Panasonic SS board
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Panasonic SS board
    Has anyone seen damage like this to a TC-P55UT50 SS board?
    No dg302 short just burnt trace.
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Panasonic SS board
    I've seen that kind of damage before on other circuit boards. As long as there are no shorts, run some fine wire/s and give it a try. Most times it worked out that this was the only problem. For some unknown reason the Cu trace just gives way and burn. Perhaps a construction flaw where it was thinner not as thick as the rest of the traces on the board. I saw this many times in CRT TVs
    • tvtimmy
      • Mar 2015
      • 1160
      • usa
      There are 5 thin traces on that side of the board and they all have continuity to each other. I checked a known good board that I have and it has the same. I soldered in a splice and covered it with clear silicone. Both the dg302s were bad, not short but bad.I will have to wait till I get another tv to test my repair.
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
        by sam_sam_sam
        After all of...
        07-13-2024, 08:14 PM
      • canadaboy25
        Panasonic TC-P54VT25 No image. A or D board?
        by canadaboy25
        I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
        The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
        I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
        01-17-2021, 01:06 AM
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
