Replacing Power Mosfet in Toshiba 32L1300UC LCD TV power supply?
  • kodiac
    • Jul 2010
    • 116
    I would like to know if it is possible to replace a UTC7N65 power mosfet with a STP7NK80ZFP power mosfet?
    If no - is there is a substitute for the UTC7N65 that can be installed in a Toshiba 32L1300UC LCD TV power supply?
    Thank You
  • R_J
    • 9535
    Re: Power Mosfet
    The current is a bit low, 5.2 amp vs 7.4 amp
    Digikey has this one, DMG9N65CTIDI-ND, looks a bit closer?
    • kodiac
      • Jul 2010
      • 116
      Re: Power Mosfet
      Thank You very much sir.
      Would it be possible to use a substitute Mosfet with internal Zener diodes as opposed to normal diodes?
      How does the Zener diodes affect the performance of the Mosfet?
      Thank You
      • kodiac
        • Jul 2010
        • 116
        Re: Power Mosfet
        Can I replace the 7n65 with a MMD70R600P MosFet?
        Thank You
        • kodiac
          • Jul 2010
          • 116
          Re: Power Mosfet
          Anyone have a Toshiba 32l1300 LCD TV that has no picture, no power - no standby led, blank screen?
          Just like to know how it was brought back to life?
          Thank You
          • R_J
            • 9535
            Re: Power Mosfet
            What was wrong with the fet? was it shorted? Was it SQ801? if not, do you get any voltages on the plug going to the main board?
            I do see an eeprom available for this model, that might be the cause of the problem.
            • kodiac
              • Jul 2010
              • 116
              Re: Power Mosfet
              Thank You for your reply.
              Do You have a schematic for the Toshiba 32L1300?
              • R_J
                • 9535
                Re: Power Mosfet
                No I don't
                • kodiac
                  • Jul 2010
                  • 116
                  Re: Power Mosfet
                  Can You show me the link to the firmware / Eeprom dump for the Toshiba 32L1300 please?
                  Thank You
                  • R_J
                    • 9535
                    Re: Power Mosfet
                    I had the wrong main board, the eeprom would be for a VTV-L40711 main board
                    Why don't you post the voltages I asked for, that way maybe it can be determined where the problem is.
                    • kodiac
                      • Jul 2010
                      • 116
                      Re: Replacing Power Mosfet in Toshiba 32L1300UC LCD TV power supply?
                      OK I will do that.
                      Thank You
                      • kodiac
                        • Jul 2010
                        • 116
                        Would the MMD70R600P be a replacement for the 7n65?
                        Thank You
                        • R_J
                          • 9535
                          the MMD70R600P is a surface mount component, not the same mounting as the 7n65
                          • kodiac
                            • Jul 2010
                            • 116
                            The 70R600P I have is in the TO-220 package.
                            Power Supply Board and Voltages attached.
                              What did you use for the meter GND ref when you made those Voltage measurement in the HOT side of the circuit? Chassis?
                              You need to use the negative leg of the main filter cap as the GND ref when working in the hot side of the circuit.
                              Please provide the pictures of the bottom side of the board so we can see the SMPS IC?
                              Was the original MOSFET shorted out? BTW, already asked in post #6 but no reply.
                              • kodiac
                                • Jul 2010
                                • 116
                                "What did you use for the meter GND ref when you made those Voltage measurement in the HOT side of the circuit?"
                                The meter GND ref was the silver Philips screw ( Chassis ) in the top right hand corner of the picture next to the AC Power connector.
                                The Bridge Rectifier voltage was pins 1 + and pin 4 - = 168v.
                                " Was the original MOSFET shorted out? "
                                Yes the original MOSFET was shorted out.
                                I'll post new voltages and pictures.
                                  If the MOSFET shorted out, it could have damaged the SMPS IC too.
                                  • kodiac
                                    • Jul 2010
                                    • 116
                                    Top and Bottom of Power Supply Board.
                                    Meter GND - Capacitor - .
                                    • kodiac
                                      • Jul 2010
                                      • 116
                                      Thank You
                                      • R_J
                                        • 9535
                                        If the mosfet was shorted, it is a very good chance R815 is also open also like budm said. U801 could be damaged, If the fet Drain shorts to Gate the full 160V could be applied to the ic.
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                          by sam_sam_sam
                                          07-01-2024, 06:34 AM
                                        • JimBanville
                                          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                          by JimBanville
                                          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                          Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                          I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                          09-13-2023, 07:21 AM
                                        • CMCM
                                          Russound CA4 Power Supply Repair
                                          by CMCM
                                          Hello Everybody,
                                          Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                                          Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                                          The outputs marked 12v and 20v are all measuring only 1v.
                                          The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                                          The capacitors physically look clean (no bludgesor leaks) and...
                                          07-03-2025, 01:12 PM
