Bush LED32982HDT video / image problems
    Re: Bush LED32982HDT video / image problems
    http://tvrepairsolution.blogspot.com...lcd-panel.html
    See page 10 and 11 too:
    Also here:
    Incorrect setting of the LCD panel is service menu can also give the same result in bad GAMMA.
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      Thanks i will have a read i think the op said he looked in the service menu but a lot was read only so cant alter much hence maybe going to try new firmware would new correct firmware solve the incorrect panel settings?
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Thanx, budm.
        • notallbad
          • Oct 2012
          • 1190
          So these tcon bds are not tv model specific?
          i.e if its a 6870c-0370a LC320EXN it should work on this tv set regardless of whether it came from another bush or toshiba etc...?
          Sorry to bother you all with this trivial question!
          thanks
          • ducky29
            • Dec 2015
            • 369
            • Europe
            Edit: Looks like in this case it should come from a similar set. I searched on ebay the part number of your tcon but nothing comes up.
            Ps: I searched using the part number of the manufacturer.
              The T-CON has to match the LCD panel, when TV manufacture buys the LCD panel, the panel comes with the T-CON board, and most of the time also comes with the backlights driver board.
              Some time the TV manufacturers use more than one LCD panel manufacturers for the same model.
              Spec of similar LCD panel SC instead of SD:
              It tells you the power requirement of the T-CON and the LED driver, pin out, etc.
              • vinceroger69
                • Mar 2012
                • 6714
                • uk
                #27
                some more good information thanks budm so maybe best the op gets the correct tcon that matches his panel and hopefully that will sort it, whats your thoughts though on a lot of the service menu items being read only could the wrong tcon cause this too?
                • Andrew F. Ali
                  • Jan 2014
                  • 2450
                  • Trinidad & Tobago
                  #28
                  • Jaime Morillo
                    Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                    by Jaime Morillo
                    Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                    The TV was stuck on the logo and I couldn't access the update menu.
                    I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                    The image result was good, but the image is inverted.
                    The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                    Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                    08-18-2025, 11:38 AM
                  • Kiks412
                    BENQ MP511 Video Projector - No Button Responce and wierd Image
                    by Kiks412
                    Hey guys, I have this Video Projector that turns on, takes a bit to give some image, and when it does it displays a weird static image, and has no reaction to on-device buttons or remote whatsoever, even to turn off, only unplugging from the outlet. I'm new to this kind of device so I will be very happy to get some help with this....
                    12-20-2022, 10:00 AM
                    GeForce RTX2080 Super Aero video gaming card issues help need
                    This is from my son’s gaming computer that at first had minor overheating issues when playing a very intense game with it causing the computer to crash or reboot
                    Then bough a new motherboard and a new computer case that a cooling system in it already installed also brought the cooling system for this video card but now the issue with it is that it randomly rebooted screen goes blank randomly and suddenly video freezing or started with video being there then blank screen and then the video comes back or it just stays blank for a while and then maybe it will come back but it...
                    05-07-2023, 08:12 AM
                    HP ProBook 450 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                    This specification for the HP ProBook 450 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load & Asset Tag boardview and 450 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                    09-06-2024, 10:56 AM
                    HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
                    This specification for the HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load, Asset Tag & Testntag boardview and 450 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
