Samsung UE22ES5000 Led tv no standby
  • datalore44
    • Jan 2015
    • 34
    Re: Samsung UE22ES5000 Led tv no standby
    Resistance across cm867 is 7.2k, but across cm864 it starts at 3meg and eventually drops down to about 30k before going back up again.
    • datalore44
      • Jan 2015
      • 34
      Anymore help on this would be greatly appreciated.
      • datalore44
        • Jan 2015
        • 34
        I still need help on this if anyone can help it would be much appreciated.
        Alan
          Right now that 12V power supply section is not making any sense, the resistance of the first filter cap at the Cathode of DM861 is 30K so that should not load down the 12V output , and since the switched MOSFET (QM861) for the switched 12V should not be on unless PS-ON is present and the resistance of the filter cap CM867 is 7K2 Ohms so that is not problem either.
          What resistance do you get reading between the two leg of DM861 when it is soldered back into the board?
          • datalore44
            • Jan 2015
            • 34
            Hi budm and thank you for your help again. The readings across the diode DM861 is erratic. I get 295 ohm with negative on the cathode and from 3meg dropping to 7k then back up when positive is on the cathode. This board is driving me crazy.
              That is strange reading of 295 Ohms.
              Can you un-solder the Source pin of switched 12V MOSFET (QM861) to see if 5V will be stable?
              It drives me crazy too since it is just simple always on power supply board.
              • datalore44
                • Jan 2015
                • 34
                I got a reading of 2.4 to 2.7 volts.
                Do you think it has anything to do with the shunt regulator icm861 (top right on board TO-92 package) which is a kia431a?
                And how would I test it?
                Alan
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4507
                  • Italy - Milan
                  #28
                  Budm was meaning if A5v is stable... B5v is the switched one so if PWR-On signal malfunctions the gates of both smd power mosfets doesn't let output on-state tensions on the connector.. if A5V is stable (pin 12 output connector) then resolder source of QM861, desolder ZDQ851, make a jumper [P-ON]-GND and watch connector outputs, if ok replace the zener.
                  • datalore44
                    • Jan 2015
                    • 34
                    Hi. Yes I took the reading from A5V. It is bouncing around at 2.4 to 2.7v
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4507
                      • Italy - Milan
                      #30
                      OK, you can: unsolder again DM861 cathode and connect a load of about 0,5-1A to the A5V, retest A5V, with and whitout load..
                      • datalore44
                        • Jan 2015
                        • 34
                        How do I go about adding a 500ma load?
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4507
                          • Italy - Milan
                          #32
                          5V/0,5A=2,5Ohm 3>5W resistor at the A5v output..
                          • datalore44
                            • Jan 2015
                            • 34
                            Ok I will have to dig around for a 3 to 5w resistor. I thought that 5/0.5 was 10 Ohms though. Or am I missing something.
                            Alan
                              Must be typo, yes, it should be 10 Ohms so it will draw 0.50A from 5V supply.
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4507
                                • Italy - Milan
                                #35
                                Sorry 10 ohms 10watt..
                                • datalore44
                                  • Jan 2015
                                  • 34
                                  I have ordered the resistor and will update you when I have tested the circuit. Many thanks for all your help.
                                  • Atavares
                                    • Dec 2020
                                    • Portugal
                                    #37
                                    Originally posted by R_J
                                    Did you replace CM808 capacitor?
                                    What number diode did you use to replace DM861?
                                    Check that QM861 is not shorted
                                    Also what is the voltage measured at the cathode of DM861
                                    Hi R_J!
                                    Do you know the ref. of the QM861, i have the same problem, but my QM is shorted.
                                      09-07-2024, 05:50 AM
                                    • tvguy12012012120
                                      by tvguy12012012120
                                      02-07-2025, 05:13 PM
                                    • ChristianBr01
                                      LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                      by ChristianBr01
                                      I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                      The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                      What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                      04-23-2025, 01:48 AM
                                    • Kaar3l
                                      Samsung QLED QE65Q7FNAT only standby light
                                      by Kaar3l
                                      TV: Samsung QLED QE65Q7FNAT
                                      PSU: BN4400940A
                                      MB: BN94-12832K
                                      I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                                      09-24-2024, 01:35 PM
                                      09-06-2024, 11:40 PM
