Bush LED32982HDT video / image problems
+ More Options
Posts
  • notallbad
    • Oct 2012
    • 1190
    Colour problems and image retention.
    Replaced the T-Con board but still the same, guess it could be possible the Ebay board is also faulty but sold as working and tested so have no reason to disbelieve them.
    Tried factory reset in Service Menu but still no change.
    Exactly the same symptoms on both HDMI 1 & 2, Scart and USB video playback.
  • ducky29
    • Dec 2015
    • 369
    • Europe
    Re: Bush LED32982HDT video / image problems
    Try changing the panel type on the service menu.
    • notallbad
      • Oct 2012
      • 1190
      There doesnt appear to be an option to do that on this tv. Mostly all options are 'read only'.
      • ducky29
        • Dec 2015
        • 369
        • Europe
        Have you tried flashing a firmware?
        • notallbad
          • Oct 2012
          • 1190
          If I could find one I would!
          17MB62-1 V3
          • vinceroger69
            • Mar 2012
            • 6714
            what lcd panel number is used in the tv also can you post a picture of the back panel sticker as may have more nfo on that too thanks.
            • notallbad
              • Oct 2012
              • 1190
              LG Panel : LC320EXN (SD)(A1)
              • notallbad
                • Oct 2012
                • 1190
                Not sure if this also helps but the panel label also has this printed on it.
                320ACWAK016DB K85C
                Not able to add photos at the moment, sorry.
                • notallbad
                  • Oct 2012
                  • 1190
                  Just for info:-
                  Tuner type : LG18273
                  • notallbad
                    • Oct 2012
                    • 1190
                    Read this from the chip so could possibly be corrupt but thought it might be of use to someone
                    • notallbad
                      • Oct 2012
                      • 1190
                      Attempted to dump the firmware via scart to no avail.
                      Possibly something not configured right or its not possible to do it from this main board. Pins 10rx,12tx & 13 gnd, 115200baud,1n8. Power on tv and just get 2 "null" 's, and get 1 "null" when tv powered down.
                      Perhaps it needs to be interrogated with cmd's rather than just automatically dumping out the fw.
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        do you know the back ground of this tv? could someone else replaced the tcon board with the wrong one and you have also replaced it with the wrong one?
                        maybe pm ducky29 and see if he can get you the correct firmware i see he has helped a few members out with firmware.
                        • notallbad
                          • Oct 2012
                          • 1190
                          Thanks vince, shall pm him!
                          Unfortunately there is no history known other than given to me as not working properly. It had crossed my mind that the tcon could have already been replaced once and both could be incompatible. Replacing the firmware and possibly the i.c too or the main bd entirely would surely eliminate a few possibilities.
                          • notallbad
                            • Oct 2012
                            • 1190
                            thanks
                              T-CON for that LCD panel you provided: https://www.shopjimmy.com/lg-6871l-2...-con-board.htm
                              • notallbad
                                • Oct 2012
                                • 1190
                                thanks budm
                                that confirms its the right tcon bd but neither are working so looks like its either a faulty panel or main bd.
                                The tv looked undisturbed inside before replacing the tcon, tape over the shield was intact.
                                  What you are seeing on the screen is due to bad GAMMA Voltages.
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    budm are bad gamma voltages all produced by the tcon or could a faulty mainboard give bad voltages that the gamma ic uses if any
                                    • Andrew F. Ali
                                      • Jan 2014
                                      • 2450
                                      • Trinidad & Tobago
                                      Gamma voltages are all produced by the T-CON Bd and a faulty Main Bd. would/could only produce loss of LVDS and 5/12V. All voltages produced by the T-CON Bd. are derived from the 5/12V supplied from the Main Bd.
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        Thankyou so he may of received another faulty tcon there does not seem too be many gamma voltage test points on that tcon so maybe best just swap it out again.
                                        • Jaime Morillo
                                          Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                                          by Jaime Morillo
                                          Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                                          The TV was stuck on the logo and I couldn't access the update menu.
                                          I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                                          The image result was good, but the image is inverted.
                                          The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                                          Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                                          08-18-2025, 11:38 AM
                                        • Kiks412
                                          BENQ MP511 Video Projector - No Button Responce and wierd Image
                                          by Kiks412
                                          Hey guys, I have this Video Projector that turns on, takes a bit to give some image, and when it does it displays a weird static image, and has no reaction to on-device buttons or remote whatsoever, even to turn off, only unplugging from the outlet. I'm new to this kind of device so I will be very happy to get some help with this....
                                          12-20-2022, 10:00 AM
                                          GeForce RTX2080 Super Aero video gaming card issues help need
                                          by sam_sam_sam
                                          This is from my son’s gaming computer that at first had minor overheating issues when playing a very intense game with it causing the computer to crash or reboot
                                          Then bough a new motherboard and a new computer case that a cooling system in it already installed also brought the cooling system for this video card but now the issue with it is that it randomly rebooted screen goes blank randomly and suddenly video freezing or started with video being there then blank screen and then the video comes back or it just stays blank for a while and then maybe it will come back but it...
                                          05-07-2023, 08:12 AM
                                          HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load, Asset Tag & Testntag boardview and 450 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                          09-06-2024, 10:56 AM
                                          HP ProBook 430 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 430 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load & Asset Tag boardview and 430 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
