TCL Black screen
  • "AD"
    • Mar 2014
    • 37
    TCL Black screen
    Hello there!
    I need help troubleshooting a TCL model 55FS3750. What I'm getting when I turn it on is just a black screen. These are the things I have done so far:
    1) I removed the back cover, and I can see the while light through the holes, so I think I have back light.
    2) If Im standing behind the TV, and I remove the left cable of the T-Con board, that half (left side) of the screen turns while, and the other half (right) displays good image.
    3) If I do exactly what I did on point 2, but on the other side of the T-Con card, the whole screen remains black.
    I originally assumed I had a bad T-con card and bought another. Used; of course, but I get exactly the same issues.
    Do you guys think I might have purchased a bad T-Con card with the same problem, or it's more likely the source of the problem is something else?
    Thanks in advance,
    AD.
  • zomi
    • Nov 2011
    • 513
    Re: TCL Black screen
    You have a short on that side of the panel
    Look on the pcb connected to the lcd on the side with no picture
    and check the capacitors for shorts.
    Remove and that tested shorted and test them off the board as well
    If you get lucky will be 1 or 2 shorted caps..
    Thats where i would head next.
    Tcon looks good to be honest.
      Yep, look for shorted caps on the Tb bonding board first on that bad side of the screen.
      • "AD"
        • Mar 2014
        • 37
        Thank you guys,
        I will do that next this afternoon and share results.
        Regards,
        • "AD"
          • Mar 2014
          • 37
          Hello Guys,
          I was really hoping to open it up, and find something obviously wrong, but it seems normal to me. Unfortunately, my cheap multimeter from Harbor Freight does not have the function for the continuity with the beep, I'll get a better one, honestly it's long overdue.
          That being said, what I tried to do as a test (please tell me if it was a bad idea), was putting the ground lead to a ground on the board, with the tv connected and on, and measure voltage at all the capacitors. Voltages did vary among the capacitors, but there was a few of them that gave me 0v at either leg, so I'm guessing those could be bad?
          I'll attach the pictures of the pcb (I split it in 3).
          Also, >if< those are bad, how do I know what are the capacitor's specs to replace them?
          Thanks in advance.
          AD
            You have two ribbon cables from the T-CON board to those tab bonding board, where is the pictures of the bad side that you disconnect?
            Just start checking the resistance to see if any one of those SMD caps (on the bad side of the tab bonding board) have low resistance or not.
            • "AD"
              • Mar 2014
              • 37
              Hello, Thanks for answering,
              Those 3 pics are the ones of the bounding board connected to the side of the T-CON with the bad image. I just split them in 3 so the image will not get too blurry when zooming in (to look but an obvious damaged capacitor). Attached is the picture of the hole thing. In this case, is the side with the ribbon cable I marked as "1".
              • kca
                by kca
                Hello all ~
                08-31-2025, 06:38 AM
              • x_orange90_x
                TCL 50S535 bad tcon or panel issue?
                by x_orange90_x
                Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                03-29-2025, 11:02 PM
              • HTR-Informatique
                by HTR-Informatique
                02-09-2025, 06:51 AM
              • VcemPzd
                Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                by VcemPzd
                Hello everyone !
                My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                04-28-2025, 10:14 AM
              • howardc64
                by howardc64
                Problem
                08-04-2024, 10:36 PM
