Thin Vertical Line
  • jstiene
    • Feb 2013
    • 148
    Thin Vertical Line
    Hello. As you will see in the pictures my Vizio has a thin vertical line. Is it worth the effort to take the screen apart to try to fix this? Is it possible to fix or is the screen basically bad?
  • petehall347
    • Jan 2015
    • 4426
    • United Kingdom
    Re: Thin Vertical Line
    looks like panel to me . never seen a fix for this ..
    • SLK001
      • May 2014
      • 264
      I agree. It is usually a bond from the flex cable to the LCD panel itself that has come loose. There is usually no way that an ordinary repairman can use to fix this.
        Single pixel line is always a bad panel, unfortunately
          • 12110
          • U.S.
          Could try stripping it down to the tab bonds on that line, maybe a shim would make it go away, on the jvc tv I'm using right now as monitor, it would have thin vertical lines if the screws holding the frame weren't just the right tightness, too tight red one pixel lines too loose same, your tv may be different of course.
          • almarhum
            To fix laptop screen vertical line by working on its EDP cable
            by almarhum
            Has one here really gone through fixing laptop screen vertical line(s) by repairing/replacing its Embedded DisplayPort (EDP) cable, so would recount and share the complete steps of the process here now?
            As most, if not all, believe the laptop screen vertical line(s) caused by defective Embedded DisplayPort (EDP) cable which slipped and passed through either laptop screen hinge but post here is asking help to elaborate definitively the useful, real knowledge of repairing in the most complete, correct way, esp. can decide/determine whether the cable can still be fixed or must be re...
            05-07-2024, 02:12 PM
          • Stanley1843
            by Stanley1843
            06-29-2024, 11:54 AM
            HP Mobile Thin Client mt44 Mobile Thin Client 3JG86EA Mobile thin client Specification for Upgrade or Repair
            This specification for the HP Mobile Thin Client mt44 Mobile Thin Client 3JG86EA Mobile thin client can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the mt44 Mobile Thin Client 3JG86EA boardview and mt44 Mobile Thin Client 3JG86EA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
            09-06-2024, 06:50 AM
          • Ryan.man
            by Ryan.man
            02-04-2025, 12:23 PM
          • ahoonid
            MacBook A1990 vertical stripes on external screen
            by ahoonid
            Hey everyone,
            I bought a MacBook A1990 with no screen. I bought it knowing the motherboard was defective but wasn't sure what the problem was until I received it. It actually turns on but as you see from the attachment, it has vertical stripes, on an external screen!!
            The board is neat. Not opened before for sure. Just a little dust, nothing more.
            Recovery using wifi can be opened, as can also be seen in the photo but it doesn't go all the way through after connecting it to a wifi. It downloads the initial Recovery files but never completes the rest of the...
            06-20-2025, 08:54 AM
