Sansui TV2510: La8517jg
  • Acca
    • Jul 2017
    • 47
    • Italy
    Hello boys,
    I need to fix this sansui tv, it works fine for a while, then, when it gets a little hot, the screen goes white and it won't accept commands from ir and buttons until it cools off.
    I found out this LA8517JG thing, that is a 3A/23V Step-Down DC-DC Converter, stops working when it gets hot, infact it outputs only 2.6v instead of 5V, as soon I spray it with the freezing spray it starts working again and tv works normally.
    Problem is I can't find it anywhere that is not on aliexpress and even then they don't provide a spreadsheet to be sure I'm not waiting a month for a thing I don't need. I found an auction on ebay but it's sold as an audio processor
    Anyone knows if there's something I can use instead?
    Re: Sansui TV2510: La8517jg
    https://www.ebay.com/itm/5PCS-X-LA85...xThe:rk:3:pf:0
    BTW, the input and output filter caps are OK in that section?
    • Acca
      • Jul 2017
      • 47
      • Italy
      Yes they are.
      Thanks for the link, the ship from china, so 30 days wait time.
      The reason I was looking for a datasheet is because I found a listing on ebay where they are listed as "5PCS LA8517JG Audio Signal Processing Circuit SOP8 IC"
      I guess I'll have to wait and order from china.
      Thank you budm for your reply.
      • neilc6
        • Nov 2015
        • 1550
        If you order Aliexpress Standard Shipping or Epacket, shipping takes 1-3 weeks. Economy shipping takes 1-3 months or more (mainly due to custom delays). This applies to Canada. Not sure for SA.
        • Coert van Dorsten
          Sansui Integrated Amplifier replacement volume control troubles
          by Coert van Dorsten
          Hi all you clever electronmic gooroos!
          I was wondering if you could help me with the below issues Im having on a Sansui Integrated amplifier. I bought this unit as a project to repair as Im playing around with basic electromics.The unit has a faulty volume control pot. The service maual refers to a 150K Logarithmic pot (A) tapered stereo. Im struggling to find this value. Seem to be a jump from 100K to 250K. Im now trying a 250K pot. It works but the problem is that as the volume is turned up from starting at Min the Left channel will come on first just slightly before the Right...
          10-15-2025, 02:54 PM
        • Hornnumb2
          Sansui sled4019 dim picture
          by Hornnumb2
          I have a sansui that just started having a dim picture, adjusting backlight settings up or down have no effect on display. I went ahead and ordered some backlight strips for it but find it weird that changing the setting has no effect. Could it be power related. Where should I start? Thanks Michael ...
          08-31-2025, 10:37 PM
        • Hornnumb2
          by Hornnumb2
        • Neddsme
          SANSUI SLEDSC-32HD TV not booting, No stand-by led
          by Neddsme
          I have a 32 inch Sansui android TV that stopped booting. i checked the motherboard for any power failures but it seemed OK to the best of my knowledge. The TV does not have a dedicated power supply board so i could not do any isolation but here is a list of all the things i think were relevant to test.
          if i missed anything you let me know;
          DDR (1.5V) = 1.484V
          VDDC = 1.000V
          VDDC_CPU = 1.151V
          VDD1V2_DM = 0.000V
          3V3_STB = 3.315V
          3V3_M = 3.307V
          1.8V_M = 1.803V
          ALL KEYS = 3.310V
          5V_STB = 5.142V
          5V ...
          11-02-2023, 01:33 PM
        • woaimi
          Sansui G-7700 receiver blows fuse
          by woaimi
          A colleague gave me this Sansui receiver. He mentioned it was still playing until recently (couple weeks ago) lost its power and he thinks it blew the fuse. I brought is home opened up and sure enough the 10A fuse is blown. I found a spare one at home put it in and instantly blew that one too. I'm hoping some experienced users here would direct me in the right direction to bring this nice piece of art back to life. Having read through some posts in the other forum regarding this receiver, I realized this is not an easy task but possessing a nice Sansui G-7700 and learning new skill that what got...
          09-21-2020, 01:28 AM
