Sharp lc55cuf8472es
  • kiko1
    • Apr 2016
    • 48
    • croatia
    Sharp lc55cuf8472es
    I can power it up through keyboard(there is no RC)...it powers up but it's stucked on changing RGB colors...like old LG PDP-s when you put them in test mode through the jumper on small board in the center...
    anyone?
    tnx....
  • nomoresonys
    • 12328
    • U.S.
    Re: Sharp lc55cuf8472es
    Try a firmware update/replace if possible.
    • kiko1
      • Apr 2016
      • 48
      • croatia
      Solved!
      With keyboard buttons...but I am not sure in sequence..."MENU" and "SOURCE" and then power on, or only "MENU" or only "SOURCE"...after that disconected from mains,wait few mins and power on....voila!!! SHARP logo and first time instalation screen...
      • MMH3
        Dell Optiplex 5050 SFF - strange behavior and service_mode jumper not working anymore
        by MMH3
        i have many 5050sff. all of them, and how i experienced over many years for all about 250 DELLs goin through my hands, are fully flashable and can be serviced in any way when the service_mode jumper is set.
        Never ever i experienced problems with that.
        Now i have one 5050sff machine, where this jumper isnt working at all.
        I do not get the normal messge that the jumper is set when booting and a short test with FPT just confirms this. Everything is locked -->> EVEN for reading !?
        The history of the machine is that i used it in my office...
        03-23-2025, 09:28 PM
      • blankdisplay
        HP EliteDesk 805 G8 "PSWD" Jumper
        by blankdisplay
        Apologies, I broke a rule and hijacked a thread, so I deleted that post.
        I am curious if anyone here owns the G8 or has good quality board shots?
        I've done some googling and curious if the 805 G8 series has some kind of jumper?!
        The 800, G3 series, much older, the maintenance and service guide, clearly talks about a PSWD jumper
        https://cdn.badcaps-static.com/pdfs/...cc246ac326.pdf
        I also believe it's just visible in this shot:
        https://www.servethehome.com/wp-cont...-EliteDesk-800...
        10-22-2023, 02:43 AM
      • advant
        by advant
        02-03-2020, 12:25 AM
      • sefoster
        Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
        by sefoster
        I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
        11-20-2022, 09:29 AM
      • gavenb
        Sharp LC-80LE661U 80 inch
        by gavenb
        Hi folks!
        I have a LC-80LE661U that had some interesting issues.
        Initially, it would come on and show the sharp logo and would show normal static before shutting off.
        I started troubleshooting by disconnecting the led lighting strips and turning it on. It would do the same thing - come on, show the sharp logo and shut off. After reading, it was suggested to replace the main board. That was replaced and the same symptoms resulted. After this and some reading, the parts cannon got loaded up. I replaced the power board, same issue. Replaced the Tcon board and now it...
        11-12-2023, 02:05 PM
