sharp aquos turns off and on random times
  • cossiejay
    • Nov 2010
    • 83
    i have a sharp aquos model number 60le741e uk spec 230 volts it has been a excellent set for the last 2 years up until now ,it has developed a fault where it will turn off for no reason sometimes it will turn back on others i have to turn it on there is no patten it can be within 2 mins of first turning on or 6 hours later sometime the power light will come back on and stay on others it turns off and flashes 2 times ( from what i have read power supply fault code is 2 flashes) which would fit the faults the tv is having i have removed the board and there are no swollen caps theres is no build up of dust etc i have performed a hard reset by holding input and volume down to enter service menu left unplugged all night its not solved anything please i am at wits end a replacement power board is £75 which i dont have thank you
    the power supply is a PSU DPS-162KP-1A (RUNTKA958WJQZ) - SHARP LC-60le741E
    Re: sharp aquos turns off and on random times
    1) Please upload good clear pictures of the whole backside of the TV showing all the board, and then good clear straight shot pictures of the whole power supply board (shopjimmy does not have pictures of your board for me to look at).
    2) So what DC Voltages do you have on each pin of the PD connector (if it has connector named PD) when it is working and when it is not working? You need to report pin name and follow by the Voltage reading of each pin.
    • cossiejay
      • Nov 2010
      • 83
      turned out to be the main board not the power board
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Thanks for the info.
        • scubacamper
          Sharp Aquos LC-70C6400U Half Screen Dark
          by scubacamper
          I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
          Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
          when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
          05-03-2025, 12:19 PM
        • sefoster
          Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
          by sefoster
          I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
          11-20-2022, 09:29 AM
        • mr._mulligan
          Sharp Aquos LC-46D85UN turns off by itself
          by mr._mulligan
          I have a 10 year old Sharp Aquos LC-46D85UN that works for a few minutes, then it clicks and turns off. After it turns off, the OPC and the power LED blink twice together, then the OPC LED alone blinks a third time.
          Sometimes, the TV would work fine for 30 minutes before this happens. After it happened once, it keeps happening after a shorter period of time.
          Any clues on how to diagnose the problem? Any help would be greatly appreciated! Thanks!
          06-15-2020, 08:39 AM
        • jonah1024
          Sharp Aquos LC-40UG7252E LCD TV burn in?
          by jonah1024
          Hello!
          I'm a few days old into this TV screens repair universe so please bear with me.
          Recently, and all of a sudden my 40ā€ 4K Sharp Aquos LCD TV turned on with colors all smudged in some places on the screen that remain like that even without any kind of video source. I do have image but the colors are smudged/tinted/ washed out in patches as per defects. This to me looks similar to burn in but I’m shore this is not an OLED.
          - I did the classic unplug and hold power button to discharge the caps but it didn't help.
          - I did a factory reset as well...
          07-16-2024, 04:23 AM
        • stale
          Sharp LC32GD4U - Multiple logic/t-con issues
          by stale
          Recently got this set for $15.
          When plugged in, the power light turns red as normal,
          and when powered on, the backlight immediately turns on, as does the blue power LED, but there's no other indication of startup; the input indicator sometimes shows up, but sometimes it doesn't.
          Elements of the UI seem to function; inputs can be selected and the volume can be adjusted. (I don't have the remote, so that's all I can test.)
          However, the TV seems to crash at 10-15 second intervals; certain actions, such as selecting the digital cable...
          11-29-2024, 12:19 AM
