toshiba 42tl515u problems
    • 12274
    • U.S.
    Re: toshiba 42tl515u problems
    Maybe you can test some components on the mainboard, might just be a 2 dollar part needed?
      • 12274
      • U.S.
      A few repair services on ebay, they want about 100 bucks.
      • doesntmind
        • Feb 2014
        • 65
        • usa
        A few repair services on ebay, they want about 100 bucks, seems pricey.
        Thank you so much for your help! Do you know where I might be able to find a service manual on this so I can get a better idea on fixing the mainboard?
          • 12274
          • U.S.
          I believe the member here named nickstvs does repair service, not sure tho, you would have to check with him, if you want.
            • 12274
            • U.S.
            Some use this site. https://elektrotanya.com/
            • doesntmind
              • Feb 2014
              • 65
              • usa
              #26
              Thank you for this resource, I wasnt able to find my boards manual but I will keep this in bookmarks.
              So far I have been able to trace the BL_ONOFF to the collector pin of LY Q1001 on back side of board. Do you think I should attempt applying heat on the board for a bit in case it just needs reflow? any tips or suggestions?
                • 12274
                • U.S.
                #27
                Hmmm, there looks like a lot of tiny components on the back, myself I would be worried I would lose some of them by applying too much heat, you might be right tho, not sure? there may be a way to test the components first without adding heat, to see if they are in working order.
                  • 12274
                  • U.S.
                  #28
                  Might be a test procedure for LY Q1001.
                    • 12274
                    • U.S.
                    #29
                    It's a transistor, you can check youtube for transistor testing, some videos are better than others of course.
                    • R_J
                      • 9588
                      The transistor marked LY is a 2SC2712-Y, easy to check with a meter on diode test
                        Report the Voltages of all 3 pins with ref to gnd when TV is OFF and when power switch is activated.
                        Bur at this point you have more than just he BL-ON. Do you have PWM Dimming control signal?
                        Do you have 12VDC feeding the T-CON?
                        • doesntmind
                          • Feb 2014
                          • 65
                          • usa
                          #32
                          I have 164mV at PWM pin
                          the emitter pin on both transisters are connected.
                          the base of q1001 goes to a 10k resistor then collector of q1002.
                          the base of q1002 goes to a 4.7k resistor then to both emitter pins.
                          Q1001
                          pin - desc - standby - reading
                          1 - base - 0 - 700mV
                          2 - emitter - 0 - 5mV
                          3 - collector - 0 - 24mV
                          Q1002
                          1 - base - 0 - 6.2mv
                          2 - emitter - 0 - 6.2mv
                          3 - collector - 0 - 3.2V
                          • doesntmind
                            • Feb 2014
                            • 65
                            • usa
                            #33
                            forgot last question, i only found 3v on one pin but couldnt find 12v anywhere on tcon
                              Did you check right at both ends of the SMD fuse on the T-CON board? You know where the fuse is, right?
                              • doesntmind
                                • Feb 2014
                                • 65
                                • usa
                                #35
                                I read 300mV at both sides of fuse while system is on, 20mV when standby
                                  You have more than just no bl-on problem, the MAIN is not sending the signal to turn on the switched MOSFET to supply the 12V to the T-CON either.
                                  So more in-depth troubleshooting of the main board will be required, so you can spend lots of time locating the schematic of your main board and do more testing.
                                    09-06-2024, 05:27 AM
                                    09-06-2024, 05:59 AM
                                    09-06-2024, 05:33 AM
