I have hahitachi 65L6 that gets no power i have tested the 5v standby and no 5v. here is the pic of the board any help of where to start?? Thanks.
hitachi 65l6 no power
Re: hitachi 65l6 no power
History of the TV?
What DC Voltage do you have between the two legs of the main lytics 450VDC filter caps?
Please provide closed up pictures around the connectors so we can read the pin name for each pin.Never stop learning
So BOTH filter caps show around 157VDC?
I need good clear straight shot of the whole Bottom side of the board to be able to trace out the ciruitNever stop learning
If you run the power supply board by itslef without having it connected to other board, does the 5VSTBY show normal?
BTW, you did verify those rectifier diodes on the cold side are good, correct?Never stop learning
Originally posted by johnz View PostThe 2 startup/running caps they just jump all over the place. Th 6 barrel starting from the top 1=31.7
2=31.7
3=0.0
4=0.0
5=0.9
6=0.9
You know how to test diodes, correct?Never stop learning
Thanks for the follow-up on the repair.Never stop learning
