Lg du42px12x
  • aljgardin
    • Nov 2018
    Lg du42px12x
    Plasma tv with no video input working.
    Screen works.
    Menu Works.
    Coax in works, DTV scan picks up 1 channel with sound.
    Tried composite, HDMI, DVI no inputs work.
    Any help, starting point or suggestions would be great.
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Lg du42px12x
    Look for a Main Bd replacement
    • Scruit
      What is a normal composite signal range for a C64?
      by Scruit
      Hello all,
      Working on my first C64 / Breadbin / 250407. Purchased as non-working. Getting black screen.
      More detail below, but for those that want to get right to the question.... Here are a few waveforms comparing the Pin15 output on the VIC chip (luma/sync) to the pin 4 on the AV socket (composite signal).
      https://imgur.com/gallery/PpqcqPY
      My question is: Is the composite waveform range of 0.1v-1v too low for a c64?
      More detail:
      Symptoms are that that I get...
      04-28-2022, 05:33 AM
    • CapLeaker
      Dell ATX PSU won’t start, but forcing it works fine?
      by CapLeaker
      Got a case of something new weird at work. There is an old 2nd gen Intel i3 in an old “Pizza box” shell that has a small form factor power supply. Unfortunately I forgot to take pictures and model number off it.
      Anyway, I get to work and get to look at this computer. Standby LED on the PSU is on, but the computer won't start. Hmm o.k. take the battery out of the main board try again, nothing. O.k. then… unplug the power supply from the main board and put in a full size ATX PSU (yeeeesss! Exact that blown Powerman IP that I fixed a while back), plug it in and the old...
      10-28-2024, 06:59 PM
    • rounin
      MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
      by rounin
      I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
      🛠 Original Issue
      The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
      ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
      04-19-2025, 01:18 AM
    • ex250
      Kenwood SW-505D no sound issue and pops from time to time when it works
      by ex250
      Hello mates,
      I bought this subwoofer a few days ago used and blind and it works erratically, as far as I could see, it has been tampered with, the speaker is not the original one and of 8 Ohm when it should be of 4, and there are some welds like reworked by the boards.
      It doesn't have much power (expected more from it) and it distorts if you increase the volume over the middle, maybe it's because of the high impedance of the speaker. The problem is that it has sound when it wants, the led panels all work correctly, you can hear the power relay on power on, but right now...
      12-29-2024, 03:27 PM
    • eurowill
      a2141 820-01700 internal display not working / external works
      by eurowill
      Hey ya'll this is my first post on here. I recently aquired a used/broken 2019 mbp 16 a2141 with the 820-01700 board. Seller told me that the laptop needed a new lcd. However upon doing some troubleshooting i found out the lcd is fine.
      Laptop boots like a normal, plays chime, touchbar lights up however there is no image on the internal lcd. If i connect and external monitor while its already on, nothing happens and no image is displayed on external. However if i restart or boot the machine while its plugged in, the external then works and a backlight is now visible on the laptop....
      07-23-2024, 10:06 AM
