Blaupunkt 40-133Z-WB-5B2-FGKU-UK weird standby problem after power cut.
  • Finnthedude
    • Sep 2018
    • 8
    • England
    Hi all, hope someone can shed some light on this. I live in a building that gets regular power cuts and it has affected my Blaupunkt TV. After a power cut, when the power comes back on the TV has NO standby light and will not turn on. If I switch the TV off with the on/off switch on the side and leave it about an hour, when I turn the switch back on the red standby light is back and the TV will then switch on with the remote as normal. TV then works flawlessly until the next cut.
    Any ideas? It's been a good TV and it was a gift so I don't want to throw it out until I've explored every possibility of me fixing it myself. I'm a mechanical engineer so stripping it doesn't worry me but I'm a novice when it comes to modern electronics.
    Thanks in advance.
    Finnthedude.
  • petehall347
    • Jan 2015
    • 4426
    Re: Blaupunkt 40-133Z-WB-5B2-FGKU-UK weird standby problem after power cut.
    might be normal operation .. used to have a pc power supply like that . best thing i can suggest is a ups . then in case of power cut you can switch it off properly .
    • Finnthedude
      • Sep 2018
      • 8
      • England
      What I forgot to mention is that this problem has only recently started happening. It used to just be fine when the power came back on - it would be just as it was before the power went out, i.e. the standby light would be on and I could use it as normal. So something has definitely gone wrong somewhere.
      UPS is a good idea though. If I can fix it I'll get one.
      Thanks,
      Finnthedude.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8158
        verify that you get stby voltage to the main board when that LED is off. If it does it is the main board. Try doing a factory reset and see if that does something, maybe flash a new firmware, check if there is some stupid power fail setting or something in the menu etc.
        • Finnthedude
          • Sep 2018
          • 8
          • England
          Thank you all for your help so far.
          I tried a factory reset but no good and there's nothing in the menus about power fail settings. I'll get the back off and check the voltage to the board this week sometime.
          I've never tried flashing a firmware, as I said I'm a novice with electronics but I'll give it a go when I can find a how to guide.
          It's so frustrating, it's so close to working perfectly that I can taste it. I'm sure we'll work it out.
          Finnthedude.
          • Finnthedude
            • Sep 2018
            • 8
            • England
            Some additional info after testing. When the led is off there is power from the switch output and power to the main board but no operations and it won't turn on. Unplug it for an hour then plug it back in and the standby led comes on and get the same reading to the board. This is a repeatable operation and gets the same results every time.
            I've bought a UPS as it's only short power cuts we have so hopefully that's a makeshift fix. It's a shame we couldn't find an obvious culprit but I suppose that's the nature of the beast with electronics.
            Finnthedude.
            • Finnthedude
              • Sep 2018
              • 8
              • England
              Got a reply from UMC-UK (who are basically Blaupunkt UK) and they say it's a software problem and have sent me an update to put on a memory stick and that will sort it.
              Bit of a dilemma now as since I got the UPS the power cuts aren't a problem any more. I think I'll leave the update until I HAVE to turn the TV off for some reason and do it then.
              Many thanks to all who helped, it is much appreciated.
              Finnthedude.
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8158
                why would you wait? Just update it and try it.
                • Finnthedude
                  • Sep 2018
                  • 8
                  • England
                  To update it I have to intentionally shut down the power (the usb has to be inserted with the TV unpowered - the exact state when it messes up). At the moment it is working fine with the UPS. In the email from UMC there was a warning that the update might brick my TV.
                  So that's why I'm waiting. It's fine now and the update is a risk.
                  Finnthedude.
                  • dick_barton
                    • Aug 2015
                    • 6642
                    • Wales
                    Do you normally leave the set in standby or powered off at the mains. It could be that if you normally leave it in standby then when you lose the mains supply due to the building outage is indicating that some of the capacitors on the power supply need changing.
                    • yohnsee
                      Semi-noob
                      • Dec 2017
                      • 198
                      • Hungary
                      these TVs are famous (at least in my country) of having issues with eprom.
                      Usually, when someone asks a question like yours, I tell them to have a look at the mainboard, identify the eprom chip, order a new one and copy the contents of the old one while it still works. Because with time it only gets worse. If the chip itself is not faulty, then yes, a firmware update helps. But if it behaves the same after update, then you should consider my approach.
                      This also applies to the other "famous" brands, who use these chinese T.MSD and other pain-in-the $$$ motherboards.
                      Cheers, Janos
                      • Finnthedude
                        • Sep 2018
                        • 8
                        • England
                        Always left on standby. Couldn't see anything obvious with the caps when I had the back off but didn't test anything.
                        We'll see how it goes. Removing and programming an eprom is way beyond my skill level at the moment. If it dies altogether I'll give it a go but as I said the UPS has cured the problem for the time being.
                        Thanks again everyone for the advice.
                        Finnthedude.
                        • petehall347
                          • Jan 2015
                          • 4426
                          see how it goes ..if it is caps you might find complete power supply failure one day with possible blown fuses and components ..recently happened to one of my tv.s .
                          • grimacelord
                            NEC TurboExpress On/Off Power Switch Replacement Help
                            by grimacelord
                            I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
                            I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
                            I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
                            11-09-2023, 09:49 AM
                          • SkishyIshy
                            Sony Bravia XBR-65x900f: No Power, No Standby-light - however 3.3v STBY is present
                            by SkishyIshy
                            Hey All,
                            I have a Sony 65x900f that I purchased cheap because of a no-power issue.
                            I assumed that because there is no standby light visible, it would be an easy fix - however upon opening up of the unit I can confirm that the 3v3 standby voltage is making it's way from the power supply to the main board. I'm a little confused as to why there is no standby light.
                            I am firstly wondering if anyone has this model of TV, or has worked on one and can give me some insight. I have tried to find a service manual for this model, to no avail - and would really appreciate...
                            03-17-2021, 11:44 AM
                          • PantherDave
                            by PantherDave
                            Hi all!
                            05-29-2024, 02:01 PM
                          • AleMonti
                            LG 55EG910V - no power and no standby light
                            by AleMonti
                            I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
                            I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
                            The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
                            After checking the basics I did the following:
                            • I measured all voltages and as expected the only active supply is the 3.5V standby. It
                            11-04-2024, 05:02 PM
                          • noinimod
                            Sony 55X900E no standby light, no power. Replaced mainboard already
                            by noinimod
                            No standby red light, nothing
                            This Sony has a separate AC->DC power adapter supplying 19.5V to the TV power board (JK3)
                            Disconnected JK3 power board from main board, checked voltages on all the pin outs
                            At a few pins I can see the power supply providing 19.5V to the main board
                            Based on the service manual triage.. it seems to be pointing towards the power board (JK3) being the most possible culprit
                            LED light turns on when I disconnect LED driver board ribbon from mainboard (so i thought it is the mainboard,...
                            12-22-2021, 12:58 AM
