Protecting a horizontal output transistor
+ More Options
Posts
  • angelos
    • Dec 2012
    • 563
    • South Africa
    Howdy. I get in these CW62C chassis 29 inch LG crt tvs with blown line output transistors and normally all one does to repair them is to replace the 20nf 2kv cap but unfortunately all i can source cheap is fake spares that blow 2 seconds after switch on. The original is a 2SC6090LS but thats become obsolete so now we get supplied with a ST1510FX but these are fake too. I am now being forced to buy the original transistor from the agents at a very high cost. Is there a way i can protect the transistor on switch on? I have my handy 100x probe and would like to view the collector pulse on the transistor.
    Your help on this will be greatly appreciated
    Re: Protecting a horizontal output transistor
    The problem is that the fake device may have low breakdown Voltage that is not high enough to be used in the circuit as required. It is like trying to use 100V rating diode in place of the 1000V rating diode, nothing you can do to solve that.
    • dick_barton
      • Aug 2015
      • 6642
      • Wales
      I don't know if this would help you but it does give details on some high voltage LOP transistor.
      https://cdn.badcaps-static.com/pdfs/...68d3c338c3.pdf
      • jetadm123
        • 2169
        My guess would be the fake devices are using a smaller die than the originals and cannot handle the higher current. Is the genuine transistor slightly heavier than the fake? You could also open them up and compare the two. Regardless, there's nothing you can do if the fake transistors don't measure up electrically to the original. Why don't you contact a reputable parts supplier and find out if they have a genuine in stock substitute for the original?
        • petehall347
          • Jan 2015
          • 4426
          • United Kingdom
          https://uk.farnell.com/stmicroelectr...ngdom%2Fsearch
          • angelos
            • Dec 2012
            • 563
            • South Africa
            I send an email to ST Microelectronics asking who is their distributor in south africa but i got no response.
            • jetadm123
              • 2169
              Maybe: Avnet South Africa. 202 Chelmsford, 2nd Floor, Essex Gardens Nelson Road, Westville Durban, South Africa Phone:+27 (0)31 266 8104.
              Also try contacting Fairchild or International Rectifier.
              • FrancescoV
                Onkyo HT-R390 no sound output, video output ok
                by FrancescoV
                Good morning everyone,
                I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                The firmware reported is the following:
                M:1.00/11107BLP
                D:?.??/????????
                O:1.00/11107AL
                The DSP firmware given the question marks seems corrupt.
                On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                05-11-2025, 02:59 AM
                NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                by sam_sam_sam
                I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                I bought this from an eBay seller but unfortunately they only had one
                I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                I bought three of from them to also make battery packs with this output power limit in mind
                I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                04-23-2025, 05:50 AM
                Corsair CX750M [Model 75-002019] - burned output toroid inductor
                by momaka
                Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
                So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
                09-19-2021, 08:44 PM
              • CoppellTVRepair
                Troubleshooting PFC with SPC1012T not raising output
                by CoppellTVRepair
                It has been a long while since I posted here to ask anything....hope you can help.
                I have this Samsung power supply that uses SPC1012T as driver for the PFC and it's giving me a problem that I can't narrow down though I've troubleshooted and fixed hundreds of boards similar circuits.
                I am attaching a schematic from a different Samsung board, but the topography is very very similar if not 100% the same and it uses SPC1012T, which BTW is a pinout match to UCC28063 for which there's plenty of information. I haven't confirmed they are functional equivalents, but I strongly...
                03-09-2025, 10:38 PM
              • flibidy
                Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
                by flibidy
                I have here a Magnum IA.100 which belongs to my parents.
                The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
                Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
                What Ive done........
                01-01-2025, 01:26 PM
