This is on Craigslist near me. Does it look like t-con issue or panel problem? Owner says it’s not all the time like that.
Phillips 55PFL5601/F7
Phillips OLED TV 55P0S9002/05 715G8886-P01-000-004Y Schematic
Brand: Philips
MPN: 55POS900255
GTIN: 8718863012352...-
Channel: Schematics and Boardviews
11-05-2024, 02:45 PM -
by grimacelordHi. I have a Phillips 55PFL5601/F7 here with some problems that I can't pin-point the cause of.
Some history on the TV, it was brought in to me after it suffered a power surge/lightning strike. I was able to find both the power and the main board pretty cheap and for the sake of time, I went ahead and bought both. Replaced both the main board and the power supply board and the TV exhibits the same symptoms as it did with it's original boards:
1. No standby LED.
2. No display.
3. Voltages on the power supply side fluctuate wildly, not stable.
4. One... -
by learnmoreHello Community,
Would welcome any help on getting a service manaula for the above model (Phillips 75PUS6754/12) TV or anything similar.
Picture intermittently works fine for a day or a minuite then goes off, but backlights appear to remain on.
I thinking troubleshooting TV or using a tape method on the panel but would like some guidance on tracing the signals accurately rather than a trail and error.
Thanks in advance,
LM -
by BloopetaPhillips 58PUS7805/12, was told it had sound no picture, sometimes picture would come back then go again?
From what I have seen myself, its just blank illuminated screen. Tried unplugging each ribbon cable from Tcon in turn.
When one is unplugged, I get half sceen, clear picture.
With other unplugged, get half screen but with thin horizontal lines
Any ideas? Or is it likely a bad panel?... -
by awyatt2Phillips 65pfl6502 I came across this set stuck on ble screen, no menu no sound all inputs dead. I'm thinking main board. The tcon wouldn't stop sound. Right or wrong.
- Loading...
