Sharp LC46D64U Power and OPC Flash
    • 12331
    • U.S.
    Re: Sharp LC46D64U Power and OPC Flash
    One guy traced his same blink code down to inverter 3. one there for 9 bucks, looks like plenty available. https://www.ebay.com/itm/Sharp-46-LC...ZG-r:rk:1:pf:0
    • Icitte
      • Aug 2011
      • 61
      there is a way to test it before?
      • R_J
        • 9625
        I think the manual is a bit misleading, page 62 says error is with DET_10V (pin57) of microprocessor, BUT pin 57 monitors DET_15V (page 104) Trace that back to page 120 and it monitors the UR15V from the power supply
        You might want to get the schematic for the power supply.
        What voltage do you have on the main filter C7820/21
        Check the resistance of R7641, it is a .1Ω/1W resistor that supplies B+ to Q7602 fet
        You say you replaced some parts froma SJ kit, were any of the parts you replace defective? ie shorted fets etc.
          • 12331
          • U.S.
          Read it in this thread. https://www.badcaps.net/forum/showthread.php?t=41621
          • Icitte
            • Aug 2011
            • 61
            /ok I know it's been a while, but I tested the V at C7820/21 one leg is -31vdc and the other one is around 58.8vdc
            R7641 test .1ohm
            hope you will accept to help me again!
            • Superbee_dad
              Sharp 80” long short flash backlight error - Help
              by Superbee_dad
              Hello Sharp TV experts
              Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
              > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
              > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
              01-24-2025, 11:51 PM
            • ekozeko333
              [Help] Lenovo Yoga Slim 7-14ARE05 (DA0LS3MBAF0) – 25Q80DVN1G Flash Is All FF, USB-C PD Stuck at 5V
              by ekozeko333
              I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
              🔥 The Problem Started After Suspected ESD/PD Fault
              I experienced a power issue or ESD event through a USB-C charger
              After that, the NX20P5090 power switch was visibly burned and was replaced
              Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
              🧠 What I’ve Done So Far
              Flashed...
              06-21-2025, 02:48 AM
            • corrize
              Nikon D800 camera - flash don’t work and capacitor don’t charge
              by corrize
              Hello, I'm stuck in troubleshooting…
              The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
              In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
              When I press the flash button, it's detected by the system, flash icon appear on LDC display....
              10-01-2022, 10:02 AM
            • yucel-yucel
              Sharp LC-39LE652V Nand Flash
              by yucel-yucel
              Sharp LC-39LE652V model device could not be opened due to nand software error, we rewrote the nand software and it worked. But we were able to find the software without satellite, it does not see the internal satellite. Does this model have a working satellite version and software? Thanks in advance.
              Model ; Sharp LC-39LE652V
              Panel ; V390HK1-LE6
              Mainboard ; QPWBXG135WJZZ
              04-06-2023, 04:57 AM
            • spmetroil
              Request: SPI Flash BIOS Dump (Winbond 25Q128) for Dahua NVR4216-4KS2
              by spmetroil
              I am trying to repair a Dahua NVR4216-4KS2 that is not booting.
              The main BIOS/firmware is stored in an SPI flash EEPROM (Winbond 25Q128, labeled as U130 on the PCB).
              I have a CH341A programmer and I already attempted the following steps:
              1. Identified the correct chip (W25Q128, 3.3V SPI flash).
              2. Tried to read the contents with CH341A Programmer software. The dump seems corrupted and I often get the error: “Chip with the contents are in disagreement.”
              3. Compared several chip type selections (24Cxx and 25Qxx families) to confirm it is indeed a 25 series SPI
              08-19-2025, 09:23 AM
