LG LED TV 65UH5500 No picture
  • Changlish76
    • Nov 2018
    Hello! I Have a LG 65UH5500 that shows the LG logo for a split second after being plugged in, then goes black and the power led blinks. I understand the led strips can cause this and want to start troubleshooting the right areas. I'm concerned because I have not been able to see anything with the flashlight test, or produce any audio. Any suggestions? Short video of the problem:
    streamable.com/w0e5z
    I was under the impression that when the led strips are at fault, you can at least see a faint image with the flashlight or get sound?
  • neilc6
    • Nov 2015
    • 1550
    Re: LG LED TV 65UH5500 No picture
    Most likely failing backlights. Some models shut down the backlight only. Your model may shut down the tv when a poblem is detected.
    Not easy to remove a panel without cracking it from a 65 inch tv to get at the backlights.
    • Charleyd
      • Aug 2016
      • 42
      My approach for handling large screens is to deal with them vertically. After removing the bezel and securing the edge boards, I raise the whole TV almost vertical with the top edge of the TV on the floor, and then lift the LCD panel away by its corners. Then I lean the panel against something, thus keeping it always vertical. To reinstall, I bring the TV close, again tilted almost vertical, and lift the panel by the corners onto the TV and then lay the unit back down. I have managed up to a 70" by myself so far.
      • budwich
        • Jul 2015
        • 3097
        before you go too far too fast.... try disconnecting, one at time, the tcon to panel cables and see what happens on power up. Go from there.
        • Tr0ll
          by Tr0ll
          Original T-con:
          First replacement T-con:
          10-07-2023, 07:48 PM
        • JJAAMM
          by JJAAMM
          Problem
          07-06-2023, 06:01 AM
        • Kingfreddie
          LED problem on samsung UE55F6475, 2 strips work. The rest is flashing every second.
          by Kingfreddie
          Ok.. this is the story:
          Have an old Samsung LED 3D TV (UE55F6475). First it started to lose light on the lower 40% of the screen now and then. Like for 10-60 mins and then it would work again. Then a bit later it just got stuck in that position. The lower 40% of the screen is dark, and it gets progressively darker the lower u go so it's obviously that LED strips where not working. I also looked for similar errors online and saw an exact copy and on that one it was faulty LED strips.
          This is kinda how it looked, just that mine were at the bottom of the screen:
          09-11-2021, 01:57 AM
        • TR103
          by TR103
          - it keeps rebooting
          01-22-2025, 04:12 PM
        • Mgiffune
          by Mgiffune
          06-09-2024, 10:28 AM
