you checked the diodes and MOSFETs out of circuit?
  • JohnNovak
    replied
    I check all resistors, standard and not standard values are OK.
    Any suggestion?
  • JohnNovak
    replied
    Some pictures for better view.
  • JohnNovak
    started a topic Philips 20PF4121/58 power inverter board problem
    Hi.
    I have LCD TV Philips with power inverter board problem.
    TV Philips model: 20PF4121/58, chasiss LC4.1E AB
    power inverter board model: DELTA DAC-12M019 AOF, REV.05
    After electrical shock by storm is dead.
    No any visible damage or short circuit found.
    I replace some sensitive parts on board,
    U101=EA1523A, Q107=11N80C3, optocoupler U100=PC817.
    No power up.
    Can not found schematic for this power inverter board to check carefully small smd resistors which many are not standard values and is very hard to check if resistance is correct.
    Any help, experience with this power inverter board?
    Thank you.
  • Destroyer-Br
    [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
    by Destroyer-Br
    I'm working on an Acer Nitro 5 unit with the following specs:
    • Motherboard: LA-J871P Rev: 1B
    • Model: Acer AN515-55-59MT
    • S/N: NHQ7JAL00403906A973400
    • SNID: 03902728734
    Initial Issue
    The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
    After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
    04-17-2025, 08:18 PM
  • spantor
    Activate power board Philips 40PFH40009/88 tv
    by spantor
    Hello partners.
    Could someone tell me how to make this Philips TV source work without the mainboard being connected? The model of the board is EAX65423701 (2.1) and the model of the Philips TV is 40PFH40009/88.
    The TV is dead, there is no standby light, however there is a voltage of 12v on the pins ( included 12v VAU ) and 3.2v on the PS-ON pin (see photo) when the power board is connected to the main board. If I disconnect both boards I only get 8 volts on 12v pins. I would like to rule out a fault in the main board by making it work, but so far no one has been able to tell...
    02-11-2024, 05:07 PM
  • Dani_2024
    by Dani_2024
    10-28-2024, 05:06 PM
    by sam_sam_sam
    After all of...
    07-13-2024, 08:14 PM
