philips 32hf7875/10 blocked?
  • Joe Black
    eager to learn
    • Sep 2015
    • 173
    • southeastern europe
    Bought this TV cheaply, and it came with italian menu setting.
    Found wierdly litlle options in menu, and while fiddling with it, out of curiosity,
    turned the option "BLOCK THE BUTTONS" ON.
    Now I can not acess the menu anymore, can use VOL and CH controls on remote, change inputs and all, but cant access the menu, neither from remote or TV-button. When I try, it says "blocked".
    Any insight on this or curiosity killed the cat
    stay classy
  • petehall347
    • Jan 2015
    • 4422
    • United Kingdom
    Re: philips 32hf7875/10 blocked?
    turn that setting off
    • Joe Black
      eager to learn
      • Sep 2015
      • 173
      I can NOT acess menu anymore....
      stay classy
      • bobbyskillz
        • 75
        The user manual indicates you need a special "Setup Remote Control" to be able to turn the button lock off.
        The setup remote control is green. P/N RC2573.
        Maybe you can change the language, too, if you have the setup remote control.
        • Joe Black
          eager to learn
          • Sep 2015
          • 173
          Nice
          Maybe that´is why it was cheap in the first place.
          I do not speak Italian, but I am sure there was also no search programs and similar options in the menu. Only picture, sound, and this option I have used so cleverly.
          Can anyone confirm that I have to buy one more remote for TV to work properly, aside of having one already?
          stay classy
          • Joe Black
            eager to learn
            • Sep 2015
            • 173
            Did a google research.
            As far as I can figure out, these SETUP remotes for Philips are simply remotes that can be SET UP for various devices (via codes)?
            But someone had to stumble upon these issues?
            stay classy
            • jetadm123
              • 2169
              Possibly this TV was made for the hotel market, which locks the menu because the hotel obviously doesn't want the guests playing around with the menu settings.
              • Joe Black
                eager to learn
                • Sep 2015
                • 173
                Yeah, possibly. However, I had menu unlocked when I got it. And I can still change inputs, channels, volume, and other stuff. Only since I fiddled with settings it says blocked.
                stay classy
                • bobbyskillz
                  • 75
                  That model was designed for hotels and other hospitality organizations. It's probable it was unlocked before resale - or never locked at all. The setup remote controls are available for cheap on eBay and Amazon. Maybe you can borrow one from a local hotel that uses them. 32" is small enough to bring with you.
                  • Joe Black
                    eager to learn
                    • Sep 2015
                    • 173
                    Thanks, I am going to order one and give it a try.
                    Will post results for future reference, many thanks guys!
                    stay classy
                    • Joe Black
                      eager to learn
                      • Sep 2015
                      • 173
                      Here is an update for reference of others in need:
                      There is an option in TV menu which sets security level to STANDARD/HIGH.
                      When STANDARD, you can use a special code for your TV (Google) and unlock it.
                      When HIGH, you MUST HAVE setup remote control, no workaround.
                      What I did is that I simply locked keys on TV which I could by then use to acess the GUEST version of the menu with only couple of options. Would have to find setup R/C anyways.
                      Now, hopefully I will order the right one from the first try.
                      Thanks all
                      stay classy
                      • tom thumb
                        • Jul 2013
                        • 66
                        try from the remote 3 1 9 7 5 3 mute
                        that is one of the codes that will get you into the hospitality menu from there you can change security
                        I had 100 motel tvs donated to where i work and philips gave me this info
                          LCD LED TV Service Menu Codes
                          ALL LCD LED TV SERVICE MENU CODES
                          Service Menu Code with Board Name
                          China Universal Board / Jumper Board Service Menu Code
                          Changhong Ruba Service Menu Code
                          Ecostar LED TV Service Menu Code
                          Orient LED TV Service Menu Code
                          Haier LED TV Service Menu Code
                          TCL LED TV Service Menu Code
                          Samsung LED TV Service Menu Code
                          LG LED TV Service Menu Code
                          Videocon LED TV Service Menu Code
                          Supra LED TV Service Menu Code
                          Toshiba LED TV Service Menu Code
                          Symphony LED TV Service Menu Code
                          Veste/ LED TV Service Menu Code...
                          10-31-2024, 03:58 AM
                        • Ierwin
                          Philips 58PUS7805 Menu working but no/weird picture from video sources
                          by Ierwin
                          I got a 58pus7805 that shows some weird behavior.
                          The menu and remote work fine and the picture is looking crisp and flawless while navigating the menu.
                          However, when a video source is displayed the screen either goes solid green (HDMI), solid black (SAT TV) or shows some fragments on mostly green background (AVI Playback from USB).
                          I tried to reinstall the firmware through the menu which was rejected saying it already had the latest version.
                          I managed to install the latest official firmware by holding the control button while plugging...
                          03-10-2024, 12:50 PM
                        • digitel
                          Philips BDP5180/12 Blue-Ray "logo" in image. blocked
                          by digitel
                          hi
                          The device is connected via HDMI to a TV. It turns on with the power key and the "Logo" appears in the image; but the device does not respond to any order from the control and/or keyboard.
                          Does not open tray.
                          Not even the front display lights up.
                          Voltages in the connector from the source to the main are correct, according to serigraphy.
                          Voltage from the connector to the front display, they are fine.
                          Display filament powered.
                          BGA memory ICs have a temperature between 36 and 39 degrees Celsius.
                          I have not tried to update...
                          11-25-2022, 11:59 AM
                        • Retro140
                          Unnlock Menu for 2007 DU-27FB32C comerrcial CRT TV
                          by Retro140
                          So I was referred here when I made this poste over on AVForums: https://www.avsforum.com/threads/loc...lg-tv.3257234/
                          To summarize, this is a commercial TV and I can't get a menu of any kind. I know the overlay is working because when I change channel, adjust volume, turn on sleep timer I do see text. But I have not ever seen the user menu nor the installers menu. I've tried a bunch of remotes(more info on the AVF post) and tried every button...
                          06-18-2023, 06:13 PM
                        • vf fa
                          EIZO CX270 - No signal but Backlight and Panel works, logo works, admin menu works. OSD doesn't. What?!
                          by vf fa
                          Hi, so i guess I´ll have to make a new topic here, as i browsed through hundreds of other threads but couldn't find a solution to my problem yet.
                          I got a EIZO CX270 from a friend. He said it doesn't work anymore and wont display any signal or take any OSD inputs. Well, as an aspiring photographer I couldn't say no, could I? Thought it was an easy game, replace a bad cap and have a working monitor. But nooope, it wasn't supposed to be this easy.
                          So let me start with the problem description. I'll try my best not to skip anything so this might get rather long.
                          01-31-2024, 01:40 PM
