Vizio E65U-D3 replacement led info needed
  • mu2
    • Oct 2009
    • 217
    Does anyone know what led's are used on the strips of a Vizio E65U-D3?
    Shop Jimmy has the replacement strips listed but they are backordered.
    Their number is SVG650A28-REV05-LED-STRIPS. I might try to replace the individual defective leds if I can find a source.
    I'm wondering if the strips use the same LG/Innotek leds used in the 50LN series of LG tv's which I think are 3 volt 1 watt.
    Thanks,
    Mike
    Re: Vizio E65U-D3 replacement led info needed
    You need to match the LED strips based on LCD panel model number.
    • mu2
      • Oct 2009
      • 217
      Budm,
      Thanks for the response. Yes, I'm aware that I need to do that before ordering.
      Shop jimmy only has one set of replacement strips listed for that model. Could be that's the only one they stock and there are other strips used in different panels.
      I don't have the set yet but will be picking it up Saturday. I'll find the panel and complete model numbers at that time.
      The tv is only about 1 1/2 years old. Fortunately, the owner bought a one year extended warranty. She will get store credit for a comparable tv since they decided they couldn't fix it.
      Mike
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • howardc64
        Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
        by howardc64
        Failure Symptom
        No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
        Where is the short?
        Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
        Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
        05-27-2025, 02:56 PM
      • smort
        Backlight Polkadarks
        by smort
        Soooo, I found someone giving away their 70" Vizio TV because it wouldn't turn on. Hoping it would be just some bad caps, I snapped it up. No dice. No bulging caps. TV would start consuming about 7W immediately after plugging it in, but no response from the remote or power button. Thermal showed the main chip on the mobo getting warm and nothing else. Power supply appeared to deliver stable 12V to the mainboard.
        I ordered a replacement mobo(actually both mobo and PSU just to be sure) and popped it in. Picture! Sound! Endorphins! Then I noticed three long dark strips. Hmmm, had...
        03-11-2025, 12:33 AM
      • mc900fthanna
        Visio M70-C3 LED replacement strips
        by mc900fthanna
        So... I have the patchy back light issue with my Visio M70, meaning some light up, others do not. I finally got around to testing the LED driver board and found that was not the issue (swapped another one in and the same issue persisted) and I am considering if i dare dive deeper into this TV and go after the LED strips.
        Right away i see that they don't seem to stock them anywhere out there (E700DLB0016-002) is a part number that i see a you tube / seller guy list out. He has a nice video of how to get into my exact TV out there: https://www.youtube.com/watch?v=0AcUPiN83Tg
        11-28-2022, 03:03 PM
      • lmcancu
        RCA RLDED 4331B: 43 inch LED TV: Backlight issue
        by lmcancu
        Hi I am having an issue with the LED backlight of this TV. I can see the picture with a flash light, so I determined it was a backlight issue.
        Initially, after opening it I found 2 shorted and 1 open LED on 2 strips (total of 4). I removed the LEDs and shorted the pads together to verify if the backlight would work.
        Testing it, I found the backlight turned on and I measured 54V when TV was in standby (off), and 100v when TV was turned on. The 4 strips each contain 9 LEDs, so 36 in all minus 3.
        Instead of putting it back together I decided to replace...
        04-01-2023, 01:11 PM
